Enable IGS on a Specific VLAN Interface
Configure Multicast Forwarding Mode
Configuring a Multicast Router Port
Disable a Multicast Router Port
Configure the Multicast Router Port Time-Out Value
Configure the IGMP Snooping Query Interval
Configuring the Port-Purge Interval
Disable the Fast Leave Process
Configuring the Report Suppression Interval
Enable the Report Suppression Interval
Disable the Report Suppression Interval
Configuring the Group Query Interval Value
Set the Group Query Interval Value
Reset the Group Query Interval
Configuring the Group Retry Count Value
Set the Group Retry Count Value
Reset the Group Retry Count Value
Reset Report Forwarding to the Default Value
Clearing the Snooping Statistics
Clear the Statistics for a Specific VLAN
Clear the Statistics for All VLANs
Configuring the General Query Transmission Option
Enable the General Query Transmission Option
Disable the General Query Transmission Option
Flow-Based Configuration Example
Configure the MAC-Based Multicast Forwarding Mode
Configure the IP-Based Multicast Forwarding Mode
Configure a Static Router Port
You can configure the IGS switch as a querier for a specific VLAN. You can also configure the group-specific query interval for that VLAN. The IGS switch stops acting as a querier on the reception of general queries. The switch resumes the querier function when there are no IGMP routers in the network. The IGS switch continues to act as a querier on the reception of router control messages (for instance, PIM or OSPF messages), and the switch acts as a querier when the router port is operationally down and there are no router ports in the switch. Before you can configure IGS features, you must configure your network environment, as described in Topology Example.
