Skip Navigation Links | |
Exit Print View | |
Sun Storage Common Array Manager Software Release Notes, Release 6.10 for Solaris OS Hosts |
1. CAM 6.10 Release Notes for Solaris OS
Controller and Disk Firmware Updates
Clearing Controller Recovery Mode
What You Get With the Software
Mixing Drive Speeds and Capacities
Supported Host Operating Systems
Best Practices for Browser Performance
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
Sun Storage F5100 Flash Array Notes
Controller Smart battery replacement procedure
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Reboots occur due to ancient I/O being aborted in large configurations
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Following is a list of the notable bug fixes delivered with CAM 6.10.
Bug 17642288 - Apache Tomcat delivered with CAM on Solaris has vulnerabilities
Bug 17582092 - Incorrect "Synchronization progress" reported by CAM for the replication set
Bug 17229956 - Controller's date/time is not right when an exmoor controller A is offline or has failed
Bug 17056859 - CAM6.9 Service Advisor for battery replacement of 25x0M2 showed wrong controller status
Bug 16741284 - CAM6.9.0.20: sscs list vdisk does not show Array Type with 2540M2 fw 07.84.44.10
Bug 16564120 - Implement cancelDatabaseRecoveryMode through service advisor
Bug 16528660 - WebConsole runs out of Java heap: memory leak suspected
Bug 16296860 - "sscs list -a arrayname fcport" not working if one FC cable removed using inband
Bug 16241824 - Windows CAM platform patch 147417-02 causes ASR configuration failure
Bug 16235089 - Implementation of "REC_DATABASE_RECOVERY_MODE" in CAM events
Bug 16095442 - "service -c initialize -t dacstore" not working with firmware 07.84Bug 16092250 - Sun Storage 2500-M2 array unusable after "Upgrade Firmware Baseline" without the mandatory CAM 6.9 patches
Bug 16036605 - Update Service Advisor to notify customers to deactivate in MOS for maintenance
Bug 15940671 - Unable to change the array password with CAM 6.9
Bug 15815348 - Upgrade Java to 1.6.0.71 to resolve Java security issues.
Bug 15802892 - Cannot create Replication Sets in CAM 6.9 BUI
