12 Discovering and Monitoring Oracle Business Intelligence Instance and Oracle Essbase
Oracle Business Intelligence (Oracle BI), a part of Oracle Business Analytics, is a combination of technology and applications that provide a range of business intelligence capabilities, such as enterprise performance management, financial performance management, data integration, data warehousing, as well as a number of query, reporting, analysis, and alerting tools.
You can use Enterprise Manager Cloud Control 13c to monitor certain Oracle Business Intelligence targets. Monitoring the status, performance, and health of Oracle Business Intelligence targets enables you to set up a more efficient business intelligence system.
By monitoring a target using Enterprise Manager, you obtain a complete and up to date overview of the status, availability, performance, and health of the target. Enterprise Manager displays complex target performance data in a simple form, using graphs and pie charts. It also keeps you informed about target metrics crossing their threshold levels, target alerts, and target incidents that require user action.
This chapter explains how to monitor Oracle BI Instance and Oracle Essbase targets in Enterprise Manager Cloud Control 13c. It consists of the following sections:
Overview of Oracle Business Intelligence Targets You Can Monitor
This section gives an overview of the Oracle Business Intelligence targets you can monitor using Enterprise Manager Cloud Control 13c Release 1 or higher. It contains the following:
Oracle Business Intelligence Instance (BI Instance) is a logical grouping of Business Intelligence components that can be configured as a unit to deliver a single integrated business intelligence capability. Every BI Instance target is part of a WebLogic domain. For information on WebLogic domains, refer to Oracle Fusion Middleware Creating Domains Using the Configuration Wizard.
A BI Instance target consists of a number of components, which can be monitored individually using Enterprise Manager. Table 12-1 describes these components.
Table 12-1 Oracle Business Intelligence Instance Components
Component Description
BI Server
This component provides query and data access capabilities for Oracle Business Intelligence, and provides services for accessing and managing the enterprise semantic model.
BI Presentation Server
This component provides the framework and interface for the presentation of Oracle Business Intelligence data to web clients. It maintains an Oracle BI Presentation Catalog service on the file system for customizing this presentation framework.
BI Cluster Controller
This component manages Oracle Business Intelligence Server (BI Server) clusters. It also manages the active-passive clustering of the Oracle Business Intelligence Scheduler (BI Scheduler) components.
BI Scheduler
This component provides extensible scheduling for analyses to be delivered to users at specified times.
BI Java Host
This component provides component services that enable Oracle BI Presentation Services to support various components such as Java tasks for Oracle BI Scheduler, Oracle BI Publisher, and graph generation. It also enables Oracle BI Server query access to Hyperion Financial Management and Oracle Online Analytical Processing (OLAP) data sources.
Oracle Essbase
Oracle Essbaseis a multidimensional database management system that provides business performance management solutions for meeting the complex calculation requirements of analysts across an enterprise.
Oracle Essbase consists of an Online Analytical Processing (OLAP) server that provides an environment for deploying pre-packaged applications and developing custom analytic and performance management applications. Every Essbase target is part of a WebLogic domain. For information on WebLogic domains, refer to Oracle Fusion Middleware Creating Domains Using the Configuration Wizard.
Using Enterprise Manager, you can monitor the Essbase server and every deployed Essbase application individually.
Understanding the Monitoring Process
To monitor Oracle Business Intelligence Instance (BI Instance) and Oracle Essbase targets, follow these steps:
  1. Install Oracle Business Intelligence.
    For information on how to install Oracle Business Intelligence, refer to Oracle Fusion Middleware Installation Guide for Oracle Business Intelligence.
  2. Install the Enterprise Manager Cloud Control 13c Release 1 system, or higher. If you are using an earlier version of Enterprise Manager Cloud Control, upgrade it to 13c Release 1 or higher.
    For information on how to install the Enterprise Manager Cloud Control 13c system, refer to Oracle Enterprise Manager Cloud Control Basic Installation Guide.
    For information on how to upgrade to Enterprise Manager Cloud Control 13c Release 1 or higher, refer to Oracle Enterprise Manager Cloud Control Upgrade Guide.
    Oracle recommends that you install the Enterprise Manager Cloud Control system on a different host, other than the one on which you have installed Oracle Business Intelligence.
  3. If the host on which you installed Oracle Business Intelligence does not have Oracle Management Agent (Management Agent) installed, install a Management Agent of version 12.1.0.2.0 or higher. If the host has a Management Agent of version earlier than 12.1.0.2.0 installed, upgrade the Management Agent to 12.1.0.2.0 or higher.
    For information on how to install a Management Agent, refer to Oracle Enterprise Manager Cloud Control Basic Installation Guide.
    For information on how to upgrade a Management Agent, refer to Oracle Enterprise Manager Cloud Control Upgrade Guide.
  4. If the Management Agent on the host on which you installed Oracle Business Intelligence does not have the Enterprise Manager for Oracle Fusion Middleware plug-in installed, deploy the 12.1.0.3.0 version, or a higher version of this plug-in on the host. If an earlier version of this plug-in is deployed to the Management Agent on the host, upgrade it to 12.1.0.3.0 or higher.
    The 12.1.0.3.0 Enterprise Manager for Oracle Fusion Middleware plug-in is downloaded by default to the OMS host when you install a 12.1.0.2.0 OMS. The 12.1.0.4.0 Enterprise Manager for Oracle Fusion Middleware plug-in is downloaded by default to the OMS host when you install a 12.1.0.3.0 OMS.
