| Oracle® Fusion Middleware System Requirements and Specifications for Oracle Forms and Reports 11g Release 2 (11.1.2) E25460-03 |
![]() Previous |
E25460-03
September 2018
This document contains system and platform-specific information for Oracle Fusion Middleware Forms and Reports 11g Release 2 (11.1.2) and later.
The following topics are covered in this document:
Section 1, "Using This Document with the Certification Matrix and Product Installation Guide"
Section 2, "Oracle Fusion Middleware Memory and Space Requirements"
Section 7, "System Requirements for Windows Operating Systems"
This document is intended for use in conjunction with the Oracle Fusion Middleware Installation Guide for Oracle Forms and Reports and the Oracle Fusion Middleware 11g Release 2 Certifications.
The following certification documents should be used to determine the proper combination of systems, database, clients, Identity and Access Management, and IP version that should be used for your product installation:
Oracle has tested and verified the performance of your product on all certified systems and environments; whenever new certifications occur, they are added to the proper certification document right away. New certifications can occur at any time, and for this reason the certification documents are kept outside of the documentation libraries and are available on Oracle Technology Network.
The Oracle Fusion Middleware System Requirements and Specifications for Oracle Forms and Reports (this document) should be used to verify that the requirements of the certification are met. For example, if the certification document indicates that your product is certified for installation on 32-Bit Oracle Linux 5, this document should be used to verify that your Oracle Linux 5 system has met the required minimum specifications, like disk space, available memory, specific platform packages and patches, and other operating system-specific items. This document is updated as needed and therefore also resides outside of the documentation libraries and is available on Oracle Technology Network.
After you have verified that your environment meets the requirements specified in both the certification documents and system requirements, you are ready to begin your installation.
Your product installation guides contain the step-by-step instructions to get your product physically installed and configured on your system. These guides are available only from the documentation library (http://docs.oracle.com/) and therefore are not updated unless there is a subsequent product release. Both the certification and system requirement documents can be updated multiple times in between product releases, depending on whether or not new information is available.
This section contains the minimum memory and disk space requirements for Oracle Fusion Middleware products. The following topics are covered:
Section 2.2, "Oracle Forms and Reports Memory and Disk Space Requirements"
Section 2.3, "Oracle Identity Management Memory and Disk Space Requirements"
Unless otherwise noted, Table 1 lists the general minimum memory requirements for Oracle Fusion Middleware products. For the purposes of this document, "minimum available memory" is defined as the amount of physical memory (RAM) and swap memory combined.
This section describes the recommended hardware and system configuration requirements for Oracle Forms and Reports.
Note: On some Windows 32-bit operating systems, the available memory is limited to 3GB. For components that are certified on such systems, Oracle recommends using the/3GB switch, as specified in Microsoft Knowledge Base Article #291988.
For more information, see the certification information, as described in Section 1, "Using This Document with the Certification Matrix and Product Installation Guide". |
Section 2.2.1, "Memory and Disk Space Requirements for Installing Oracle Forms and Reports"
Section 2.2.2, "Memory and Disk Space Requirements for Configuring Oracle Forms and Reports"
Table 2 lists the memory and disk space requirements for installing Oracle Forms and Reports.
Table 2 Memory and Disk Space Requirements for Installation
| Requirement | Value |
Physical Memory |
Expected minimum value is 922MB. |
Temp Space |
Must be greater than 270MB |
Swap Space |
Must be greater than 500MB |
Minimum Available Memory |
Must be greater than 1422MB (physical memory and swap space combined) |
Disk Space |
3600MB |
Table 2 lists the memory and disk space requirements for configuring Oracle Forms and Reports.
Table 3 Memory and Disk Space Requirements for Configuration
Physical Memory |
Temp Space |
Swap Space |
Disk Space |
Depends on your configuration mode:
Oracle Forms and Reports can be protected by Oracle Identity Management as described in Oracle Fusion Middleware Installation Guide for Oracle Forms and Reports.
The memory and disk space requirements for Oracle Identity Management 11g Release 1 (11.1.1) can be found in Oracle Fusion Middleware System Requirements and Specifications for 11g Release 1 (11.1.1). This document can be found on the following page:
http://www.oracle.com/technetwork/middleware/ias/downloads/fusion-requirements-100147.html
Oracle Forms and Reports 11g Release 2 (11.1.2) is released and tested with Oracle WebLogic Server 11gR1 (10.3.5) and 11gR1 (10.3.6). Oracle WebLogic Server can be obtained from the following URL:
http://www.oracle.com/technetwork/middleware/weblogic/downloads/
Oracle WebLogic Server is a prerequisite for installing Oracle Forms and Reports; doing so creates the Middleware home directory where all 11g Release 2 (11.1.2) products must be installed. For instructions, refer to the Oracle WebLogic Server Installation Guide in the 11g Release 1 (11.1.1) documentation library.
Installing Oracle WebLogic Server also installs a JDK on your system. If you are using a 64-bit JVM in your environment, ensure that all your Oracle Fusion Middleware components are using the 64-bit JVM. Also make sure that Oracle WebLogic Server is installed with the 64-bit JDK. You cannot mix components using a 32-bit JVM with those using a 64-bit JVM.
Refer to the certification documents for information on the platforms that support a 64-bit JDK. Links to the certification documents can be found in Section 1, "Using This Document with the Certification Matrix and Product Installation Guide".
This section contains prerequisite information for the Oracle Universal Installer (OUI). The requirements in this section must be met in order for the installer to start:
The environment variables on your system must be set as described in Table 4:
Table 4 Oracle Universal Installer Environment Variable Requirements
| Variable | Description |
Applies to: all configuration tools for all products on all platforms. This variable is automatically set by the configuration tool to the Oracle home from where the configuration tool is started. This is true even if the |
Applies to: all installers for all products on all platforms. For the Oracle Forms and Reports installer, this variable must not be set. For all other installers, there are no restrictions as to whether this variable is set or not set. |
Applies to: all installers for products with system components only on all platforms. If you are installing on a Windows operating system, see "Resolving PATH and Directory Issues on Windows" in the Oracle Fusion Middleware Release Notes for Microsoft Windows (32-Bit) or Oracle Fusion Middleware Release Notes for Microsoft Windows x64 for important additional information. This variable is automatically set by the installer and prepended with NOTE: If your Oracle Fusion Middleware components are running in a 64-bit JVM environment, you must have the appropriate version of the JDK installed on your system, and include the |
Applies to: all installers for products with system components only on HP-UX and HP-IA operating systems. This variable is automatically set by the installer and prepended with |
Applies to: all installers for products with system components only on AIX operating systems. This variable is automatically set by the installer and prepended with |
Applies to: all installers for products with system components only on Linux and Solaris operating systems. This variable is automatically set by the installer and prepended with NOTE: make sure this variable does not contain a reference to any other Oracle home directory. |
Applies to: all installers for all products on all platforms. If you are installing with a graphical user interface (GUI), this variable must be set to the monitor where you want the installer GUI to appear. Refer to your operating system documentation for specific instructions on how to do this, as procedures vary depending on your exact operating system. |
Applies to: all installers for all products on all platforms. Optional variable. If not set, then the default value is |
Applies to: all installers for all products on all platforms. For the Oracle Forms and Reports installer, these variables must not be set. For all other installers, there are no restrictions as to whether these variables are set or not set. |
The items in Table 5 are checked as the installer is being started:
Table 5 Oracle Universal Installer Startup Requirements
| Category | Accepted or Minimum Values |
Platforms |
For a complete list of supported platforms, refer to the System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix on the Oracle Fusion Middleware Supported System Configurations page, as described in Section 1, "Using This Document with the Certification Matrix and Product Installation Guide". |
CPU Speed |
At least 300MHz |
Temp Space |
At least 270MB |
Swap Space |
At least 500MB |
Monitor |
At least 256 colors |
If you are running Oracle Universal Installer on Linux x86 or Linux x86-64 operating systems, you must modify the value of the SHMMAX kernel parameter to avoid seeing errors generated by the Oracle Universal Installer. To do so:
Change the value of SHMMAX to 4294967295 by including the following line in /etc/sysctl.conf:
kernel.shmmax = 4294967295
Activate the new SHMMAX setting by running the command:
/sbin/sysctl -p
Start the Oracle Universal Installer and install your software.
