Skip Navigation Links
Exit Print View
Sun Server X4-2
Security Guide
search filter icon
search icon
Document Information
Sun Server X4-2 Security Guide
Security Principles
Using Server Configuration and Management Tools
Planning a Secure Environment
Maintaining a Secure Environment
This document provides general security guidelines to help you protect the Oracle Sun Server X4-2, its network interfaces, and the network switches to which it is connected.
Contact your IT Security Officer for additional security requirements that pertain to your system and specific environment.
The following sections are in this chapter:
