Siebel Security Guide > Communications and Data Encryption >
Implementing Siebel Strong Encryption
Siebel Strong Encryption is installed during the Siebel Enterprise and Siebel Web Server installations. However, there are various tasks you must perform to use Siebel Strong Encryption. This topic describes these tasks. For an overview of Siebel Strong Encryption, see About Siebel Strong Encryption. NOTE: Siebel Strong Encryption is only available in U.S. English (enu); however, it can be implemented in a Siebel environment that uses other languages.
Requirements for Implementing Siebel Strong Encryption
Before implementing Siebel Strong Encryption, carry out the following tasks:
To implement Siebel Strong Encryption, perform the steps in the following procedure. To implement Siebel Strong Encryption
- Verify that you have completed the tasks listed in Requirements for Implementing Siebel Strong Encryption.
- Navigate to one of the following directories to locate the SSE files:
- To implement Siebel Strong Encryption on the Siebel Web Server Extension (SWSE), navigate to the following directory:
- To implement Siebel Strong Encryption on the Siebel Server or Gateway Name Server, navigate to the following directory:
- To increase the certificate key sizes supported for SISNAPI communications, see Increasing the Certificate Key Sizes Supported For SISNAPI Communications.
- To increase the key length used for data encryption, copy the files as indicated:
- Windows. Depending on the key length you want to use, copy either sslcrsa128.dll or sslcrsa
256 .dl to the SIEBEL_ROOT\ siebsrvr\BIN, SIEBEL_ROOT\ gtwysrvr\BIN, or SWEAPP_ROOT\ BIN directory.
- UNIX. Depending on the key length you want to use, copy either libsslcrsa128.so or libsslcrsa256.so to the directory SIEBEL_ROOT
/siebsrvr/LIB , or to SIEBEL_ROOT/gtwysrvr / LIB , or to SWEAPP_ROOT/BIN.
- Upgrade the key database file to use the level of data encryption you chose in Step 4 by running the keydbupgrade.exe utility.
For information on this task, see Increasing the Encryption Level.
