This host driver release supports Oracle HCAs as well as third-party manufacturers' HCAs with the requirement that the HCAs use the required version of firmware. Refer to the Oracle HCA's product notes for latest firmware versions.
The following Oracle HCAs are supported.
For third-party HCAs, refer to the manufacturer's documentation for the required firmware version.
