For detailed instructions, refer to Install Software and Firmware Updates in Oracle X5 Series Servers Administration Guide or to Install Software and Firmware Updates in Oracle X6 Series Servers Administration Guide.
Always refer to the update README file(s) for requirements and installation instructions.
load -source protocol:// username-password@node-IP/path-to-image/image.pkg
where protocol is http, https, ftp, tftp, sftp, or scp.
where username-password@node-IP is the user's name and password with the node's ILOM IP address.
where path-to-image is the directory path.
where image.pkg is the name of the package being installed.
For example, load -source tftp://10.10.0.215/fw x5_2_ncn-rom.3.2.6.28.r110588.pkg
Refer to the following for firmware update instructions:
http://docs.oracle.com/cd/E37444_01/html/E37446/z400371a1482689.html#ILMCMz400371a1482689
Refer to the Netra Modular System Installation Guide and to the OS documentation.
