Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configuring the split-horizon Option
By default, the auto-summary option is enabled. Before you can manage the auto-summary option, you must configure your environment. The procedures in this section are based on RIP Topology 1. For instructions on how to configure switch 1, see Configure Switch 1. For instructions on how to configure switch 2, see Configure Switch 2.
