The Reporting and Analytics interface is where you can manually sync information from Inventory Management to the Reporting and Analytics reporting application. You can sync menu item costs, inventory totals, and menu definitions. This page is available for support reasons only. Daily exports must be scheduled using the Scheduler.
Do not use this page if exports have already been carried out for the previous date. It is not possible to send totals for the current day. If you try to send current day info or a day that has already been exported, you get an error. This module is primarily for Oracle Hospitality in the event that scheduled exports do not run.