    For information on how to deploy a plug-in and upgrade an existing plug-in, refer to the Using Plug-Ins chapter of the Oracle Enterprise Manager Cloud Control Administrator's Guide.
  5. Discover the required BI Instance and Essbase targets.
    BI Instance and Essbase targets are automatically discovered when you discover the WebLogic domain that they are part of.
    The BI Instance and Essbase targets you want to monitor may be part of an undiscovered WebLogic domain, or a previously discovered WebLogic domain.
    For information on how to discover BI Instance and Essbase targets part of an undiscovered WebLogic domain, see Discovering Targets of an Undiscovered WebLogic Domain.
    For information on how to discover BI Instance and Essbase targets part of a previously discovered WebLogic domain, see Discovering New or Modified Targets of a Discovered WebLogic Domain.
  6. Monitor the BI Instance and Essbase targets.
    For information on how to monitor BI Instance and Essbase targets, see Monitoring Oracle Business Intelligence Instance and Essbase Targets.
Discovering Oracle Business Intelligence Instance and Oracle Essbase Targets
Oracle Business Intelligence Instance (BI Instance) and Oracle Essbase targets you want to discover may be part of an undiscovered WebLogic domain, or a discovered WebLogic domain.
This section contains the following:
This section is applicable only for Oracle Business Intelligence Enterprise Edition 11g targets.
To discover BI Instance and Essbase targets that are part of an undiscovered WebLogic domain, first discover the WebLogic domain that the targets are part of. To do so, either enable the automatic discovery of WebLogic domains, or discover the required WebLogic domains manually. After discovering the WebLogic domains, you must promote the targets and assign Management Agents to monitor them.
Discovery is supported for 11g and 12c Oracle Business Intelligence Enterprise Edition targets only.
The following sections explain how to perform these actions. For additional information about Fusion Middleware discovery, see Oracle Enterprise Manager Cloud Control Administrator's Guide.
Enabling Automatic Discovery of Targets
Using this method, you enable the automatic discovery of Fusion Middleware targets to automatically discover the various WebLogic domains in the enterprise. Also, you promote the BI Instance and Essbase targets part of the WebLogic domains, and assign Management Agents to monitor these targets.
Auto-discovery only discovers the domains which are not visible under the Middleware tab, for monitoring. To make a domain visible, it should first be promoted to Enterprise Manager. You can promote a domain by using the Autodiscovery page.
Discovering Targets Manually
Using this method, you manually discover WebLogic domains. Also, you promote the BI Instance and Essbase targets part of the WebLogic domains, and assign Management Agents to monitor these targets.
In a typical enterprise, WebLogic domains are not static. New or modified domain members, such as BI Instance and Essbase targets, may be added to a discovered WebLogic domain at any point of time. Either enable the automatic discovery of these added targets, or discover them manually. After discovering these targets, you must promote the targets and assign Management Agents to monitor them.
Using this method, you enable the automatic discovery of new or modified WebLogic domain member targets, such as BI Instance and Essbase targets. Also, you promote the new or modified domain member targets, and assign Management Agents to monitor them.
Using this method, you manually check a WebLogic domain for new members, such as BI Instance and Essbase targets, and discover them. Also, you promote the new or modified domain member targets, and assign Management Agents to monitor them.
To monitor Oracle Business Intelligence Instance (BI Instance) and Essbase targets, navigate to the home page of the required target.
To navigate to the home page of a BI Instance or Essbase target, follow these steps:
  1. From the Targets menu, select Middleware.
  2. From the navigation tree, select the Oracle Fusion Middleware farm having a BI Instance or Essbase Server target. Click the BI Instance or Essbase Server name.
  3. From the navigation tree in the Target Navigation window, click the name of the required target.
Using the target home page, you can perform a number of monitoring tasks. These tasks are described in this section, which contains the following:
This section is applicable only for Oracle Business Intelligence Enterprise Edition 11g and 12c targets.
Performing General Monitoring Tasks
This section explains how to perform general BI Instance and Essbase target monitoring tasks, such as viewing target status and availability, performance, health, alerts, incidents, and so on.
This section contains the following elements:
General
Performance
Health
Configuration, Jobs, and Compliance
Viewing Target General and Availability Summary
To view a general summary of the target details, navigate to the Summary section, by following these steps:
The Summary section provides background information about the target, which helps you locate the target binaries, log files, metadata files, and configuration files for viewing or editing purposes.
Table 12-2 describes the elements of the Summary section.
Table 12-2 Target General and Availability Summary
Element Description
Up Since
(Displayed only when the target is up) Time the target was last started successfully.
Down Since
(Displayed only when the target is down) Time the target was last stopped.
Availability
Percentage availability of the target.
Version
Version of the target software.
Oracle Home
Location of the target binaries.
Oracle Instance
Location of the target content files, metadata, configuration files and log files.
Port
Port used by the target for communication.
Running Applications
(Only for Essbase Server targets)
Number of Essbase applications currently up and running.
Unexposed Applications
Number of Essbase applications currently not being accessed by any user.
Connected Users
Number of users currently connected through one or more of the applications.
Storage Type
(Only for Essbase application targets)
Type of data storage used by the application.
Cubes
Number of cubes contained in the application.
Query Tracking
Whether or not query tracking, that is, tracking data combinations having a large number of data values that require aggregation, is enabled.
Memory Usage (MB)
Memory used by the application in MB.
