Front Panel Components (Installation)
Rear Panel Components (Installation)
Confirming Server and Site Specifications
Minimum Clearance for Service Access
AC and DC Power Supply Specifications
Overcurrent Protection Requirements
DC Power Source, Power Connection, and Grounding Requirements
Installing the Server in a 4-Post Rack
Installing the Standard 19-Inch Hardmount Kit (4-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (4-Post Rack)
Installing the 600-mm Hardmount Kit (4-Post Rack)
Installing the Server in a 2-Post Rack
Installing the 19-Inch Hardmount Kit (2-Post Rack)
Installing the 19-Inch Sliding-Rail Kit (2-Post Rack)
Installing the 23-Inch Hardmount Kit (2-Post Rack)
Connecting Data and Management Cables
Powering On the Server the First Time
Assembling DC Power Cords and Applying DC Power
Power On the Host for the First Time
Choosing an OS Installation Method
OS Installation Task Map (Oracle Solaris)
OS Installation Task Map (Oracle VM)
OS Installation Task Map (Linux)
OS Installation Task Map (VMware ESXi)
OS Installation Task Map (Windows)
Supported OS Versions and Documentation
Understanding Installation Methods
Configuring the Preinstalled Oracle Solaris OS
Preinstalled OS RAID Limitations
Configuration Worksheet (Oracle Solaris)
Configure the Preinstalled Oracle Solaris OS
Configuring the Preinstalled Oracle VM 3. 0 Software
Configuration Worksheet (Oracle VM Server)
Configure the Preinstalled Oracle VM 3.0 OS
Preparing Your PXE Environment
Accessing Installation Utilities
RAID Configuration Requirements
Post-Installation RAID Volume Creation
Configuring RAID Volumes (LSI BIOS Utilities)
Performing Post-Installation Tasks
(Optional) Assign Boot Drive Priorities
Oracle VM Post-Installation Information
Performing Linux Post-Installation Tasks
Performing VMware ESXi Post-Installation Tasks
Performing Windows Post-Installation Tasks
Understanding Administration Resources
BIOS Overview (Administration)
Hardware RAID Administration Tools
Multiple Server Management Tools
Accessing Administration Tools
Access Add-On Card Configuration Utilities (BIOS)
Change Telco Alarm States Manually
Configuring Power-On and Boot Options
Change the Oracle ILOM Root Password (Oracle ILOM CLI)
Recover the Oracle ILOM Root Password
Configuring Oracle ILOM (Oracle ILOM Web Interface)
Configuring the SP and Oracle ILOM (BIOS)
Configure the SP and Oracle ILOM (OSA)
Configure the Enhanced PCIe Cooling Mode Policy (Oracle ILOM CLI)
Resetting the BIOS to Default Settings
Configuring Legacy Option ROM Allocation
Configuring I/O Resource Allocation
Obtain the Server Serial Number
Locate the Server (Oracle ILOM Web Interface)
Monitoring the Server Health (Oracle ILOM Web Interface)
Updating the Firmware and Software
Obtain and Update Firmware (OSA)
Mounting the Oracle System Assistant USB Flash Drive
Requesting Updates on Physical Media
Component Locations (Storage, Power, and Fans)
Component Locations (Motherboard, Memory, and PCIe3 Cards)
Front Panel Components (Service)
Rear Panel Components (Service)
Understanding Diagnostic Tools Available During Server States
Tools Available When Power Cords Are Attached
Tools Available On Initial Power Up
Tools Available When the BIOS Menu Is Available
Tools Available When the OS Boots
Tools Available When the OS Is Running
Network Management Troubleshooting Guidelines
Troubleshooting (Oracle ILOM /SP Targets)
Enable Oracle ILOM Legacy Targets
Display Oracle ILOM Log Entries
Display Active Power Consumption
Display Information About User Sessions
Display the NET MGT Configuration Properties
Display the SP Firmware Version
Troubleshooting (Oracle ILOM /System Targets)
Display Problematic Components
Display PCIe3 Card Information
Display the General Health of Component Systems
Display Health and Information About Specific Components
Oracle ILOM Target Health States
Display Faults (show faulty Command)
