Go to main content
Oracle® SuperCluster M8 and SuperCluster M7 Security Guide
Exit Print View
Updated: June 2020
Disable the SSLv3 Protocol for HTTPS
By default, the SSLv3 protocol is enabled for the HTTPS service.
For security purposes, disable the SSLv3 protocol.
  1. On the management network, log into Oracle ILOM.
    See Log in to the Oracle ILOM CLI.
  2. Determine if the SSLv3 protocol is disabled for the HTTP service.
    -> show /SP/services/https sslv3
    /SP/services/https
    Properties:
    sslv3 = enabled
  3. Disable the SSLv3 protocol.
    -> set /SP/services/https sslv3=disabled
  4. Verify the setting by repeating Step 2.