Threads
Number of application threads.
Viewing Target Status and Availability History
To view the status and availability history of a target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select Status History.
Sometimes, due to network problems and system errors, the target might be down, or the Oracle Management Service (OMS) might not be able to reach the Management Agent that monitors the target. The Availability (Status History) page provides information about when, and for how long these situations occurred for a particular target. This information is essential for troubleshooting target related incidents.
The Availability (Status History) page consists of the Overall Availability, Downtime History, and General sections. The Overall Availability section consists of a pie chart depicting the availability of the target, from the time it was discovered. The Downtime History section provides detailed information about the periods when the target was down.
Table 12-3 describes the elements of the General section.
Table 12-3 Target Status and Availability History
Element Description
Current Status
Current status of the target, whether it is up and running, or down.
Up Since
Down Since
Availability (%)
Down Time (minutes)
Duration for which the target was down.
Blackout Time (minutes)
Total duration of blackouts set on the target.
Agent Down Time (minutes)
Duration for which the Oracle Management Agent monitoring the target was down.
System Error Time (minutes)
Duration for which the target could not be monitored, due to a system error.
Status Pending Time (minutes)
Duration for which the status of the target could not be determined.
Viewing Target Performance or Resource Usage
To view the performance or resource usage of a target, navigate to the Response or CPU and Memory Usage section, by following these steps:
  3. From the navigation tree in the Target Navigation window, click the name of the required target. Graphs depicting the target performance or target resource usage are displayed.
  4. (Optional) To view the performance or resource usage data in a tabular format, click Table View.
For the BI Instance, BI Server, and BI Presentation Server targets, you can view only performance data, and not resource usage data, on the target home page. For other BI Instance component targets and Essbase targets, you can view only resource usage data and not performance data on the target home page.
Target Performance
The Response and Load section displays the performance of the BI Instance, BI Server, or BI Presentation Server target. For these targets, the Response and Load section can consist of the following graphs:
  • The variation of Average Query Time with time
    Average Query Time is the average time the BI Server or BI Presentation Server takes to execute a query. The Average Query Time is collected and uploaded to the Oracle Management Repository every fifteen minutes, by default.
  • The variation of Server Queries (per second) with time
    Server Queries (per second) is the number of queries processed by the BI Server or BI Presentation Server in one second. Server Queries (per second) is collected and uploaded to the Oracle Management Repository every fifteen minutes, by default.
  • The variation of Completed Requests (per second) with time
    Completed Requests (per second) is the number of requests completed by the BI Presentation Server in one second. Completed Requests (per second) is collected and uploaded to the Oracle Management Repository every fifteen minutes, by default.
Carefully observing these graphs can sometimes provide early warnings about server overloading, reduced server access, and so on. Analyzing graphical data collected over a long period of time can help you set up a more efficient BI Server or BI Presentation Server.
For detailed information on target performance, access the Performance Summary page. To access this page, from the Business Intelligence Instance, BI Server or BI Presentation Services menu, select Monitoring, then select Performance Summary.
Target Resource Usage
The CPU and Memory Usage section displays the resource usage of the target. It consists of two graphs:
  • The variation of CPU Usage (%) with time
    CPU Usage specifies the percentage of CPU time used by the target. A large value of CPU Usage can cause the Business Intelligence components and applications to slow down, reducing their performance. The CPU Usage is collected and uploaded to the Oracle Management Repository every fifteen minutes by default.
  • The variation of Memory Usage (MB) with time
    Memory Usage specifies the amount of memory used by the target. A large value of Memory Usage can cause the Business Intelligence components and applications to slow down. The Memory Usage is collected and uploaded to the Oracle Management Repository every fifteen minutes by default.
Carefully observing these graphs can sometimes provide early warnings about application overloading, component downtime, and so on.
Viewing Target Metrics
To view all the metrics collected for a particular target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select All Metrics.
The All Metrics page displays details about all the metrics collected for a particular target. The average value, threshold values, collection schedule, and metric value history is displayed for each collected metric.
Viewing or Editing Target Metric and Collection Settings
To view and edit the metric and collection settings for a particular target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select Metric and Collection Settings.
  5. To edit the collection schedule or thresholds of a metric, or any other collected item, click the corresponding icon present in the Edit column.
The Metric and Collection Settings page provides details about target metric collection thresholds and target metric collection schedules. Using this page, administrators can edit the warning threshold and critical threshold values of target metrics and other collected items, as well as the time intervals at which these are collected.
Viewing Target Metric Collection Errors
To view the metric collection errors for a particular target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select Metric Collection Errors.
The Metric Collection Errors page provides details about the errors encountered while obtaining target metrics. These details give you an idea of the metrics that may not represent the performance of the target accurately, as errors were encountered while collecting them.
Viewing Target Health
To view a summary of the health of the target, navigate to the Monitoring and Diagnostics section, by following these steps:
The Monitoring and Diagnostics section specifies the number of abnormal occurrences related to the target that require user action, and the number of changes made to the target configuration, within a particular time interval. This information is useful to administrators who want to quickly get an idea of the overall health of the target, and know the number of issues that need to be resolved. For more details on target configuration, access Configuration from the BI Instance component menu or Essbase target menu.
Table 12-4 describes the elements of the Monitoring and Diagnostics section.
Table 12-4 Target Health
Element Description
Incidents
The number of unresolved situations or issues that impact the target negatively, and hence require user action. The displayed integer is also a link to the Incident Manager page.