Typically, the computer on which you want to install Oracle Fusion Middleware is connected to the network. The computer has local storage to store the Oracle Fusion Middleware installation and also contains a display monitor and DVD drive.
If your environment is not a typical scenario, you should read the "Oracle Fusion Middleware Network Requirements" section in the 11g Release 1 (11.1.1) System Requirements and Specification document:
http://docs.oracle.com/html/E18558_01/fusion_requirements.htm
This section contains system requirement information for UNIX operating systems.
In some cases, a particular platform may be de-supported for use with Oracle Fusion Middleware products. While this particular platform's requirements may remain in this document for legacy purposes, it would no longer be listed in the certification document and would no longer be considered a "certified" platform.
Links to the certification document can be found in Section 1, "Using This Document with the Certification Matrix and Product Installation Guide".
All packages listed are minimum versions.
The following topics are covered in this section:
Section 6.2, "Supported Linux Operating System Versions, Packages, and Patches"
Section 6.3, "Supported Solaris Operating System Versions, Packages, and Patches"
Section 6.4, "Supported HP-UX Operating System Versions, Packages, and Patches"
Section 6.5, "Supported IBM AIX Operating System Versions, Packages, and Patches"
On all UNIX and Linux operating systems, verify the values that are currently set for Open File Limit. The minimum Open File Limit should be at 4096, but you should also consider the number of processes required for each host.
The following examples are for Linux operating systems. Equivalent commands should be followed for other UNIX operating systems.
To verify how many files are open, use the following command:
/usr/sbin/lsof | wc -l
To check your open file limits, use the following commands:
For C-shell:
limit descriptors
For Bash:
ulimit -n
To change the open file limits:
Log in as the root user.
Locate and open the following operating system configuration file:
/etc/security/limits.conf
Look for or modify the following lines in the limits.conf file:
* soft nofile 4096 * hard nofile 65536 * soft nproc 2047 * hard nproc 16384
Save your changes and close the limits.conf file.
If you are running Oracle Enterprise Linux 6 or Red Hat Linux 6, locate the following operating system configuration file:
/etc/security/limits.d/90-nproc.conf
Make sure the same values are added to the 90-nproc.conf file; otherwise, the values in the 90-nproc.conf file can override the values in the limits.conf file.
Reboot the machine.
On UNIX operating systems, the installation of Fusion Middleware products is owned and controlled as a known user (for example, "oracle"). The file permissions associated with this installation are configured to ensure the highest level of security possible, which by default are 700 (meaning all files are owned and accessible by the owner only).
Changing the default permissions settings will reduce the security of the installation and possibly your system. Therefore, making such a change is not recommended. If access to particular files or executables is required by other users, the UNIX sudo command (or other similar command) should be considered in lieu of changing file permissions.
Refer to your UNIX operating system Administrator's Guide or contact your operating system vendor if you need further assistance.
Table 6 lists the platform, operating system, package, and patch information for Linux operating systems that are either currently supported or were supported in a previous release.
