Go to main content
SPARC M8 and SPARC M7 Servers Security Guide
Exit Print View
Updated: September 2017
Understanding Hardware Security
Physical isolation and access control are the foundation on which you should build the security architecture. Ensuring that the physical server is installed in a secure environment protects the server against unauthorized access. Likewise, recording all serial numbers helps prevent the use of unauthorized hardware components.
These sections provide general hardware security guidelines for the servers.
