3.1.6 Transforming Data
In preparing data for analysis, a typical step is to transform data by reformatting it or deriving new columns and adding them to the data set. The examples in this topic demonstrate two ways of formatting data and deriving columns. Example 3-7 creates a function to format the data in a column and Example 3-8 does the same thing by using the transform function. Example 3-9 uses the transform function to add columns to the data set.
Example 3-8 does the same thing as Example 3-7 except that it uses the transform function to reformat the data in a column of the data set.
Example 3-9 uses the transform function to add a derived column to the data set and then to add additional columns to it.
See Also:
The derived.R example script
Example 3-7 Formatting Data
# Create a function for formatting data.
petalCategory_fmt <- function(x) {
    ifelse(x > 5, 'LONG',
    ifelse(x > 2, 'MEDIUM', 'SMALL'))
# Create an ore.frame in database memory with the iris data set.
iris_of <- ore.push(iris)
# Select some rows from iris_of.
iris_of[c(10, 20, 60, 80, 110, 140),]
# Format the data in Petal.Length column.
iris_of$Petal.Length <- petalCategory_fmt(iris_of$Petal.Length)
# Select the same rows from iris_of.
Listing for Example 3-7
R> # Create a function for formatting data.
R> petalCategory_fmt <- function(x) {
+    ifelse(x > 5, 'LONG',
+    ifelse(x > 2, 'MEDIUM', 'SMALL'))
R> # Create an ore.frame in database memory with the iris data set.
R> iris_of <- ore.push(iris)
R> # Select some rows from iris_of.
R> iris_of[c(10, 20, 60, 80, 110, 140),]
    Sepal.Length Sepal.Width Petal.Length Petal.Width    Species
10           4.9         3.1          1.5         0.1     setosa
20           5.1         3.8          1.5         0.3     setosa
60           5.2         2.7          3.9         1.4 versicolor
80           5.7         2.6          3.5         1.0 versicolor
110          7.2         3.6          6.1         2.5  virginica
140          6.9         3.1          5.4         2.1  virginica
R> # Format the data in Petal.Length column.
R> iris_of$Petal.Length <- petalCategory_fmt(iris_of$Petal.Length)
R> # Select the same rows from iris_of.
10           4.9         3.1        SMALL         0.1     setosa
20           5.1         3.8        SMALL         0.3     setosa
60           5.2         2.7       MEDIUM         1.4 versicolor
80           5.7         2.6       MEDIUM         1.0 versicolor
110          7.2         3.6         LONG         2.5  virginica
140          6.9         3.1         LONG         2.1  virginica
Example 3-8 Using the transform Function
iris_of2 <- ore.push(iris)
iris_of2[c(10, 20, 60, 80, 110, 140),]
iris_of2 <- transform(iris_of2,
                  Petal.Length = ifelse(Petal.Length > 5, 'LONG',
                                 ifelse(Petal.Length > 2, 'MEDIUM', 'SMALL')))
Listing for Example 3-8
R> iris_of2 <- ore.push(iris)
R> iris_of2[c(10, 20, 60, 80, 110, 140),]
R> iris_of2 <- transform(iris_of2,
+                  Petal.Length = ifelse(Petal.Length > 5, 'LONG',
+                                 ifelse(Petal.Length > 2, 'MEDIUM', 'SMALL')))
Example 3-9 Adding Derived Columns
# Set the page width.
options(width = 80)
names(iris_of)
# Add one column derived from another
iris_of <- transform(iris_of, LOG_PL = log(Petal.Length))
names(iris_of)
head(iris_of, 3)
# Add more columns.
                    SEPALBINS = ifelse(Sepal.Length < 6.0, "A", "B"),
                    PRODUCTCOLUMN = Petal.Length * Petal.Width,
                    CONSTANTCOLUMN = 10)
names(iris_of)
# Select some rows of iris_of.
Listing for Example 3-9
R> # Set the page width.
R> options(width = 80)
R> names(iris_of)
[1] "Sepal.Length" "Sepal.Width"  "Petal.Length" "Petal.Width"  "Species"
R> # Add one column derived from another
R> iris_of <- transform(iris_of, LOG_PL = log(Petal.Length))
R> names(iris_of)
[6] "LOG_PL"
R> head(iris_of, 3)
  Sepal.Length Sepal.Width Petal.Length Petal.Width Species    LOG_PL
1          5.1         3.5          1.4         0.2  setosa 0.3364722
2          4.9         3.0          1.4         0.2  setosa 0.3364722
3          4.7         3.2          1.3         0.2  setosa 0.2623643
R> # Add more columns.
R> names(iris_of)
[5] "Species"        "LOG_PL"         "CONSTANTCOLUMN" "SEPALBINS"
[9] "PRODUCTCOLUMN"
R> # Select some rows of iris_of.
10           4.9         3.1          1.5         0.1     setosa 0.4054651
20           5.1         3.8          1.5         0.3     setosa 0.4054651
60           5.2         2.7          3.9         1.4 versicolor 1.3609766
80           5.7         2.6          3.5         1.0 versicolor 1.2527630
110          7.2         3.6          6.1         2.5  virginica 1.8082888
140          6.9         3.1          5.4         2.1  virginica 1.6863990
    CONSTANTCOLUMN SEPALBINS PRODUCTCOLUMN
10              10         A          0.15
20              10         A          0.45
60              10         A          5.46
80              10         A          3.50
110             10         B         15.25
140             10         B         11.34
