PeopleSoft Interaction Hub (Portal Solutions)
Online Help for PeopleSoft Interaction Hub 9.1 (through Update Image 17)
Online Help and PeopleBooks
Set Up Hosted Context-Sensitive Help
Set up your PeopleSoft applications to use this site for context-sensitive help. The hosted PeopleSoft Online Help can search multiple product families and releases and return context-sensitive help from all available resources.
Note: If clicking a Help link on a PeopleSoft application page brought you to this page instead of to actual PeopleSoft online help content, it is likely that your PeopleSoft system is configured to access an older version of online help that is no longer available. You can access a current help library from this page and then search by the application page name. If you are a PeopleSoft system administrator, you can configure context-sensitive help to always display help for the latest application image or PeopleTools patch, so you'll never have to update your help configuration again.
Install the Online Help Locally
If your organization has firewall restrictions that prevent you from using the hosted online help, you can install the help locally.
Notices
You can access the latest version of all PeopleSoft documentation on this page. If you use links to older versions of the documentation that are no longer available, you'll be redirected to the latest version of the documentation or to this page.
The Hosted Online Help and PeopleBook PDFs are updated with every PeopleSoft Update Image. The locally installable Online Help is updated and made available with the first PeopleSoft Update Image of each calendar year.
Find regularly-posted announcements about new certifications, end-of-support or third-party retirement notices, and other platform-related information in Tech Updates.
Install and Upgrade
- Installation: PeopleSoft Portal Solutions 9.1 (through Update Image 17)
- Hardware and Software Requirements: PeopleSoft Portal Solutions 9.1 (through Update Image 17)
- PeopleSoft 9.2 Application Installation for Db2 for z/OS (PeopleSoft PeopleTools 8.60)
- PeopleSoft 9.2 Application Installation for Microsoft SQL Server (PeopleSoft PeopleTools 8.60)
- PeopleSoft 9.2 Application Installation for Oracle (PeopleSoft PeopleTools 8.60)
- PeopleSoft Deployment Packages for Update Images Installation (PeopleSoft PeopleTools 8.60)
- Understanding PeopleSoft Deployment Packages for Update Images
- Getting Started on Your PeopleSoft Application Upgrade
- Upgrade: Portal Solutions 9.0 to 9.1 Revision 3
Other Documentation
Tutorials
PeopleSoft Information Portal
Start here to find all of the latest resources for Oracle's PeopleSoft products, features, customers, and more.
The PeopleSoft Information Portal provides everything you need to know about PeopleSoft in one place.
