Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
VRRP Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring VRRP
Introduction
VRRP Topology
Configuration Guidelines
Default Configuration Values
Create VRRP Instance Over an Interface
Configure Additional Associated IP Addresses to a VRRP Instance
Configure VRRP Priority
Enable Preempt Mode
Configure Authentication Password for VRRP Tickets
Configure VRRP Advertisement Interval
Configure VRRP (Linux Example)
See the first figure in VRRP Topology for the topology in this example. You can configure VRRP text authentication to authenticate VRRP packets. An advertisement packet will get discarded if the authentication key in the packet does not match with the locally configured value.
  1. In switch 1 and in switch 2, configure the authentication password or key as text1.
    SEFOS# configure terminal
    SEFOS(config)# router vrrp
    SEFOS(config-vrrp)# interface vlan 2
    SEFOS(config-vrrp-if)# vrrp 1 text-authentication text1
    SEFOS(config-vrrp-if)# end
  2. View the authentication key configured in switch 1.
    SEFOS# show vrrp interface vlan 2 detail
    vlan2  - vrID 1
    State is Master
    Virtual IP address is 12.0.0.5
    Virtual MAC address is 00:00:5e:00:01:01
    Master router is 12.0.0.5
    Associated IpAddresses :
    12.0.0.5
    12.0.0.6
    Advertise time is 1 secs
    Current priority is 200
    Configured priority is 200, may preempt
    Configured Authentication
    Authentication key is text1
    Accept Mode Disabled
  3. View the authentication key configured in switch 2.
    vlan2  - vrID 1
    State is Backup
    12.0.0.5
    12.0.0.6
    Current priority is 150
    Configured priority is 150, may preempt
