Oracle® EDR InfiniBand Switch and Virtualized I/O Systems Hardware Security Guide
Exit Print View
Updated: September 2016
Data Protection
Follow these guidelines to maximize data security:
  • Backup switch configuration files to remote, secure locations and limit their access to authorized administrators only. The configuration files should contain descriptive comments for each setting.
  • Use data encryption software to keep confidential information on hard drives secure.
  • The SP, SCP, and SSD are switch components that contain data equivalent to a system hard drive. When replacing a switch, physically destroy these components or completely erase all the data in the respective filesystems. Use disk wiping software to completely erase all data on the filesystem.