Descendant Target Incidents
(Only for Essbase Server Targets)
The number of incidents related to Essbase applications. The displayed integer is also a link to the Incident Manager page.
Configuration Changes
The number of changes made to the target configuration in the last seven days. The displayed integer is also a link to the Configuration History page.
Viewing Target Alert History
To view the alert history of a particular target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select Alert History.
The Alert History page provides details about target metrics, such as the periods when a particular metric was beyond its critical threshold value, the periods when the metric could not be calculated, and so on. These details help you plan corrective measures for metric-related problems, before any severe damage or prolonged downtime can occur.
Table 12-5 describes the elements of the Alert History page.
Table 12-5 Target Alert History
Element Description
Metric
Parameter related to the performance of the target.
History
Condition of the metric at various times. The condition can have the values Critical, Warning, Clear, and No Data.
Viewing Target Incidents
To view the incidents related to the target, navigate to the Incidents section, by following these steps:
The Incidents section provides details about the various events, related to the target, that negatively impact the business intelligence system. These events require user action. The details provided by this section, such as the incident summary, severity, target, target type, and so on, are essential for troubleshooting.
For detailed reports on target incidents, access the Incident Manager page. To access this page, from the BI Instance component menu or Essbase target menu, select Monitoring, then select Incident Manager.
For details on the elements of the Incidents section, refer to Oracle Enterprise Manager Cloud Control Administrator's Guide.
Viewing Target Logs
To view the log messages related to a particular target, follow these steps:
  3. From the BI Instance component or Essbase target menu displayed on the target home page, select Logs, then select View Log Messages.
  4. (Optional) To view or download the target log files, click Target Log Files, select the required log file, then click View Log File or Download, respectively.
  5. (Optional) To export log messages to a file, from the Log Messages page, select the required messages. From the Export Messages to File menu, click the file format you want to export the selected messages to. Choose a location, and download the file.
The target logs are a repository of target error messages, warnings, and notifications. They can be used for tracing the intermediate steps of an operation, and are essential for troubleshooting incidents and problems.
You can use the Log Messages page to view all log messages, search for a particular message, view messages related to a message, export messages to a file, view the target log files, and download the log files. For more information about log files, refer to Oracle Enterprise Manager Cloud Control Administrator's Guide.
For the BI Instance target, this page displays log messages related to all system components and Java EE components. For the BI Instance component targets and Essbase targets, this page displays only those log messages that are related to the target.
Table 12-6 describes the elements of the Log Messages page.
Table 12-6 Target Log Messages
Element Description
Time
Date and time when the log message was created.
Message Type
Type of the log message. Message Type can be Incident Error, Error, Warning, Notification, Trace, or Unknown. These types represent the decreasing severity of messages, with Trace representing the least severe message and Incident Error representing the most severe message. Unknown indicates that Message Type is not known.
Message ID
9-digit string that uniquely identifies the message within the framework.
Message
Text of the log message.
Execution Context ID (ECID)
Global unique identifier of the execution of a particular request, in which a target component participates. You can use the ECID to correlate error messages from different target components.
Relationship ID
Identifier which distinguishes the work done by a particular thread on a particular process, from the work done by any other thread on the same, or any other process, on behalf of the same request.
Component
Target component that generated the message.
Module
Identifier of the module that generated the message.
Incident ID
Identifier of the incident to which the message corresponds.
Instance
Oracle Instance containing the target component that generated the message.
Message Group
Group containing the message.
Message Level
An integer value representing the severity of the message. Ranges from 1 (most severe) to 32 (least severe).
Hosting Client
Identifier of the client or security group related to the message.
Organization
Organization ID for the target component that generated the message. This ID is oracle for all Oracle components.
Host
Name of the host where the message was generated.
Host IP Address
Network address of the host where the message was generated.
User
User whose execution context generated the message.
Process ID
Identifier of the process or execution unit that generated the message.
Thread ID
Identifier of the thread that generated the message.
Upstream Component
Component that the message generating component works with, on the client side.
Downstream Component
Component that the message generating component works with, on the server side.
Detail Location
URL linking to additional information about the message.
Supplemental Detail
Detailed information about the message, more detailed than the message text.
Target Log Files
Link to the target log files.
Log File
Log file containing the message.
Viewing Target Configuration and Configuration File
To view the configuration data of a target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Configuration, then select Last Collected to access the Target Configuration browser.
  5. (Optional) To export target configuration data to a configuration file, click Export. The exported target configuration data is stored in a .xls file.
Use the Target Configuration browser to view the latest configuration data of the target. Using the browser, you can also search for configuration data, view saved target configurations, compare target configurations, and view the target configuration history.
Viewing Target Job Activity
To view the past, currently running, and scheduled jobs related to a target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Job Activity.
The Job Activity page displays target jobs related to target administrative tasks, such as starting the target, stopping the target, target blackouts, and so on.
Use the Job Activity page to search for a particular job and retrieve job details such as the owner, status, scheduled start time, and so on. You can also use the Job Activity page to perform target job administration tasks, such as creating, editing, suspending, and resuming a job.
Viewing Target Compliance
To view the compliance of a target to compliance standards or compliance frameworks, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Compliance, then select Results.
  5. To view the compliance results of a target with respect to a particular compliance standard, select Compliance Standards. To view the compliance results of a target with respect to a particular compliance framework, select Compliance Frameworks.