In addition, you should also review the following Linux-specific issues to see if they are applicable to your environment:
Section 6.2.1, "How to Obtain the Required Kernel Version for Linux Operating Systems"
Section 6.2.3, "Patches Required Before Installing Oracle Forms and Reports on SUSE 12 (SP1+)"
Section 6.2.5, "Silent Install Not Supported on Oracle Linux 7, Red Hat Linux 7 and SUSE 12 (SP1+)"
Section 6.2.6, "Obtaining the Font RPM Package for Forms and Reports on Oracle Linux 6"
Section 6.2.7, "Obtaining the Font RPM Package for Forms and Reports on Oracle Linux 7"
Section 6.2.8, "Obtaining the openmotif22 Package on SUSE 10 and SUSE 11 Operating Systems"
Section 6.2.9, "Installing Oracle HTTP Server on Linux Operating Systems Requires NPTL"
Table 6 Supported Linux Operating Systems
| Platform | Operating System Version | Required Packages | Required Operating System Kernel |
Linux x86-64 |
Oracle Linux 7 (UL0+) Red Hat Linux 7 (UL0+) |
binutils-2.23.52.0.1 compat-libcap1-1.10 compat-libstdc++-33-3.2.3 for x86_64 compat-libstdc++-33-3.2.3 for i686 gcc-4.8.2 gcc-c++-4.8.2 glibc-2.17 for x86_64 glibc-2.17 for i686 glibc-devel-2.17 for x86_64 glibc-devel-2.17 for i686 libaio-0.3.109 for x86_64 libaio-devel-0.3.109 for x86_64 libgcc-4.8.2 for x86_64 libgcc-4.8.2 for i686 libstdc++-4.8.2 for x86_64 libstdc++-4.8.2 for i686 libstdc++-devel-4.8.2 for x86_64 ksh make-3.82 ocfs2-tools-1.8.0 libXext-1.3.2 for i686 libXext-1.3.2 for x86_64 libXtst-1.2.2 for x86_64 libXtst-1.2.2 for i686 sysstat-10.1.5 motif-2.3.4-7 for x86_64 motif-devel-2.3.4-7 for x86_64 motif-2.3.4-7 for i686 motif-devel-2.3.4-7 for i686 redhat-lsb-4.1-27.0.1.el7 for x86_64 redhat-lsb-core-4.1-27.0.1.el7 for x86_64 |
See How to Obtain the Required Kernel Version for Linux Operating Systems. |
Linux x86-64 |
Oracle Linux 6 (UL1+) Red Hat Linux 6 (UL1+) |
binutils-2.20.51.0.2-5.28.el6 compat-libcap1-1.10-1 compat-libstdc++-33-3.2.3-69.el6 for x86_64 compat-libstdc++-33-3.2.3-69.el6 for i686 gcc-4.4.4-13.el6 gcc-c++-4.4.4-13.el6 glibc-2.12-1.7.el6 for x86_64 glibc-2.12-1.7.el6 for i686 glibc-devel-2.12-1.7.el6 for i686 libaio-0.3.107-10.el6 libaio-devel-0.3.107-10.el6 libgcc-4.4.4-13.el6 libstdc++-4.4.4-13.el6 for x86_64 libstdc++-4.4.4-13.el6 for i686 libstdc++-devel-4.4.4-13.el6 libXext for i686 libXtst for i686 openmotif-2.2.3 for x86_64 openmotif22-2.2.3 for x86_64 sysstat-9.0.4-11.el6 redhat-lsb-4.0-3.el6 for x86_64 redhat-lsb-core-4.0-3.el6 for x86_64 |
Linux x86-64 |
Oracle Linux 5 (UL3+) Red Hat Linux 5 (UL3+) |
