Skip Navigation Links
Exit Print View
Sun Server X4-2
Security Guide
search filter icon
search icon
Document Information
Sun Server X4-2 Security Guide
Security Principles
Using Server Configuration and Management Tools
Planning a Secure Environment
Maintaining a Secure Environment
After the initial installation and configuration, use Oracle hardware and software security features to continue controlling hardware and tracking system assets.
Contact your IT Security Officer for additional security requirements that pertain to your system and specific environment.
Hardware Power Control
You can use software to turn power on and off to some Oracle systems. The power distribution units (PDUs) for some system cabinets can be enabled and disabled remotely. Authorization for these commands is typically set up during system configuration and is usually limited to system administrators and service personnel. Refer to your system or cabinet documentation for further information.
Asset Tracking
Use serial numbers to track inventory. Oracle embeds serial numbers in firmware on option cards and system motherboards. You can read these serial numbers through local area network connections.
You can also use wireless radio frequency identification (RFID) readers to further simplify asset tracking. An Oracle white paper, How to Track Your Oracle Sun System Assets by Using RFID, is available at:
http://www.oracle.com/technetwork/articles/systems-hardware-architecture/o11-001-rfid-oracle-214567.pdf
Updates for Software and Firmware
For security reasons, update the firmware on your system with the most recent firmware whenever a new version becomes available. This is important so that you take advantage of bug fixes and enhancements that improve the overall quality and security of the system.
Network Security
Follow these guidelines to secure local and remote access to your systems.
For more information about network security, refer to the Oracle ILOM Security Guide, which is part of the Oracle ILOM documentation library. You can find the Oracle ILOM documentation at:
http://www.oracle.com/goto/ILOM/docs
Data Protection and Security
Follow these guidelines to maximize data protection and security.
Log Maintenance
Inspect and maintain your log files on a regular schedule. Use these methods to secure log files.
