Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Cluster System Administration Guide Oracle Solaris Cluster 3.3 3/13 |
Overview of Administering Oracle Solaris Cluster
Oracle Solaris OS Feature Restrictions
Preparing to Administer the Cluster
Documenting an Oracle Solaris Cluster Hardware Configuration
Using an Administrative Console
Beginning to Administer the Cluster
How to Log Into the Cluster Remotely
How to Connect Securely to Cluster Consoles
How to Access the Cluster Configuration Utilities
How to Display Oracle Solaris Cluster Patch Information
How to Display Oracle Solaris Cluster Release and Version Information
How to Display Configured Resource Types, Resource Groups, and Resources
How to Check the Status of Cluster Components
How to Check the Status of the Public Network
How to View the Cluster Configuration
How to Validate a Basic Cluster Configuration
How to Check the Global Mount Points
How to View the Contents of Oracle Solaris Cluster Command Logs
2. Oracle Solaris Cluster and RBAC
3. Shutting Down and Booting a Cluster
4. Data Replication Approaches
5. Administering Global Devices, Disk-Path Monitoring, and Cluster File Systems
7. Administering Cluster Interconnects and Public Networks
10. Configuring Control of CPU Usage
11. Patching Oracle Solaris Cluster Software and Firmware
12. Backing Up and Restoring a Cluster
13. Administering Oracle Solaris Cluster With the Graphical User Interfaces
This chapter provides the following information about administering a global cluster and a zone cluster, and includes procedures for using Oracle Solaris Cluster administration tools:
All procedures in this guide are for use on the Oracle Solaris 10 Operating System.
A global cluster is composed of one or more global-cluster nodes. A global cluster can also include native and cluster brand, non-global zones that are not nodes, but rather are configured with the HA for Zones data service. For general information about zone clusters, see the Oracle Solaris Cluster Concepts Guide.
A zone cluster is composed of one or more non-global zones of the cluster brand. You create a zone cluster by using the clzonecluster command or the clsetup utility. You can run supported services on the zone cluster similar to a global cluster, with the isolation that is provided by Oracle Solaris zones. A zone cluster depends on, and therefore requires, a global cluster. A global cluster does not contain a zone cluster. A zone cluster has, at most, one zone cluster node on a machine. A zone-cluster node continues to operate only as long as the global-cluster node on the same machine continues to operate. If a global-cluster node on a machine fails, all zone-cluster nodes on that machine fail as well. For general information about zone clusters, see Oracle Solaris Cluster Concepts Guide.
