This issue only applies to the Oracle Solaris 10 OS. This issue does not apply to the Oracle Solaris 11.1 OS.
The SPARC T5 series servers introduce the ability to display SP (Oracle ILOM) faults within the Oracle Solaris OS. However, several fields of information, such as the affected FRU, FRU location, and platform serial number, are not properly interpreted by the Oracle Solaris 10 OS.
As in previous platform releases, significant failures detected by the SP illuminate the chassis fault LED, indicating that the SP status should be investigated.
Workaround: If you encounter proxy faults that contain missing or incomplete information, gather the required information from the SP. Refer to the SPARC T5-2 Server Service Manual for instructions.