binutils-2.17.50.0.6 compat-libstdc++-33-3.2.3 for x86-64 compat-libstdc++-33-3.2.3 for i386 elfutils-libelf-0.125 elfutils-libelf-devel-0.125 gcc-4.1.1 gcc-c++-4.1.1 glibc-2.5-12 for x86_64 glibc-2.5-12 for i686 glibc-common-2.5 glibc-devel-2.5 for x86-64 glibc-devel-2.5-12 for i386 libaio-0.3.106 for x86_64 libaio-0.3.106 for i386 libaio-devel-0.3.106 libgcc-4.1.1 for x86_64 libgcc-4.1.1 for i386 libstdc++-4.1.1 for x86_64 libstdc++-4.1.1 for i386 libstdc++-devel-4.1.1 make-3.81 openmotif-2.2.3 openmotif22-2.2.3 redhat-lsb-3.1-12.3.EL.0.2 sysstat-7.0.0 xorg-x11-utils |
Kernel 2.6.18 |
Linux x86 |
binutils-2.16.91.0.5-23.4 compat-libstdc++-296-2.96-132.7.2 compat-db-4.1.25-9 control-center-2.8.0-12 gcc-4.1.0-28.4 gcc-c++-4.1.0-28.4 glibc-common-2.3.4-2.9 libaio-0.3.106 libaio-devel-0.3.106 libgnomeui.i386 libstdc++-4.1.0-28.4 libstdc++-devel-4.1.0-28.4 make-3.80-202.2 openmotif-2.2.3 openmotif22-2.2.3 pdksh-5.2.14-30 setarch-1.6-1 sysstat-5.0.5-1 |
Kernel 2.6.18 |
Linux x86-64 |
Oracle Linux 4 (UL7+) Red Hat Linux 4 (UL4+) |
binutils-2.15.92.0.2 compat-libstdc++-33-3.2.3 for x86_64 compat-libstdc++-33-3.2.3 for i386 elfutils-libelf-0.97 elfutils-libelf-devel-0.97 gcc-3.4.5 gcc-c++-3.4.5 glibc-2.3.4-2.19 for x86_64 glibc-2.3.4-2.19 for i686 glibc-common-2.3.4 glic-devel-2.3.4 for x86_64 glic-devel-2.3.4 for i386 libaio-0.3.105 for x86_64 libaio-0.3.105 for i386 libaio-devel-0.3.105 libgcc-3.4.5 for x86_64 libgcc-3.4.5 for i386 libstdc++-3.4.5 for x86_64 libstdc++-3.4.5 for i386 libstdc++-devel-3.4.5 for x86_64 libstdc++-devel-3.4.5 for i386 make-3.80 openmotif-2.2.3 openmotif21-2.1.30-11.RHEL4.4 sysstat-5.0.5 |
Kernel 2.6.9 |
Linux x86 |
binutils-2.15.92.0.2-13 compat-libstdc++-296-2.96-132.7.2 compat-db-4.1.25-9 control-center-2.8.0-12 gcc-3.4.3-22.1 gcc-c++-3.4.3-22.1 glibc-common-2.3.4-2.9 gnome-libs-1:1.4.1.2.90-44.1 libaio-0.3.105 libaio-devel-0.3.105 libstdc++-3.4.3-22.1 libstdc++-devel-3.4.3-22.1 make-1:3.80-5 openmotif-2.2.3 openmotif21-2.1.30-11.RHEL4.4 pdksh-5.2.14-30 setarch-1.6-1 sysstat-5.0.5-1 xscreensaver-4.18-5.rhel4.2 |
Kernel 2.6.9 |
Linux x86-64 |
SUSE 12 (SP1+) |
binutils-2.24-2.165 gcc-4.8-6.189 gcc-c++-4.8-6.189 glibc-2.19-17.72 glibc-devel-2.19-17.72 mksh-50-2.13 libaio1-0.3.109-17.15 libaio-devel-0.3.109-17.15 libcap2-2.22-11.709 libstdc++6-4.8.3+r212056-6.3 libstdc++48-devel-4.8.3+r212056-6.3 libstdc++48-devel-32bit-4.8.3+r212056-6.3 libstdc++6-32bit-4.8.3+r212056-6.3 libgcc_s1-4.8.3+r212056-6.3 libgcc_s1-32bit-4.8.3+r212056-6.3 make-4.0-2.107 xorg-x11-libs-7.6-45.14 motif-2.3.4-4.15.x86_64 |
Kernel 3.12.28-4-default |
Linux x86-64 |
SUSE 11 (all SP levels included) |
