Go to main content
man pages section 3: Networking Library Functions
Exit Print View
Updated: Wednesday, July 27, 2022
sip_hdr_to_str(3SIP)
Name
sip_msg_to_str, sip_hdr_to_str, sip_reqline_to_str, sip_respline_to_str, sip_sent_by_to_str - return string representations
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
char *sip_msg_to_str(sip_msg_t sip_msg,
     int *error);
char *sip_hdr_to_str(sip_header_t sip_header,
     int *error);
char *sip_reqline_to_str(sip_msg_t sip_msg,
     int *error);
char *sip_respline_to_str(sip_msg_t sip_msg,
     int *error);
char *sip_sent_by_to_str(int *error);
Description
The sip_msg_to_str() function returns the string representation of the SIP message sip_msg. Deleted headers are not included in the returned string. The caller is responsible for freeing the returned string.
The sip_hdr_to_str() function returns the string representation of the SIP header sip_header. The caller is responsible for freeing the returned string.
The sip_reqline_to_str() function returns the string representation of the request line from the SIP message sip_msg. The caller is responsible for freeing the returned string.
The sip_respline_to_str() function returns the string representation of the response line from the SIP message sip_msg. The caller is responsible for freeing the returned string.
The sip_sent_by_to_str() function can be used to retrieve the list of sent-by values registered with the stack. The returned string is a comma separated list of sent-by values. The caller is responsible for freeing the returned string.
Return Values
The sip_msg_to_str(), sip_hdr_to_str(), sip_reqline_to_str(), sip_respline_to_str(), and sip_sent_by_to_str() functions return the relevant string on success and NULL on failure.
The value of errno is not changed by these calls in the event of an error.
Errors
For the sip_msg_to_str(), sip_hdr_to_str(), sip_reqline_to_str(), and sip_respline_to_str(), one of the following values is set if the error is non-null:
EINVAL
Input is null.
ENOMEM
Memory allocation failure.
On success, the value of the location pointed to by error is set to 0.
Attributes
See attributes(7) for descriptions of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
libsip(3LIB)
