Go to main content
man pages section 9: DDI and DKI Driver Entry Points
Exit Print View
Updated: Wednesday, July 27, 2022
audio_engine_rate(9E)
Name
audio_engine_rate - return the sample rate of an audio engine
Synopsis
#include <sys/audio/audio_driver.h>
int prefix_rate(void *state);
Parameters
state
pointer to driver supplied soft state
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_engine_rate() function is called by the framework to determine the sample rate of the engine, represented in Hz.
Return Values
The audio_engine_rate() function returns the sample rate of the engine expressed in Hz.
Context
This function may be called from user or interrupt context.
Attributes
See attributes(7) for descriptions of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See Also
audio(4D), attributes(7), audio_engine_ops(9S)
