Front Panel Components (Installation)
Rear Panel Components (Installation)
Confirming Server and Site Specifications
Minimum Clearance for Service Access
AC and DC Power Supply Specifications
Overcurrent Protection Requirements
DC Power Source, Power Connection, and Grounding Requirements
Installing the Server in a 4-Post Rack
Installing the Standard 19-Inch Hardmount Kit (4-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (4-Post Rack)
Installing the 600-mm Hardmount Kit (4-Post Rack)
Installing the Server in a 2-Post Rack
Installing the 19-Inch Hardmount Kit (2-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (2-Post Rack)
Installing the 23-Inch Hardmount Kit (2-Post Rack)
Connecting Data and Management Cables
Powering On the Server the First Time
Assembling DC Power Cords and Applying DC Power
Power On the Host for the First Time
Choosing an OS Installation Method
OS Installation Task Map (Oracle Solaris)
OS Installation Task Map (Oracle VM)
OS Installation Task Map (Linux)
OS Installation Task Map (VMware ESXi)
OS Installation Task Map (Windows)
Supported OS Versions and Documentation
Understanding Installation Methods
Configuring the Preinstalled Oracle Solaris OS
Preinstalled OS RAID Limitations
Configuration Worksheet (Oracle Solaris)
Configure the Preinstalled Oracle Solaris OS
Configuring the Preinstalled Oracle VM 3. 0 Software
Configuration Worksheet (Oracle VM Server)
Configure the Preinstalled Oracle VM 3.0 OS
Preparing Your PXE Environment
Accessing Installation Utilities
RAID Configuration Requirements
Post-Installation RAID Volume Creation
Configuring RAID Volumes (LSI BIOS Utilities)
Performing Post-Installation Tasks
(Optional) Assign Boot Drive Priorities
Oracle VM Post-Installation Information
Performing Linux Post-Installation Tasks
Performing VMware ESXi Post-Installation Tasks
Performing Windows Post-Installation Tasks
Understanding Administration Resources
BIOS Overview (Administration)
Hardware RAID Administration Tools
Multiple Server Management Tools
Accessing Administration Tools
Access Add-On Card Configuration Utilities (BIOS)
Change Telco Alarm States Manually
Configuring Power-On and Boot Options
Change the Oracle ILOM Root Password (Oracle ILOM CLI)
Recover the Oracle ILOM Root Password
Configuring Oracle ILOM (Oracle ILOM Web Interface)
Configuring the SP and Oracle ILOM (BIOS)
Configure the SP and Oracle ILOM (OSA)
Configure the Enhanced PCIe Cooling Mode Policy (Oracle ILOM CLI)
Resetting the BIOS to Default Settings
Configuring Legacy Option ROM Allocation
Configuring I/O Resource Allocation
Obtain the Server Serial Number
Locate the Server (Oracle ILOM Web Interface)
Monitoring the Server Health (Oracle ILOM Web Interface)
Updating the Firmware and Software
Obtain and Update Firmware (OSA)
Mounting the Oracle System Assistant USB Flash Drive
Mount the Oracle System Assistant USB Flash Drive on a Linux Operating System
Mount the Oracle System Assistant USB Flash Drive on an Oracle Solaris 10 Operating System
Access the Firmware and Software on the Oracle System Assistant USB Flash Drive
Download Software Releases (My Oracle Support)
Available Software Release Packages
Requesting Updates on Physical Media
Request Physical Media (Online)
Request Physical Media (By Phone)
Component Locations (Storage, Power, and Fans)
Component Locations (Motherboard, Memory, and PCIe3 Cards)
Front Panel Components (Service)
Rear Panel Components (Service)
Troubleshooting (Oracle ILOM /SP Targets)
Troubleshooting (Oracle ILOM /System Targets)
Troubleshooting (Oracle ILOM Legacy Targets)
Component Service Task Reference
Removing Power From the Server
Raise the Drive Cage to the Service Position
Remove a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Riser 3)
Install the Drive Signal Cable
Determine if the Drive Backplane Is Faulty
Determine if the LED Board Is Faulty
Determine if the Motherboard Is Faulty
Determine if the PDB Is Faulty
Power On the Server (Oracle ILOM)
An example of how this command displays the storage devices on the server is shown below.
# lsscsi [0:0:0:0] disk SEAGATE ST360057SSUN600G 0805 /dev/sda [0:0:1:0] disk SEAGATE ST32000SSSUN2.0T 0313 /dev/sdb [0:0:2:0] disk SEAGATE ST32000SSSUN2.0T 0313 /dev/sdc [0:0:3:0] disk ATA INTEL HDDSA2BZ30 0362 /dev/sdd [0:0:4:0] enclosu ORACLE BLADE14 0903 - [7:0:0:0] disk SUN StorEdge 3511 421F /dev/sde [7:0:0:1] disk SUN StorEdge 3511 421F /dev/sdf [7:0:0:2] disk SUN StorEdge 3511 421F /dev/sdg [7:0:0:3] disk SUN StorEdge 3511 421F /dev/sdh [9:0:0:0] disk SUN CSM200_R 0660 /dev/sdi [9:0:0:1] disk SUN CSM200_R 0660 /dev/sdj [9:0:0:2] disk SUN CSM200_R 0660 /dev/sdk [9:0:0:3] disk SUN CSM200_R 0660 /dev/sdl [9:0:0:4] disk SUN CSM200_R 0660 /dev/sdm [9:0:0:5] disk SUN CSM200_R 0660 /dev/sdn [11:0:0:0] disk ORACLE SSM PMAP /dev/sdo
The Oracle System Assistant USB flash drive is the disk labelled ORACLE SSM and in this example is mapped to /dev/sdo.
An example of the output produced by this command is shown below.
# fdisk -l /dev/sdo Disk /dev/sdo: 3880 MB, 3880452096 bytes 4 heads, 32 sectors/track, 59211 cylinders Units = cylinders of 128 * 512 = 65536 bytes Device Boot Start End Blocks Id System /dev/sdo1 * 17 57344 3668992 ef EFI (FAT-12/16/32)
For example:
# mkdir /mnt/OSA
Here is an example of a mount command:
# mount -t vfat -o codepage=850 /dev/sdo1 /mnt/OSA # ls /mnt/OSA boot Firmware LiveOS OracleVM syslinux.cfg Documentation ldlinux.sys manifest.xml readme.html Versions.txt EFI Linux Oracle Solaris Windows #
The Oracle System Assistant USB flash drive is now mounted at the mount location specified.
