man pages section 5: Standards, Environments, and Macros
Exit Print View
Updated: July 2014
audit_remote(5)
Name
audit_remote - send Solaris audit logs to a remote server
Synopsis
/usr/lib/security/audit_remote.so
Description
The audit_remote plugin module for Solaris audit, /usr/lib/security/audit_remote.so, sends binary audit records (audit.log(4) ) to audit servers as they are configured with auditconfig(1M).
The audit_remote plugin is loaded by auditd(1M) if the plugin is configured as an active via auditconfig. Use the auditconfig –setplugin option to change all the plugin related configuration parameters.
The Solaris audit service daemon's audit remote service, ars(5), may be configured with auditconfig to receive the binary audit records send by audit_remote .
Object Attributes
The following attributes specify the configuration of audit_remote plugin:
p_hosts
host1[:[port1][:mech1]][,host2[:[port2][:mech2]],... \
    hostn[:[portn][:mechn]]]
A list of audit hosts/servers. Audit records are sent to the first available host. If a host is unreachable or a timeout occurs while sending data, the next host in the list is tried. If connection to all hosts fails, the list is tried again from the beginning.
The host part of a p_hosts entry can be in any form acceptable to getipnodebyname(3SOCKET).
The port part of a p_hosts entry is the port on host that is contacted to initiate an audit server connection. If not specified, the port number is that assigned to the solaris-audit service. See getservbyname(3XNET).
The mech part of a p_host entry is the GSS-API mechanism name (mech(4)). If not specified, the local host's default mechanism is used. The recommended mechanism is kerberos_v5.
p_retries
The number of retries for connecting to and sending data to a server.
The default value is 3.
p_timeout
The number of seconds in which a connection/sending data timeouts.
The default value is 5 seconds.
qsize
The maximum number of outstanding audit records to keep.
The default is the value of the kernel queue control high water mark. See auditconfig(1M).
If set to 0, the default value is the value of the kernel queue control high water mark. See auditconfig(1M).
GSS SESSION
The audit_remote plugin is a TCP client that authenticates configured audit servers using the GSS-API (libgss(3LIB)). Binary Solaris Audit records are sent with integrity and confidentiality protection as per-message tokens generated by gss_wrap(3GSS).
The plugin initiates a TCP connection to an audit server (host:port:mech) and establishes a GSS security context (with gss_init_sec_context(3GSS)), with appropriate security mechanism (mech(4)).
If no port is specified, the service name solaris-audit is looked up to obtain a TCP port number. If no mechanism is specified, the GSS_C_NO_OID is used as a mech_type parameter of gss_init_sec_context(3GSS), and causes the underlying GSS-API to use the local default mechanism.
gss_init_sec_context(3GSS) uses GSS_C_NO_CREDENTIAL as the initiator credential handle and a target name of the form audit@<host_fqdn>. The server is expected to use gss_accept_sec_context(3GSS) to complete the context establishment.
Once the security context is established, the client (audit_remote plugin) calls gss_wrap(3GSS) to achieve the confidentiality of the transferred payload - the audit records. The server is expected to use gss_unwrap(3GSS) to unwrap the received data and gss_get_mic(3GSS) to obtain the MIC (Message Integrity Code) to be later sent back to the plugin as a message retrieval acknowledgment.
For example, if the kerberos_v5 mechanism is configured as GSS_API mechanism on the client and both sides agree on using this mechanism, the client side has to be eligible to non-interactively gain session keys for the audit/<host_fqdn>@<REALM> principal from the Kerberos KDC/TGS. At the same time the identity running the audit server application has to have the long term keys associated with the audit/<host_fqdn>@<REALM> principal stored in the keytab file (krb5.conf(4)) to be able to decrypt the session keys.
The audit_remote plugin initiates a connection to first server in the p_hosts list. If the connection fails or audit record sends are not responded to in p_timeout seconds, after p_retries attempts the plugin tries to connect to the next server. If the connection to the last server fails, the plugin retries to connect to the first host in the list. audit_warn(1M) is executed at every unsuccessful attempt to connect to the server or send timeout with the plugin option plugin audit_remote.so retry <count> <error>.<error> is connection <host:port> <the network error>. An EPROTO network error indicates that the client plugin did not get a successful protocol version handshake.
PROTOCOL DESCRIPTION
All protocol messages are preceded by the 4 octets of the size of the data to follow. This size is in network byte order.
The protocol begins with version negotiation followed by a GSS-API security context token exchange. On error the connection is closed (and any output token optionally sent).
The version negotiation takes place in the clear with the plugin sending an octet array of the comma (,) separated list of versions supported. The current version number is the characters 01. The receiver is expected to respond with the version that they accept (in the current case that is the characters 01). A mismatch is considered an error and the connection is closed.
