Go to main content
Sun Datacenter InfiniBand Switch 36 Product Notes for Firmware Version 2.1
Exit Print View
Updated: March 2017
Replication Password Information Incomplete
The replication password is an eight alphanumeric character string used for encrypting communications between Subnet Managers nodes. All Subnet Managers must be configured with the same string, and you set the replication password using the smsubnetprotection command on the management controller of each Subnet Manager node. Because of the password's secure nature, is not readable. Therefore, you must remember the password for when adding Subnet Manager nodes in the future. Should you forget the replication password, you must reconfigure all Subnet Manager nodes with a new replication password.
