Go to main content
1/20
Contents
Title and Copyright Information
Preface
Audience
Documentation Accessibility
Conventions
1
Understanding JD Edwards EnterpriseOne and Oracle VM Templates
1.1
Understanding This Guide
1.2
Understanding the Installation Process
1.2.1
Understanding the Deployment Server Installation
1.2.2
Understanding the Creation of the Enterprise, Database and HTML Web Server Virtual Machines
1.2.3
Understanding the Database Server for Non-Virtualized Databases such as Oracle Exadata or ODA
1.2.4
Understanding the Web Development Client Installation
1.3
Certifications (Formerly Known as Minimum Technical Requirements)
1.4
Working With the Customer Checklist
1.5
Working With the Pre-Install Worksheet
1.5.1
Environments Overview
1.5.2
Updating to the Operating System and Applications
2
Before You Begin the Installation
2.1
Verifying Software and Hardware Requirements
2.2
Verifying the Disk Space Requirements
2.3
Host Name
2.4
Security Considerations
2.5
Overall Process Flow
3
Working with the Deployment Server
3.1
3.2
Local Oracle Enterprise Edition (OEE) Considerations
3.2.1
32-Bit Oracle Database Client (Required to Run EnterpriseOne)
3.2.2
EnterpriseOne Application P96717
3.2.3
Best Practices for OEE Performance
3.3
Obtaining and Preparing the Deployment Server Install Image
3.4
Working with JDBC Drivers on the Deployment Server
3.5
Installing the Deployment Server
3.5.1
Prerequisites
3.5.2
Installation Process Flow
3.5.3
Before Launching the Deployment Server Installer
3.5.4
Understanding Destination Paths
3.5.5
Using InstallManager to Install a Local Database on the Deployment Server
3.5.6
Examine the Local Database Installer Logs
3.5.7
Understanding the JD Edwards EnterpriseOne Deployment Server Installer
3.5.7.1
Understanding EnterpriseOne Files Location
3.5.7.2
Running the JD Edwards EnterpriseOne Deployment Server Installer
3.5.7.3
Mandatory Post Installation Tools Accelerator
3.6
Working with the Development Client Installation
3.6.1
Updating the oraparam.ini File
3.6.2
WebSphere Express Considerations
3.6.3
Add the Security Server Name to the Development Client jde.ini
3.7
Adding Additional Environments (Rerunning the Deployment Server Installer)
3.8
Downloading and Installing the Latest Software (Optional Except for Planner Update, which is Recommended)
3.8.1
Installing the Latest Tools Release and Latest Tools Release Patch to the Deployment Server
3.8.2
Installing the Latest Planner Update and Running the Special Instructions
3.9
Troubleshooting Deployment Server Installation
3.9.1
Verify Local Planner Tablespaces are Not Attached
3.9.2
OEE Installer Logs
3.9.3
Configuration Files
3.9.4
Path Code Master (F98611)
3.9.5
3.9.5.1
File Locations
3.9.5.2
Rebooting the Deployment Server
3.9.5.3
EnterpriseOne Access to the Local Oracle Database
3.9.5.4
Process Explorer
3.9.5.5
Verifying the Local Oracle Database Installation
3.9.5.6
Deployment Server Installation Problems
3.9.5.7
Runtime Problems
3.9.5.8
Administering the Local Oracle Database Using SQL Plus
3.9.5.9
Encrypting the Password of the Local Oracle Database
3.9.5.10
Decrypting the Password of the Local Oracle Database
3.9.5.11
Import and Export Tablespaces to the Local Oracle Database
3.9.5.12
Local Oracle Database Configuration
3.9.5.13
Deployment.inf and <Package_name>.inf
3.9.6
UBE Submission Failed on the Development Client
3.10
Configuring the Planner Databases
4
Working with Oracle VM Templates for JD Edwards EnterpriseOne
4.1
Implementing the Oracle Database With or Without Oracle VM Templates
4.2
Completing the Pre-Install Worksheet
4.3
Working with the Download Files
4.4
Extraction the Oracle VM-Templated for EnterpriseOne Application and System Images to the FTP or HTTP Server
4.4.1
Working with the vm.cfg Files
4.4.2
Working with .zip and .tgz files for the JD Edwards EnterpriseOne Image for the System
4.4.3
Working with .zip and .tgz files for the JD Edwards EnterpriseOne Image for the Enterprise Server
4.4.4
Working with .zip and .tgz files for the JD Edwards EnterpriseOne Image for the Database Server
4.4.5
Working with .zip and .tgz files for the EnterpriseOne Image for the HTML Server
4.4.6
Working with .zip and .tgz files for the JD Edwards EnterpriseOne Image for the BI Publisher Server
4.4.7
Working with .zip and .tgz files for the JD Edwards EnterpriseOne Image for the Mobile Server
4.5
Uploading a VM Template for JD Edwards Enterprise One Application Image
4.6
Creating a VM Guest from the JD Edwards EnterpriseOne Application Template