Use the Compliance Results page to view the compliance of a target to compliance standards and compliance frameworks. This page also lists the number of violations made to compliance standards and compliance frameworks, hence giving you an idea of whether the targets in your enterprise adhere to established standards or not.
For more information on target compliance, refer to Oracle Enterprise Manager Lifecycle Management Administrator's Guide.
Performing Target-Specific Monitoring Tasks
This section explains how you can perform target-specific BI Instance and Essbase target monitoring tasks, such as viewing BI Instance dashboard reports, BI Instance scheduler reports, Essbase application data storage details, and so on.
BI Instance
Essbase
Viewing Oracle Business Intelligence Dashboard Reports
To view Oracle Business Intelligence dashboard reports, follow these steps:
  2. From the navigation tree, select the Oracle Fusion Middleware farm having a BI Instance. Click the BI Instance name.
  3. From the Business Intelligence Instance menu, select Dashboard Reports.
  4. From the View list, select the set of dashboard reports you want to view.
To view Oracle Business Intelligence dashboard reports in Enterprise Manager Cloud Control, you must enable usage tracking. For information on how to enable usage tracking, refer to the Managing Usage Tracking chapter of the Oracle Fusion Middleware System Administrator's Guide for Oracle Business Intelligence Enterprise Edition.
Using this page, you can view the dashboard usage in the past 7 days, the dashboards that failed in the past 24 hours, the top dashboards by resource usage in the past 7 days, and the top users by resource usage in the past 7 days. These details tell you which dashboards are the most popular, which dashboards failed recently, which dashboards use the maximum resources, and which user is the most active. An in-depth analysis of these details can provide important insights into the functioning of an enterprise.
Without specifying the correct credentials on the Monitoring Credentials page, you cannot access certain dashboard reports. Hence, ensure that you specify the appropriate credentials on the Monitoring Credentials page, before accessing the Dashboard Reports page.
To access the Monitoring Credentials page, from the Business Intelligence Instance menu, select Target Setup, then select Monitoring Credentials.
You can also perform a SQL drill down of the dashboard by selecting Top Dashboards by Resource Usage in last 7 days, and then clicking the SQL details icon.
In order to do a SQL drill down, you need to discover the database from where the dashboards are fetching the data. To do this, from the Business Intelligence Instance menu, select Target setup, and then select Monitoring Credentials. Select the database which has been discovered and add it using the target selector icon.
Table 12-7 describes the elements of the Dashboard Reports page.
Table 12-7 Oracle Business Intelligence Dashboard Reports
Element Description
User
User who accessed the dashboard.
Total Sessions
Total number of user sessions which accessed the dashboard.
Last Accessed On
Time when the dashboard was last accessed.
Dashboard
Dashboard name.
Error Code
Dashboard error code.
Error Message
Dashboard error message.
Repository
Name of the repository accessed by the dashboard.
Subject Area
Information about business areas, or the groups of users in an organization.
Start Time
Time when the server received the logical request for the dashboard.
End Time
Time when the server completed servicing the logical request for the dashboard.
View Log Messages
View log messages related to the dashboard.
Total Time
Total time taken to service all logical requests made for a particular dashboard.
Note: In the Top Users by Resource Usage in Last 7 Days reports, this element represents the total time taken to service all logical requests made by a particular user.
Database Time
Time taken by the database to complete all physical requests made for a particular dashboard.
Note: In the Top Users by Resource Usage in Last 7 Days reports, this element represents the time taken by the database to complete all physical requests made by a particular user.
Compile Time
Time taken to convert all logical requests made for a particular dashboard.
Note: In the Top Users by Resource Usage in Last 7 Days reports, this element represents the time taken to convert all logical requests made by a particular user, to physical requests.
Failed Logical Requests
Number of logical requests made for the dashboard that failed.
Note: In the Top Users by Resource Usage in Last 7 Days reports, this element represents the number of logical requests made by a particular user that failed.
Total Logical Requests
Total number of logical requests made for the dashboard.
Note: In the Top Users by Resource Usage in Last 7 Days reports, this element represents the total number of logical requests made by a particular user.
Viewing Oracle Business Intelligence Scheduler Reports
To view Oracle Business Intelligence scheduler reports, follow these steps:
  3. From the Business Intelligence Instance menu, select Scheduler Reports.
  4. From the View list, select the set of scheduler reports you want to view.
Using this page, you can view the BI Instance target jobs that failed in the past 24 hours, and the BI Instance target jobs that have been scheduled to begin later. These details inform you about the jobs that failed recently and the jobs scheduled to take place in the future, giving you a summary of the BI Instance past and future job activity.
Table 12-8 describes the elements of the Scheduler Reports page.
Table 12-8 Oracle Business Intelligence Instance Scheduler Reports
Element Description
Job Name
Name of the job, as specified by the user who created it.
Instance ID
ID of the job instance.
Job ID
ID of the job.
Start Time
Time the job started.
End Time
Time the job ended or failed.
Error Message
Error message of the failed job.
User
User who created the job.
Scheduled Time
Time the job is scheduled to begin.
Script Type
Type of script to be executed.
Viewing Oracle Business Intelligence Instance Key Metrics
To view the key metrics related to the BI Instance target, navigate to the Metrics section by following these steps:
The Metrics section displays the key metrics used to monitor the performance of the BI Instance. Analyzing these metrics provides early warnings of errors and incidents, and helps you identify problem areas quickly.
