Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIMv6 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
SEFOS PIMv6 Overview
Supported Features
Protocol Description
Default Settings
Topology Example
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure PIMv6 in Router A
Configure PIMv6 in Router B
Global Configurations
Enable PIMv6
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configure the PMBR Status
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the LAN Delay
Configure the LAN Prune Delay
Configure the BSR Candidate
Configure the Message Interval
Configuring the PIMv6 Component
Create a PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
Configure the RP Static Address
Create an RP-Set Table
Create a PIMv6 Neighbor
Create Multicast Routes
  1. In router A, associate the VLAN 7 interface with PIMv6 component 1.
    SEFOS(config)# interface vlan 7
    SEFOS(config-if)# ipv6 pim componentId 1
    SEFOS(config-if)# exit
  2. Enter PIMv6 component mode for component 1.
    SEFOS(config)# ip pim component 1
  3. Set the RP-candidate hold time to 30 seconds for PIMv6 component 1.
    SEFOS(pim-comp)# rp-candidate holdtime 30
  4. Set the RP-candidate RP address (7777::11) for the group (ff02::e001:1) with a mask length of 128 in PIMv6 component 1.
    SEFOS(pim-comp)# ipv6 pim rp-candidate rp-address ff02::e001:1 128 7777::11
    SEFOS(pim-comp)# exit
  5. Enter the interface configuration mode for VLAN 7.
    SEFOS# configure terminal
    SEFOS(config-if)# shutdown
  6. Set the BSR-candidate preference to 20 for the VLAN 7 interface.
    SEFOS(config-if)# ipv6 pim bsr-candidate 20
  7. In router B, associate the VLAN 7 interface with PIMv6 component 1.
  8. Enter PIMv6 component mode for component 1.
  9. Set the RP-candidate hold time to 30 seconds for PIMv6 component 1.
    SEFOS(pim-comp)# end
  10. Set the RP-candidate address (7777::11) for the group (ff02::e001:1) with a mask length of 128 in PIMv6 component 1.
    SEFOS(pim-comp)# ipv6 pim rp-candidate rp-address ff02::e001:1 128 7777::21
  11. In router A, review the RP-set table.
    SEFOS# show ipv6 pim rp-set
    PIM Group-to-RP mappings
    Group Address : ff02::e001:1Group Mask : 128
      RP: 7777::11
      Component-Id : 1
        Hold Time : 100, Expiry Time : 00:01:17
      RP: 7777::21
      Component-Id : 1
        Hold Time : 110, Expiry Time : 00:01:37
  12. In router B, review the RP-set table.
    SEFOS# show ipv6 pim rp-set 7777::11
        RP: 7777::11
        Component-Id : 1
        Hold Time : 30, Expiry Time : 00:01:08
