Skip Navigation Links
Exit Print View
Oracle Exalytics In-Memory Machine T5-8
Owner's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Understanding the Server
Hardware Components
Safety and Compliance Information
Understanding Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Airflow Precautions
Understanding Configuration Details
Supported Configurations
CPU/Memory Allocations
PCIe Physical Slot Assignments
Preparing for Installation
Shipping Kit With Single-Unit CMA Comb (Part No. 7069640)
Shipping Kit With Multi-Piece CMA (Part No. 350-1662-02)
Handling Precautions
ESD Precautions
Tools Needed for Installation
Prepare the Server
Installing the Server
Rack Compatibility
Rack Cautions
Stabilize the Rack
Rackmount Kit With Single-Piece CMA Comb (Part No. 7069640)
Rackmount Kit With Multi-Piece CMA (Part No. 350-1662-02)
Determine Correct Rackmount Hardware
Mark the Rackmounting Location
Install the Rackmount Hardware
Installing the CMA
CMA Kit (Single-Piece CMA Comb, Part No. 7069793)
Install the Single-Piece CMA Comb
CMA Kit (Multi-piece CMA, Part No. 7041990)
Install the Multi-Piece CMA
Installing the Shipping Brace Assembly
Determine Correct Shipping Brace Fasteners
Install the Top Rear Braces
Install the Bottom Rear Shipping Brace
Remove the Bottom Rear Shipping Brace
Install the Server
Connecting the Server Cables
Cabling Requirements
Front Panel Components
Rear Panel Components
Connecting Data and Management Cables
Connect the SER MGT Cable
Connect the NET MGT Cable
Connect the Ethernet Network Cables
Connect the Fiber Channel Card Cables
Secure Cables Using the CMA
Powering On the Server for the First Time
Prepare the Power Cords
Connect a Terminal or Emulator to the SER MGT Port
Power on the System for the First Time
Oracle ILOM System Console
Installing the OS
Configure the Preinstalled OS
Reach a State to Install a Fresh OS (Oracle ILOM CLI)
Reach a State to Install a Fresh OS (Oracle ILOM Web Interface)
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Log In to the SP (SER MGT Port)
Assign a Static IP Address to the NET MGT Port
Accessing the Server Using Oracle ILOM
Oracle ILOM Overview
Log In to Oracle ILOM
Display the Oracle ILOM Prompt
Oracle ILOM Remote Console
Installing Auto Service Request Software
ASR Overview
Preparing to Configure ASR
Prepare the ASR Environment
Software Requirements (ASR Manager)
Minimum Software Requirements (Oracle Exalytics In-Memory Machine T5-8 Server)
Installing ASR Manager Components
Install the Oracle Automated Service Manager Package
Install Service Tools Bundle for Oracle Solaris Only
Install the Oracle Auto Service Request Package
Register ASR Manager
Verify ASR Manager
Configure ASR on the Server (Oracle ILOM)
Configuring ASR on the Server (Oracle Solaris 11)
Enable the HTTP Receiver on the ASR Manager
Enable HTTPS on ASR Manager (Optional)
Register Server With Oracle Solaris 11 to ASR Manager
Approve and Verify ASR Activation
Managing Oracle Solaris 11 Boot Environments
Advantages to Maintaining Multiple Boot Environments
Create a Boot Environment
Mount to a Different Build Environment
Reboot to the Original Boot Environment
Remove Unwanted Boot Environments
Index
Use the CMA to secure cables and ensure proper cable routing.
  1. Remove the CMA cover.
    The CMA cover is secured with two No. 2 Phillips screws.
    image:Illustration showing how to use the CMA comb.
  2. Place the system cables into the appropriate slots in the CMA.
    See Connecting the Server Cables.
  3. Install the CMA cover.
    Secure the cover using two No. 2 Phillips screws.
