Safety and Compliance Information
Understanding Configuration Details
PCIe Physical Slot Assignments
Shipping Kit With Single-Unit CMA Comb (Part No. 7069640)
Shipping Kit With Multi-Piece CMA (Part No. 350-1662-02)
Rackmount Kit With Single-Piece CMA Comb (Part No. 7069640)
Rackmount Kit With Multi-Piece CMA (Part No. 350-1662-02)
Determine Correct Rackmount Hardware
Mark the Rackmounting Location
Install the Rackmount Hardware
CMA Kit (Single-Piece CMA Comb, Part No. 7069793)
Install the Single-Piece CMA Comb
CMA Kit (Multi-piece CMA, Part No. 7041990)
Installing the Shipping Brace Assembly
Determine Correct Shipping Brace Fasteners
Install the Bottom Rear Shipping Brace
Remove the Bottom Rear Shipping Brace
Connecting Data and Management Cables
Powering On the Server for the First Time
Connect a Terminal or Emulator to the SER MGT Port
Power on the System for the First Time
Reach a State to Install a Fresh OS (Oracle ILOM CLI)
Reach a State to Install a Fresh OS (Oracle ILOM Web Interface)
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Log In to the SP (SER MGT Port)
Assign a Static IP Address to the NET MGT Port
Accessing the Server Using Oracle ILOM
Display the Oracle ILOM Prompt
Installing Auto Service Request Software
Software Requirements (ASR Manager)
Minimum Software Requirements (Oracle Exalytics In-Memory Machine T5-8 Server)
Installing ASR Manager Components
Install the Oracle Automated Service Manager Package
Install Service Tools Bundle for Oracle Solaris Only
Install the Oracle Auto Service Request Package
Configure ASR on the Server (Oracle ILOM)
Configuring ASR on the Server (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Server With Oracle Solaris 11 to ASR Manager
Approve and Verify ASR Activation
Advantages to Maintaining Multiple Boot Environments
Mount to a Different Build Environment
Reboot to the Original Boot Environment
When you first install the Oracle Solaris OS on a system, a boot environment is created. You can use the beadm (1M) utility to create and administer additional boot environments on your system.
After your system is installed, you should create a backup of the original boot environment. If needed, you can then boot to the backup of the original boot environment.
For more information about Oracle Solaris 11 boot environments, refer to:
http://docs.oracle.com/cd/E23824_01/html/E21801/toc.html
These topics describe how to manage the Oracle Solaris 11 boot environments.