Troubleshooting (Oracle ILOM Legacy Targets)
Display FRUID and Fault State for Specific Components
Oracle ILOM Legacy Targets for Component FRUID and Fault States
Display Component Power Consumption
Oracle ILOM Legacy Targets for Component Power Consumption
Display Component Temperatures
Oracle ILOM Legacy Targets for LED States
Diagnose the Drives and USB Drive
Component Service Task Reference
Removing Power From the Server
Raise the Drive Cage to the Service Position
Remove a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Risers 1 and 2)
Install a PCIe3 Card (Riser 3)
Install the Drive Signal Cable
Determine if the Drive Backplane Is Faulty
Determine if the LED Board Is Faulty
Determine if the Motherboard Is Faulty
Determine if the PDB Is Faulty
Power On the Server (Oracle ILOM)
Note - The Oracle ILOM CLI includes implementations of Oracle Solaris fault manager commands, such as fmadm and fmdump, within the Oracle ILOM CLI shell. This feature is referred to as the Oracle ILOM faultmgmt shell. For more information about the Oracle Solaris fault manager commands, refer to Server Administration and the Oracle Solaris documentation.
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y
faultmgmtsp> fmadm faulty No faults found faultmgmtsp>
If a fault is found, information about the fault is displayed in seven fields:
Heading – The time, UUID, MSGID, and severity of the fault are displayed.
Fault class – A categorization of the fault according to the component and type of fault.
FRU – The Oracle ILOM target, part number, and serial number of the faulted component.
Description – A succinct statement of the fault.
Response – A description of how the system responded to the failure.
Impact – A description of the consequences if no service action is taken.
Action – Additional tasks the user can do to supplement troubleshooting the fault.
This is an example of a power supply fault:
Note - The characters SPT at the beginning of the message ID indicate that the fault was detected by Oracle ILOM.
------------------- ------------------------------------ -------------- -------- Time UUID msgid Severity ------------------- ------------------------------------ -------------- -------- 2011-09-13/15:47:41 d7d67b9b-ba67-e257-8d8d-bcef2db2971b SPT-8000-MJ Critical Fault class : fault.chassis.power.fail FRU : /SYS/PS0 (Part Number: 300-2304) (Serial Number: C40003) Description : A Power Supply has failed and is not providing power to the server. Response : The service required LED on the chassis and on the affected Power Supply may be illuminated. Impact : Server will be powered down when there are insufficient power supplies operational. Action : The administrator should review the ILOM event log for additional information pertaining to this diagnosis. Please refer to the Details section of the Knowledge Article for additional information.
faultmgmtsp> fmdump TIMESTAMP UUID MSGID 2011-12-20/06:00:14 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 2011-12-20/06:03:26 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 Repaired 2011-12-20/06:03:26 52db4790-1d30-e1d5-b4e3-8bf677246bd2 ILOM-8000-30 Resolved 2012-01-27/18:47:27 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 2012-02-16/16:54:08 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 Repaired 2012-02-16/16:54:08 f69cca33-4759-4e16-9a06-9feaaa19a15c SPX86-8003-K5 Resolved 2012-03-06/20:13:05 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 2012-03-06/20:24:12 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 Repaired 2012-03-06/20:24:13 63e1c3c7-910a-e825-83d5-d180378f54ae SPX86-8003-73 Resolved faultmgmtsp>
The fault history provides the date and time (TIMESTAMP) of the fault, the UUID, and the MSGID of the fault.
In this example, three fault events occurred as indicated in the MSGID column. When the fault was Repaired satisfactorily, Oracle ILOM marked the fault as Resolved.
faultmgmtsp> exit ->
