This chapter contains the following topics:
Although equipped with a robust set of over eighty application modules, the JD Edwards EnterpriseOne product suite typically does not cover 100% of an enterprises's application requirements. As with any implementation of enterprise software, perhaps the most important requirement is that it integrates easily with other complementary applications. In this regard JD Edwards EnterpriseOne does not take a one-size-fits-all approach. Rather, it offers several interoperability and integration patterns to ensure that system architects can apply the appropriate technology for an optimal solution to the requirements.
JD Edwards EnterpriseOne offers the following methods for interoperability and integration with other Oracle applications and third-party products:
Business Services Server
Transaction Server
Connectors for point-to-point integration
Batch interfaces for bulk data transfer
This section discusses these topics:
Overview of Business Services Server
Business Services Server Architecture
Business Services Server Certified Platforms
Additional References
The Business Services Server provides interoperability between JD Edwards EnterpriseOne and other Oracle applications and third-party systems by natively producing and consuming web services. It can also send XML over HTTP(s) in an asynchronous request/reply model when the third party does not support web service calls. The business services server is built on top of a Java 2 Platform, Enterprise Edition (J2EE) server, which can be an Oracle WebLogic Server or a WebSphere Application Server. Applications that are developed or run on the Business Services Server are written in the Java programming language.
The business services server exposes business services as web services. A web service is a standardized way of integrating web-based applications, and in JD Edwards EnterpriseOne, web services are referred to as published business services. Business services provide operations that access the business logic in JD Edwards EnterpriseOne for many supported business transactions, such as journal entries, exchange rates, accounts payable vouchers, inventory look-ups, pricing, sales orders, etc and they enable JD Edwards EnterpriseOne to expose transactions as a basic service that can expose an XML document-based interface.
The business services server supports the following integration patterns for interoperating with other Oracle applications and third-party applications or systems:
Service provider
Service consumer
Event Notification
The lifecycle of a business service is similar to the lifecycle of a business function. A business service is created on the development client as a JD Edwards EnterpriseOne object using both JD Edwards EnterpriseOne tooling and JDeveloper. Object Management Workbench (OMW) controls the artifacts for add, check-in, check-out, get, restore, and delete. The business service is compiled and assembled into a deployable artifact during the package build process. Server Manager uses that deployable artifact to deploy a business services server. Subsequent client installs will include any new or updated business service artifacts.
The following diagram depicts the relationships between the various JD Edwards EnterpriseOne servers and the Business Services Server and it also shows how the business services server provides interoperability with other Oracle applications and third-party systems:
The below diagram provides an architectural overview of the business services lifecycle:
Figure 4-2 Business Services Server Lifecycle Architecture
Business Services Server is certified to run on the following platforms:
Linux / x86-64
Oracle Solaris / SPARC
Microsoft Windows /x86-64
HP-UX / Itanium
IBM AIX /Power
IBM i/Power
IBM WebSphere Application Server
Oracle Certification: https://support.oracle.com
, Certifications tab
Product = JD Edwards EnterpriseOne Business Services Server
Overview of AIS Server
AIS Server Architecture
AIS Server Certified Platforms
The AIS Server provides a JSON over REST interface, which is a light-weight interface that AIS clients (including mobile enterprise applications, AIS Java API clients, and the Simplified Applications Framework) use to interact with EnterpriseOne applications and forms. The interaction with EnterpriseOne requires an AIS Server configuration with the EnterpriseOne HTML Server.
The following illustration shows how the AIS Server functions as the interface between mobile applications and the EnterpriseOne HTML Server.
Figure 4-3 JD Edwards Mobile Architecture
AIS is certified to run on the following platforms (operating systems and web application servers):
Linux / x86-64
HP-UX / Itanium
IBM AIX /Power
IBM i/Power
Product = JD Edwards EnterpriseOne AIS Server
Overview of Transaction Server
Transaction Server Architecture
Transaction Server Certified Platforms
Transaction Server is a key component for the Real Time Event (RTE) notification system. RTE is an extension of the normal transaction process. This additional processing is performed to capture the JD Edwards EnterpriseOne transaction data for subsequent notification and delivery to external parties. This can also be termed as an Outbound Notification.
Transaction Server and Real time Event system consists of the following components:
Event - Contains JD Edwards EnterpriseOne data structure and values in binary and XML format for outbound notification in both single and aggregate format.
Event Category - Decides how event data is processed: for example RTE, XAPI, Z-FILE etc.
Transport Type - How the event is delivered using JAVA connector, COM connector, JDENET, MQ Series, JMS Topic etc.
Subscriber - Third party interested in receiving event and is associated with a transport type.
Following are the three life cycle events of processing in transaction server:
Event Generation
Business Function calls JdeIEO_EventFinalize API - An event or set of events is inserted into F90710 table
A JDENET message is sent to RTE server to trigger event transfer.
Event Transfer
Sequencing - Provides multiple options to sequence events
Transaction - Uses JMS Bean managed transaction.
Event Processing/Delivery
Convert binary format of data structure into XML format
Delivered to all interested subscribers based on transport type
Figure 4-4 Transaction Server Architecture
Transaction Server is certified to run on the following platforms:
Linux / x86-64
HP-UX / Itanium
IBM AIX /Power
IBM i/Power
Oracle Weblogic Server
IBM WeSphere Application Server
Product = JD Edwards EnterpriseOne Transaction Server
Connectors are point-to-point, component-based models that enable third-party applications and JD Edwards EnterpriseOne to share logic and data. JD Edwards EnterpriseOne connector architecture includes Java and COM connectors. The connectors accept inbound XML requests and expose business functions for reuse. Output from the connectors is in the form of an XML document. The connectors include:
Java
Java is a portable language, so you can easily tie JD Edwards EnterpriseOne functionality to Java applications. The JD Edwards EnterpriseOne dynamic Java connector supports real-time event processing.
COM
The JD Edwards EnterpriseOne COM connector solution is fully compliant with the Microsoft component object model. You can easily tie JD Edwards EnterpriseOne functionality to Visual Basic and VC++ applications. The COM connector also supports real-time event processing.
Some benefits of using connectors include:
Scalability
Multi-threaded capability
Concurrent users
Batch implies processing multiple transactions at the same time and usually involves movement of bulk information. Batch processing is often scheduled and is non-interactive. JD Edwards EnterpriseOne provides several model types for batch processing, and each model type has one or more capabilities that enable you to access JD Edwards EnterpriseOne data. The model types include:
Interface tables
Electronic Data Exchange
Table conversions
Output Stream Access
Open Data Access
