After you have installed the JD Edwards EnterpriseOne Deployment Server, Enterprise Server, Database Server, and HTML Web Server, you may wish to perform some of these tasks:
Working with Sign-on Security
Applying an Oracle Business Accelerator
Building and Testing Packages
Installing Languages
Creating a Language-Only Plan
Adding a Server to an Existing Configuration
Setting up Microsoft Windows Security on Deployment Server
Using Adobe SVG Viewer on Web Clients
Building Task Word Search Tables
Configuring JD Edwards EnterpriseOne for use with Vertex
Enabling CRM
Enabling Verity Search Capability
Copying an Environment to Another Environment
Basic security has been set up in the Security tables on the Database Server. The Security Server is running on the Enterprise Server. You must turn on the Security Server on the Deployment Server before running an Oracle Business Accelerator.These tasks are described in detail in the JD Edwards EnterpriseOne Applications Release 9.1 Installation Guide for Oracle on Unix, which is available in the document on the Oracle Technology Network at this link:
http://docs.oracle.com/cd/E24902_01/doc.91/e23313.pdf
Important:
The Support Assistant is delivered with the Deployment Server installation and is located inside the Change Assistant folder. This is an executable that collects information such as configuration and logs. In the event that you place a Service call, Global Customer Service may request that you run the Support Assistant.
