Go to main content
Oracle® Solaris Cluster 4.3 Software Installation Guide
Exit Print View
Updated: June 2019
Configuring Solaris Volume Manager Software
The following table lists the tasks that you perform to configure Solaris Volume Manager software for Oracle Solaris Cluster configurations. Complete the procedures in the order that is indicated.
Table 6  Task Map: Configuring Solaris Volume Manager Software
Task
Instructions
Plan the layout of your Solaris Volume Manager configuration.
Install the Solaris Volume Manager software.
Create state database replicas on the local disks.