4.7
Starting and Configuring the JD Edwards EnterpriseOne VM Guest Image
4.7.1
Boot the VM and Configure System IP and Host Names
4.7.2
Run the EOne_cfg.ksh Script to Input Worksheet Information
4.7.3
Run the EOne_cfg.ksh Script to Synchronize Values
4.7.4
Changing Base Configurations of the JD Edwards EnterpriseOne Templates
4.7.4.1
Changing Base Configurations if the Database Server is Virtualized (VM Template)
4.7.4.2
Changing Base Configurations if the Database Server is non-Virtualized
5
Working with the Platform Pack in Silent Mode for a Non-Virtualized Database Server
5.1
Understanding the Platform Pack for a Non-Virtualized Database Server
5.2
Understanding the Connect String
5.3
Working with the Platform Pack Installer for a Non-Virtualized Database Server
5.3.1
Working with the zip File for the Platform Pack Installer
5.3.2
Working with the Response File for the Platform Pack Installer
5.3.3
Running the Platform Pack Installer for Non-Virtualized Database Servers
5.3.4
Working with Installer Log Files
5.3.5
Deinstalling the Platform Pack for Non-Virtualized Database Servers
6
Working With the Enterprise Server
6.1
Starting and Shutting Down Network Services on the Enterprise Server
6.2
Verifying the Release 9.1 Enterprise Server Installation Using PORTTEST
7
Starting the JD Edwards EnterpriseOne Servers
7.1
Starting the HTML Server
7.2
Starting the BI Publisher Server
7.3
Starting the Mobile Server
8
Testing the JD Edwards HTML Web Server Connection
9
Installing the Workstations for Developers and System Administrators
9.1
Workstation Installation
9.1.1
Overview of Workstation Installation
9.1.2
Prepare for Workstation Installation
9.1.3
Prerequisites
9.1.4
Configure the jde.ini File on the Deployment Server to Specify the Security Server
9.1.5
Modifying the Workstation JDE.INI on the Deployment Server for Languages (Optional)
9.2
Copying the Configured tnsnames.ora File
9.3
Copying the JDK to the Deployment Server
9.4
Understanding Workstation Installation Methods
9.4.1
Interactive Mode
9.4.1.1
Creating a Desktop Shortcut
9.4.1.2
Using a Shared Drive
9.4.2
Silent Mode
9.4.3
Push Mode
9.5
Understanding Third-Party Products
10
Next Steps
11
Deinstalling the Software
11.1
Understanding the Deinstallation
11.2
Deinstalling the Software from the Workstations
11.3
Deinstalling the Local OEE from the Deployment Server
11.4
Deleting Virtual machines for JD Edwards EnterpriseOne Servers
A
Globalization Considerations
A.1
National Language Setting Considerations
A.2
NLS Considerations for Non Western European Users
A.2.1
Non-Western European Database Language Considerations
B
Documentation Resources
B.1
Oracle VM Documentation
B.2
Oracle Exalogic Documentation
B.3
Oracle Enterprise Manager
B.4
JD Edwards EnterpriseOne Installation Guide
B.5
JD Edwards EnterpriseOne HTML Server on WebLogic Reference Guide
C
Security and Demo Data Configuration
C.1
Licensing Considerations
C.2
Understanding Users for the Mobile Application
C.3
Understanding Default Passwords for Database Users
C.4
Considerations for Securing Database Users
C.5
Securing the Miscellaneous Users
C.6
Securing Package Build Users
C.7
Securing the ESU Users
C.8
Securing Other Users
C.9
Securing the JDE User
C.10
Adding a Security Override
C.11
Changing the Admin Password with the P98OWSEC Security Application
C.12
Changing the User Password in the Database
C.13
Working with the Oracle Business Intelligence Publisher Schema Password
C.13.1
Step 1: Modify the Schema Password from the Database
C.13.2
Step 2: Modify the Data Source Connection Information from the WebLogic Administration Console
D
Installing an OVM database to a Non-Virtualized Database using OUI in GUI Mode
D.1
Understanding the Platform Pack in GUI Mode for a Non-Virtualized Database Server
D.2
Understanding the Platform Pack in GUI Mode for an ASM Database Server
D.3
D.3.1
D.3.2
D.3.3
D.3.4
E
Applying Patches
E.1
Oracle Systems
E.2
JD Edwards Applications, Clients, and Servers
F
Managing Disk Images Used Within the EnterpriseOne VMs
F.1
Creating a New Disk Image
F.2
Updating the vm.cfg File to Add the New Disk Image
F.3
Creating a Partition Table
F.4
Creating a New Physical Volume with the New Disk Image
F.5
Extending the Volume Group with the New Physical Disk
F.6
Extending the Logical Volume with the New Volume Group
F.7
Resizing the File System
F.8
Logical Volume Manager Command Summary
Scripting on this page enhances content navigation, but does not change the content in any way.
