Some services use datagram sockets. The rwho(1) service provides status information on hosts that are connected to a local area network. Avoid running in.rwhod(1M) because in.rwho causes heavy network traffic. The rwho service broadcasts information to all hosts connected to a particular network. The rwho service is an example of datagram socket use.
A user on a host that is running the rwho(1) server can get the current status of another host with ruptime(1). Typical output is illustrated in the following example.
Example 7-8 Output of ruptime(1) Programexample1 up 9:45, 5 users, load 1.15, 1.39, 1.31 example2 up 2+12:04, 8 users, load 4.67, 5.13, 4.59 example3 up 10:10, 0 users, load 0.27, 0.15, 0.14 example4 up 2+06:28, 9 users, load 1.04, 1.20, 1.65 example5 up 25+09:48, 0 users, load 1.49, 1.43, 1.41 example6 5+00:05, 0 users, load 1.51, 1.54, 1.56 example7 down 0:24 example8 down 17:04 example9 down 16:09 example10 up 2+15:57, 3 users, load 1.52, 1.81, 1.86
Status information is periodically broadcast by the rwho(1) server processes on each host. The server process also receives the status information. The server also updates a database. This database is interpreted for the status of each host. Servers operate autonomously, coupled only by the local network and its broadcast capabilities.
Use of broadcast is fairly inefficient because broadcast generates a lot of net traffic. Unless the service is used widely and frequently, the expense of periodic broadcasts outweighs the simplicity.
The following example shows a simplified version of the rwho(1) server. The sample code receives status information broadcast by other hosts on the network and supplies the status of the host on which the sample code is running. The first task is done in the main loop of the program: Packets received at the rwho(1) port are checked to be sure they were sent by another rwho(1) server process and are stamped with the arrival time. The packets then update a file with the status of the host. When a host has not been heard from for an extended time, the database routines assume the host is down and logs this information. Because a server might be down while a host is up, this application is prone to error.
Example 7-9 rwho(1) Servermain()
    sp = getservbyname("who", "udp");
    net = getnetbyname("localnet");
    sin.sin6_addr = inet_makeaddr(net->n_net, in6addr_any);
    sin.sin6_port = sp->s_port;
    s = socket(AF_INET6, SOCK_DGRAM, 0);
    on = 1;
    if (setsockopt(s, SOL_SOCKET, SO_BROADCAST, &on, sizeof on)
            == -1) {
        syslog(LOG_ERR, "setsockopt SO_BROADCAST: %m");
        exit(1);
    bind(s, (struct sockaddr *) &sin, sizeof sin);
    signal(SIGALRM, onalrm);
    onalrm();
    while(1) {
        struct whod wd;
        int cc, whod, len = sizeof from;
        cc = recvfrom(s, (char *) &wd, sizeof(struct whod), 0,
            (struct sockaddr *) &from, &len);
        if (cc <= 0) {
            if (cc == -1 && errno != EINTR)
                syslog(LOG_ERR, "rwhod: recv: %m");
            continue;
        if (from.sin6_port != sp->s_port) {
            syslog(LOG_ERR, "rwhod: %d: bad from port",
                ntohs(from.sin6_port));
            continue;
        if (!verify( wd.wd_hostname)) {
            syslog(LOG_ERR, "rwhod: bad host name from %x",
                ntohl(from.sin6_addr.s6_addr));
            continue;
        (void) sn
printf(path, sizeof(PATH),
 "%s/whod.%s", RWHODIR, wd.wd_hostname);
        whod = open(path, O_WRONLY|O_CREAT|O_TRUNC
|O_NOFOLLOW, 0666);
        (void) time(&wd.wd_recvtime);
        (void) write(whod, (char *) &wd, cc);
        (void) close(whod);
    exit(0);
The second server task is to supply the status of its host. This requires periodically acquiring system status information, packaging it in a message, and broadcasting it on the local network for other rwho(1) servers to hear. This task is run by a timer. This task is triggered by a signal.
Status information is broadcast on the local network. For networks that do not support broadcast, use multicast.
