SPARC T5-1B Server Module Product Notes
Exit Print View
Updated: May 2016
Spurious sunos.eft.unexpected_telemetry Faults Might be Reported (15820471)
Note - This issue has been fixed in Oracle Solaris 11.1.4.6.0.
A device reporting a large number of correctable errors continues to report errors while it is being disabled. Each error is queued and diagnosed in order. In rare cases, the last error reported by the device might be queued but not processed for diagnosis until after the device is disabled. This last error is reported as unexpected telemetry, because the device is no longer enabled in the system.
For example:
# fmadm faulty
Time                UUID                                 msgid
Problem Status    : solved
Diag Engine       : [unknown]
System
   Manufacturer   : Oracle Corporation
   Part_Number    : 7045605
   Serial_Number  : xxxxxxxxxx
Severity
Suspect 1 of 2
   Fault class  : fault.sunos.eft.unexpected_telemetry
   Certainty    : 50%
   Affects      : dev:////pci@1040/pci@1/pci@0
   Status       : faulted but still in service
FRU
      Status            : faulty
      Chassis
2012-10-04/17:24:07 87732365-faa6-e9cd-bf2a-9052cb8cf876 SUNOS-8000-J0 Major
Suspect 2 of 2
   Fault class  : defect.sunos.eft.unexpected_telemetry
   Certainty    : 50%
 FRU
 Status            : faulty
Description: A fault has been diagnosed by the Host Operating System.
Response   : The service required LED on the chassis and on the affected
             FRU may be illuminated.
Impact     : No SP impact.
Action     : Refer to the associated reference document at
             http://support.oracle.com/msg/SUNOS-8000-J0 for the latest
             service procedures and policies regarding this diagnosis.
Chassis
Workaround: You can ignore unexpected telemetry faults. To clear the fault, perform these steps:
  1. Type the fmadm faulty command to obtain the fault UUID.
    # fmadm faulty
    Time                UUID                                 msgid          ...
    Severity
  2. Clear the unexpected telemetry fault in the Oracle Solaris host using the fault UUID.
    # fmadm repair 87732365-faa6-e9cd-bf2a-9052cb8cf876