The version octet array sent by the plugin and the version characters accepted by the receiver are concatenated together to make up the application data field of the channel bindings of the GSS security context establishment.
<plugin version characters> || <server accepted version characters>
"||" represents concatenation
Subsequent tokens contain a 64 bit sequence number in network byte order and a single audit record (audit.log(4)); the client uses confidentiality protection. wrap (64 bit sequence number || audit record)
The server acknowledges the receipt (and is then responsible for any data loss) with the received 64 bit sequence number and a MIC token of the unwrapped 64 bit sequence number and audit record. MIC verification on the client side acknowledges the audit record can be freed and not saved for possible retransmission.
64 bit sequence number || mic (64 bit sequence number || audit record)
Secure remote audit client/server communication flow:
1) Client <--> Server - TCP handshake
2) Client <--> Server - protocol version negotiation:
   a) Client  --> Server - send data size - uint32_t value (2)
   b) Client  --> Server - send clear text message of the versions
                           supported comma separated, e.g.,
                           "01,02,03" for versions 1 and 2 and 3.
                           The only version supported at present is
                           "01"
   c) Client <--  Server - send data size - uint32_t value (2)
   d) Client <--  Server - send clear text version selected
                           ("01")
   :no version match; close connection; try next host
3) Security context initiation:
   a) Client - Construct channel bindings:
         initiator address type (GSS_C_AF_NULLADDR)
         acceptor address type (GSS_C_AF_NULLADDR)
         application data value (4 octets  "0101")
   b) Client  --> Server - send token (data) size - uint32_t value
   c) Client  --> Server - GSS-API per-context token
   d) Client <--  Server - send token (data) size
   e) Client <--  Server - GSS-API per-context token
      :repeat a-e until security context is initialized; if unsuccessful,
4) Client - transmit thread, when audit record to be sent:
   b) Client  --> Server - GSS-API per-message token
                  wrap (sequence number || audit record)
      :repeat a-b while less than max (qsize) outstanding records
 5) Client - receive thread:
    a) Client <--  Server - receive data size - uint32_t value
    b) Client <--  Server - receive sequence number - uint64_t value
    c) Client <--  Server - receive MIC
    d) Client             - MIC verification - OK
    e) Client             - remove particular audit record
                            pointed by the sequence number from the
                            retransmit buffer
  :repeat a-e, on error close connection; try next host;
   retransmit unacknowledged audit records
6) Server - receive thread:
    a) Client  --> Server - receive data size
    b) Client  --> Server - GSS-API receive, uwrap, store
                   per-message token
7) Server - transmit thread:
    a) Server - MIC generation - message integrity code
                    mic (sequence number || audit record)
    b) Client <--  Server - send data size
    c) Client < -- Server - send sequence number
    d) Client <--  Server - send MIC
Examples
Example 1 Loading audit_remote.so and Specifying the Remote Audit Servers
The following directives cause audit_remote.so to be loaded and specify the remote audit servers to where the audit records are sent. The kerberos_v5 security mechanism is defined to be used when communicating with the servers.
auditconfig -setplugin audit_remote active \
    "p_timeout=90;p_retries=2;
     p_hosts=eggplant.eng.sun.com::kerberos_v5,
     purple.ebay.sun.com:4592:kerberos_v5"
Example 2 Using the Configuration of Usage Default Security Mechanism
The following example shows the configuration of usage of default security mechanism. It also shows use of default port on one of the configured servers:
    "p_timeout=10;p_retries=2;
     p_hosts=jedger.eng.sun.com, jbadams.ebay.sun.com:4592"
Example 3 Internal plugin queue size settings
Certain conditions (for instance, high or bursty audit data traffic in combination with slow communication lines between server and client) may cause the number of outstanding audit records queued by the audit_remote plugin to reach the maximum number configured. The following example shows how to set the queue size parameter.
auditconfig -setplugin audit_remote "" 1000
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT Level
MT-Safe
Interface Stability
See below.
The plugin configuration parameters are Committed. The client/server protocol (version "01") is Contracted Project Private. See audit.log(4) for the audit record format and content stability.
See also
auditd(1M), auditconfig(1M) , audit_warn(1M), getipnodebyname (3SOCKET), getservbyname(3XNET), gss_accept_sec_context(3GSS), gss_get_mic(3GSS), gss_init_sec_context(3GSS), gss_wrap (3GSS), gss_unwrap(3GSS), libgss(3LIB), libsocket(3LIB), audit.log(4), krb5.conf(4), mech(4), ars(5), attributes(5), kerberos(5), tcp(7P)
Managing Auditing in Oracle Solaris 11.2
Notes
audit_remote authenticates itself to the remote audit service by way of GSS-API (libgss(3LIB)). Default gss credentials are used as provided by the gss implementation mechanism, such as Kerberos.
The solaris-audit service port assigned by IANA is 16162.