To view all BI Instance metrics, access the All Metrics page. To access this page, from the Business Intelligence Instance menu, select Monitoring, then select All Metrics. For more information on this page, see Viewing Target Metrics.
Table 12-9 describes the elements of the Metrics section.
Table 12-9 Oracle Business Intelligence Instance Key Metrics
Metric Description
Request Processing Time (ms)
Average time, in milliseconds, taken by the BI Servers to process a request. This metric is collected from the time the BI Analytics application was last started.
SOA Request Processing Time (ms)
Average time, in milliseconds, taken by the Oracle WebLogic Server cluster to process a web services request. This metric is collected from the time the BI SOA application was last started.
Average Query Time (seconds)
Average time, in seconds, taken by the BI Servers to process a query. This metric is collected from the time the BI Server was last started.
Active Sessions
Total number of active sessions for the BI Instance. This metric is collected from the time the BI Analytics application was last started.
Requests (per minute)
Average number of requests, per minute, received by the BI Servers. This metric is collected from the time the BI Analytics application was last started.
SOA Requests (per minute)
Average number of servlet and/or JavaServer Pages (JSP) invocations, per minute, for web services requests across the Oracle WebLogic Server cluster. This metric is collected from the time the BI SOA application was last started.
Presentation Services Requests (per second)
Average number of requests, per second, received by the BI Presentation Servers. This metric is collected from the time the BI Presentation Server was last started.
Average number of queries, per second, completed by the BI Servers. This metric is collected from the time the BI Server was last started.
Failed Queries
Number of failed BI Server queries. This metric is collected from the time the BI Presentation Server was last started.
Viewing Oracle Essbase Applications Summary
To view a summary of Oracle Business Intelligence Essbase applications, navigate to the Applications section, by following these steps:
  2. From the navigation tree, select the Oracle Fusion Middleware farm having an Essbase Server target. Click the Essbase Server name.
The Applications section provides details about the status, resource usage, and data storage type of the various Essbase applications under the Essbase server. This section is useful to administrators who want to quickly obtain an overview of the availability and storage details of the Essbase applications being monitored.
If the applications displayed in the Applications section are different from the ones displayed in the Target Navigation window, refresh the Oracle Fusion Middleware farm. To do this, from the Target Navigation window, click the Oracle Fusion Middleware farm name. From the Farm menu, click Refresh WebLogic Domain. Click Add/Update Targets.
Table 12-10 describes the elements of this section.
Table 12-10 Oracle Essbase Applications Summary
Element Description
Name
Name of the application.
Status
Application status, whether the application is up or down.
Storage Type
Type of application data storage.
Memory Usage (MB)
Memory, in MB, used by the application.
Cubes
Viewing Oracle Essbase Application Data Storage Details
To view details about how data for an Oracle Business Intelligence Essbase application is stored, navigate to the Cubes section, by following these steps:
  3. From the navigation tree in the Target Navigation window, click the name of the required Essbase application.
The Cubes section provides structural and usage information about the cubes contained in the Essbase application. These details tell you about how data storage is designed for the application, and how accessible the application data is at the moment.
Table 12-11 describes the elements of this section.
Table 12-11 Oracle Essbase Application Data Storage Details
Element Description
Name
Name of the cube.
Dimensions
Number of dimensions the cube has.
Connected Users
Number of users currently connected to the cube data.
Locks
Number of data block locks currently held on the cube.
Data Cache Size (KB)
Size, in KB, of the buffer in memory that holds uncompressed data blocks.
Administering Oracle Business Intelligence Instance and Essbase Targets
To administer Oracle Business Intelligence Instance (BI Instance) and Essbase targets using Enterprise Manager Cloud Control, navigate to the home page of the required target. For information on how to do this, see Monitoring Oracle Business Intelligence Instance and Essbase Targets.
Using Enterprise Manager Cloud Control, you can perform general, as well as target specific administration tasks.
Performing General Administration Tasks
This section explains how to perform general BI Instance and Essbase target administration tasks, such as starting, stopping, or restarting the target, administering target access privileges, administering target blackouts, and so on.
Starting, Stopping, or Restarting the Target
To start, stop, or restart a target, follow these steps:
  4. Click Start Up, Shut Down, or Restart to start, stop, or restart the target, respectively. Alternatively, from the BI Instance component menu or Essbase target menu, select Control, then select Start Up, Shut Down, or Restart.
To run certain patching and maintenance tasks, you may need to stop the target, perform the task, and restart it once the operation is complete.
Administering Target Access Privileges
To manage the access privileges for a target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Target Setup, then select Administrator Access.
  5. Click Add to grant target access privileges to a role or an administrator.
Use the Access page to set target privileges for roles and administrators. The available privileges are View, Operator, and Full.
View only allows you to view the target in the console, whereas Operator allows you to view targets, and perform all administrative actions except deleting targets. Full allows you to view targets, and perform all administrative actions.
Administering Target Blackouts
To administer the blackouts for a target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Monitoring, then select Blackouts.
Blackouts suspend data collection on a monitored target. Blackouts are useful when you want to perform scheduled maintenance tasks on monitored targets.
Use the Blackouts page to search for existing target blackouts, edit existing blackouts, define new blackouts, and stop blackouts. You can also create and stop blackouts using the BI Instance component menu, or the Essbase target menu. To create or stop a blackout, from the BI Instance component menu, or the Essbase target menu, select Control, then select Create Blackout or End Blackout, respectively.
