Register a resource type
Upgrade a resource type
Downgrade a resource type
Create failover or scalable resource
groups
Add logical hostnames or shared addresses
and data service resources to resource
groups
Enable resources and resource monitors,
manage the resource group, and bring the resource
group and its associated resources online
Quiesce a resource group
Suspend and resume automatic recovery
actions of a resource group
Disable and enable resource monitors
independent of the resource
Remove resource types from the
cluster
Remove resource groups from the
cluster
Remove resources from resource groups
Switch the primary for a resource
group
Disable resources and move their resource
group into the UNMANAGED
state
Display resource type, resource group, and
resource configuration information
Change resource type, resource group, and
resource properties
Clear error flags for failed Resource Group Manager
(RGM) processes
Clear the Start_failed
resource state
Reregister the built-in resource types
LogicalHostname and
SharedAddress
Update the network interface ID list for the
network resources, and update the node list for
the resource group
Remove a node from a resource group
Set up HAStoragePlus for
resource groups to synchronize the startups
between those resource groups and device
groups
Set up the HAStoragePlus
to make a local Solaris ZFS highly
available
Modify online the resource for a highly
available local file system
Change the cluster file system to local file
system in an HAStoragePlus
resource
Upgrade the built-in resource types
LogicalHostname and
SharedAddress
Upgrade the HAStoragePlus resource
type
Distribute online resource groups among
cluster nodes
Distribute resource-group load across
cluster nodes
Enable Solaris SMF services to run with
Oracle Solaris Cluster
Tune fault monitors for Oracle Solaris Cluster data
services
