man pages section 3: Extended Library Functions, Volume 2
Exit Print View
Updated: July 2014
fegetexceptflag(3M)
Name
fegetexceptflag, fesetexceptflag - get and set floating-point status flags
Synopsis
cc [ flag... ] file... –lm [ library... ]
#include <fenv.h>
int fegetexceptflag(fexcept_t *flagp, int excepts);
int fesetexceptflag(const fexcept_t *flagp, int excepts);
Description
The fegetexceptflag() function attempts to store an implementation-defined representation of the states of the floating-point status flags indicated by the excepts argument in the object pointed to by the flagp argument.
The fesetexceptflag() function attempts to set the floating-point status flags indicated by the excepts argument to the states stored in the object pointed to by flagp. The value pointed to by flagp will have been set by a previous call to fegetexceptflag() whose second argument represented at least those floating-point exceptions represented by the excepts argument. This function does not raise floating-point exceptions but only sets the state of the flags.
Return Values
If the representation was successfully stored, fegetexceptflag() returns 0. Otherwise, it returns a non-zero value.
If the excepts argument is 0 or if all the specified exceptions were successfully set, fesetexceptflag() returns 0. Otherwise, it returns a non-zero value.
Errors
No errors are defined.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
Standard
See also
fenv.h(3HEAD), feclearexcept(3M), feraiseexcept(3M), fesetexceptflag(3M), attributes(5), standards(5)