Viewing Target Monitoring Configuration
To view the monitoring configuration details for a particular target, follow these steps:
  4. From the BI Instance component menu or Essbase target menu displayed on the target home page, select Target Setup, then select Monitoring Configuration.
The Monitoring Configuration page provides information about instance properties of the target, which provide internal details about target monitoring.
Table 12-12 describes the elements of the Monitoring Configuration page.
Table 12-12 Target Monitoring Configuration
Element Description
Canonical Path
Component path of the form instance_name/component_name.
Oracle Instance Home
DB Class String
String needed to form a JDBC connection with a target repository.
DB Connection String
String that specifies information about the target repository, and the means to connect to it.
DB Password
Repository database password.
DB User Name
Repository database user name.
Domain Home
Domain home directory of the WebLogic domain that the target is a part of.
Is JRF Enabled
Whether Oracle Java Required Files (JRF) is applied to the target instance or not.
Monitoring Mode
Indicates whether the Enterprise Manager instance uses a repository while monitoring the target or not. Repo indicates that a repository is used, whereas Repo-less indicates that a repository is not used.
Version
Performing Target-Specific Administration Tasks
This section explains how to perform target-specific BI Instance and Essbase target administration tasks, such as viewing BI Instance component failovers, and editing BI Instance monitoring credentials.
Viewing Oracle Business Intelligence Component Failovers
To view the BI Instance component failovers, follow these steps:
  2. From the navigation tree, select the Oracle Fusion Middleware farm having a BI Instance target. Click the BI Instance name.
  3. Select the Availability tab, then select Failover.
This page displays the risk levels of BI Instance component failure, the recommended backup actions to prevent component failures, and the backup or secondary hosts for components that have failovers configured. Administrators can use this information to plan failovers for BI Instance components that have a high risk of failure.
For more information on the recommended backup actions to avoid BI Instance component failures, refer to Oracle Fusion Middleware System Administrator's Guide for Oracle Business Intelligence Enterprise Edition.
Editing Oracle Business Intelligence Monitoring Credentials
To edit the BI Instance monitoring credentials, follow these steps:
  2. From the navigation tree, select the Oracle Fusion Middleware farm having an BI Instance. Click the BI Instance name.
  3. From the Business Intelligence Instance menu, select Target Setup, then select Monitoring Credentials.
  4. Edit the required fields, then click Save.
This page enables you to specify and edit the credentials required to connect to the database which stores scheduling and usage tracking information. Without specifying the correct credentials on this page, you cannot access certain dashboard reports. Hence, ensure that you specify the appropriate credentials on this page before accessing the Dashboard Reports page.
Table 12-13 describes the elements of the Monitoring Credentials page.
Table 12-13 Oracle Business Intelligence Instance Monitoring Credentials
Element Description
Database Type
Type of the database.
Hostname
Name of the host on which the database is installed.
Port
Port used for communicating with the database.
Service Name
Name of the database service.
Username
User name used for database login.
Password
Password used for database login.
Scaling Out Oracle Business Intelligence Domains
This section describes the procedure to scale out a Business Intelligence Domain.
Prerequisites for Scaling Out a Business Intelligence Domain
Before you run the deployment procedure, meet the following prerequisites:
  • The Business Intelligence Domain that is scaled up must be an existing domain that has been discovered with Cloud Control.
  • If you are scaling out a domain, ensure that the destination machine contains sufficient space. If the size of the Middleware Home on the source machine is 3 GB, you need approximately 3 GB in the working directory on the source and destination machines. Additionally, the destination machine should also have 3 GB of space for the Middleware Home. The working directory is cleaned up after deployment procedure has been successfully completed.
  • The Middleware Home directory you specify on the destination machine must be a new directory or must be empty.
  • The Management Agent must be installed on the source (where the Administration Server is running) and the destination machines. The Administration Server for the domain must be up and running.
  • The Administration Server and Managed Server (being cloned) must be up and running before you run the deployment procedure.
  • The Managed Server and Node Manager ports must be free.
  • The Listener Address should be updated in the admin console for Adminserver.
  • The oraInst.loc file should be created in the Destination Host before starting the Scale Out deployment procedure.
  • Both the Source and Destination Hosts should have the same username and target user.
  • The user must have the following permissions:
    • Read permissions on:
      • Administration Server Host Middleware Directory
      • Administration Server Host Domain Directory
    • Write permissions on:
      • Administration Server Host Working Directory
      • Working Directory of all the destination Managed Server hosts
      • Middleware Directory of all the destination Managed Server hosts
      • Domain Directory of all the destination Managed Server hosts
Procedure for Scaling Out a Business Intelligence Domain
To scale out an existing Business Intelligence (BI) domain in online mode, follow these steps:
  1. You can access the BI instance scale out deployment procedure page, by using any of the following two ways:
    • On the BI instance home page, from the Business Intelligence Instance menu, select Provisioning, and then select Scale Out Business Intelligence.
    • From the Enterprise menu, select Provisioning and Patching, and then select Middleware Provisioning. On the Middleware Provisioning page, in the Deployment Procedures section, select Scale Out Business Intelligence, and then click Launch.
    The Oracle Business Intelligence Scale Out wizard opens.
  2. On the Business Intelligence Details page, select a Business Intelligence instance.
    In the Working Directory field, specify the directory on the Administration Server machine on which the domain scale out related files are temporarily stored. If this directory is not present, it will be created. When the scale out operation has been completed, the directory and its contents will be deleted.
    The Working Directory must not be created under the Middleware Home or the BI Domain Home directory.
  3. In the Source Information section, the details of the source domain including the Middleware Home, BI Domain Home, and the BI Domain Location are displayed. Verify the details.
  4. In the Oracle Instance Details section, to select the host where you want to scale out the Oracle Business Intelligence domain, click Add Hosts.
    In the Target Selector dialog box, select a host, and then click Select. You can select more hosts by clicking Add Host again.
    Click Next.
    You can add the name of the instance and select the number of BI servers, Presentation servers, and Java hosts. You can also select the port range.
  5. In the Credentials page, specify the Host credentials and the Weblogic Administrator credentials.
    • Preferred Credentials: The preferred credentials stored in the Management Repository are used. The Preferred Credentials option will be available only if it has already been defined in Cloud Control.
    • Named Credentials: The credentials stored in the Management Repository is used. To use the Named Credentials stored in the Management Repository, you must have already registered each of the preferred credential types with a unique name. Select the desired Named credential from the list available in Credential Name. If you have created all necessary named credentials, you can use them now. If they have not been created, you can create them using this deployment procedure.
    Click Next.
  6. In the Schedule page, specify a Deployment Instance name. If you want to run the procedure immediately, then retain the default selection, that is, Immediately. If you want to run the procedure later, then select Later and provide time zone, start date, and start time details. You can set the notification preferences according to deployment procedure status. If you want to run only prerequisites, you can select Pause the procedure after the necessary prerequisite checks have been completed to pause the procedure execution after all prerequisite checks are performed.
    Click Next.
  7. On the Review page, review the details you have provided for the Deployment Procedure. If you are satisfied with the details, then click Submit to run the Deployment Procedure according to the schedule set. If you want to modify the details, click the Edit link in the section to be modified or click Back repeatedly to reach the page where you want to make the changes. You can also directly go to the required page by clicking the train button corresponding to the desired page, on the top of the page.
  8. Navigate to the Procedure Activity page. From the Enterprise menu, select Provisioning and Patching, and then select Procedure Activity.
    In the Procedure Activity page, view the status of the execution of the job and steps in the deployment procedure. Click the Status link for each step to view the details of the execution of each step. You can click Debug to set the logging level to Debug and click Stop to stop the procedure execution.
Creating Oracle Business Intelligence Instance Provisioning Profiles
This section describes the procedure to create a Business Intelligence (BI) instance snapshot.
To create a BI instance snapshot, follow these steps:
Before you create a snapshot, you need to configure the NFS software library or the Agent SW library.
Provisioning of BI 12c targets are not supported.
  1. From the Enterprise menu, select Provisioning and Patching, and then select Middleware Provisioning.
  2. On the Middleware Provisioning page, in the Deployment Procedures section, select Create Business Intelligence Profile, and then, click Launch.
  3. On the Create Snapshot: Business Intelligence Details page, click the search icon to search and select the Oracle Business Intelligence instance for which you want to create a snapshot.
  4. On the Create Snapshot: Credentials page, specify the Host credentials and the Weblogic Administrator credentials.
    Click Next.
  5. In the Business Intelligence Details page, verify or specify the BI instance details. Click Next.
  6. In the Snapshot Details page, verify or specify the details of the snapshot to be created. Click Next.
Cloning Oracle Business Intelligence Instances
This section describes the procedure to clone a Business Intelligence Instance from a provisioning profile present in the Software Library.
Prerequisites for Cloning a Business Intelligence Instance
Before running this deployment procedure, the following prerequisites must be met:
  • The user must have Write permissions on:
    • The Working Directory on all destination hosts.
    • Middleware Home on all destination hosts.
  • The ports on the Administration Server, Managed Server, and Node Manager must be free.
  • A Business Intelligence Instance Provisioning Profile must be present in the NFS Software Library or in the Agent Software Library. For details on creating this profile, see Creating a Business Intelligence Provisioning Profile.
    Else, the root credentials have to be used in the credentials page.
Procedure for Cloning a Business Intelligence Instance
To clone a Business Intelligence (BI) instance from a profile, follow these steps:
  1. From the Enterprise menu, select Provisioning and Patching, then select Middleware Provisioning.
  2. On the Middleware Provisioning page, in the Procedure Deployments section, select Business Intelligence Cloning, and then, click Launch.
  3. On the Clone BI Instance: Snapshot page, click the search icon. In the Select Snapshot dialog box, search for or select a snapshot from the list, and then click Select.
    Click Next.
  4. On the Clone BI Instance: Destination Host page, click Add to select the destination host where you want the business intelligence instance to be cloned.
    The destination base directory is read-only and automatically gets configured to match the source location.
    The Temporary Work Directory gets deleted when the content movement deployment procedure has been run.
  5. On the Clone BI Instance: Credentials page, specify the following:
    • Normal Host Credentials
    • Root Host Credentials
    • Weblogic Administration Server Password
    • Global Node Manager Password
    • Keystore Passphrase
  6. On the Clone BI Instance: Domains page, to configure the BI domain information, do the following:
    • In the Destination Hosts section, search for the database hosts that were configured for the destination environment, enter the password that was assigned for each database, and then click Test Connection to confirm that the entry is valid.
    • In the RPD Configuration section, specify the data source and the password.
    • In the Business Intelligence Publisher Configuration section, specify the XMLP Data Source URL.
    • In the Email Options section, specify the SMTP server name, the port, the From display name, and the email address of the sender.
    • Click Next.