binutils-2.19-11.28 gcc-4.3-62.198 gcc-c++-4.3-62.198 gcc-32bit-4.3 glibc-2.9-13.2 glibc-32bit-2.9-13.2 glibc-devel-2.9 glibc-devel-32bit-2.9-13.2 ksh-93t libaio-0.3.104-140.22 libaio-devel-0.3.104-140.22 libaio-32bit-0.3.104 libaio-devel-32bit-0.3.104 libgcc43-4.3.3_20081022 libstdc++43-4.3.3_20081022-11.18 libstdc++43-devel-4.3.3_20081022-11.18 libstdc++33-3.3.3 libstdc++33-32bit-3.3.3 libstdc++43-32bit-4.3.3_20081022 libstdc++43-devel-32bit-4.3.3_20081022 libstdc++-devel-4.3 make-3.81 openmotif-2.3.1-3.13 openmotif-devel-32bit-2.3.1-3.13 openmotif22-libs-32bit-2.2.4-138.17Footref 1 openmotif-libs-2.3.1-3.13 openmotif-devel-2.3.1-3.13 openmotif-libs-32bit-2.3.1-3.13 openmotif21-libs-32bit-2.1.30MLI4-143.2 openmotif22-libs-2.2.4-138.17Footref 1 sysstat-8.1.5-7.8 |
Kernel 2.6.27.19-5-default |
Linux x86 |
binutils-2.19-11.28 gcc-4.3-62.198 gcc-c++-4.3-62.198 glibc-2.9-13.2 glibc-devel-2.9 ksh-93t libaio-0.3.104-140.22 libaio-devel-0.3.104-140.22 libgcc43-4.3.3_20081022 libstdc++43-4.3.3_20081022-11.18 libstdc++43-devel-4.3.3_20081022-11.18 libstdc++33-3.3.3 libstdc++devel-4.3 make-3.81 openmotif22-libs-2.2.4-138.17Foot 1 openmotif-2.3.1-3.13 openmotif21-libs-2.1.30MLI4-143.9 openmotif-libs-2.3.1-3.13 openmotif-devel-2.3.1-3.13 sysstat-8.1.5-7.8 |
Linux x86-64 |
SUSE 10 (SP1+) |
binutils-2.16.91.0.5 compat-libstdc++-5.0.7-22.2 gcc-4.1.0 gcc-c++-4.1.0 glibc-2.4-31.2 glibc-32bit-2.4-31.2 glibc-devel-2.4 glibc-devel-32bit-2.4 libaio-0.3.104 libaio-devel-0.3.104 libelf-0.8.5 libgcc-4.1.0 libstdc++-4.1.0 libstdc++-devel-4.1.0 make-3.80 openmotif-2.2.3 openmotif21-libs-2.1.30 sysstat-6.0.2 |
Kernel 2.6.16.21 |
Linux x86 |
SUSE 10 (SP1+) |
binutils (version 2.16.91.0.5-23) compat-libstdc++ (version 5.0.7-22.2) compat (version 2006.1.25-11.2) gcc (version 4.1.0-28.4) glibc-devel (version 2.4-31.2) gcc-c++ (version 4.1.0-28.4) libaio (version 0.3.104) libaio-devel (0.3.104) libgcc (version 4.1.0-28.4) libstdc++ (version 4.1.0-28.4) libstdc++-devel (version 4.1.0-28.4) make (version 3.80-202.2) openmotif (version 2.2.3) openmotif21-libs (version 2.1.30) |
Kernel 2.6.16.21 |
Footnote 1 This package is required for Oracle Forms and Reports. For more information, see Section 6.2.8, "Obtaining the openmotif22 Package on SUSE 10 and SUSE 11 Operating Systems".
To identify the required Kernel version for each supported version of Oracle Linux, refer to the following resources:
For Oracle Linux 6 (UL5+) and Oracle Linux 7 (UL0+) Containers, refer to Table 1 on "Supported Virtualization and Partitioning Technologies for Oracle Fusion Middleware" on the Oracle Technology Network.
Install the patch mentioned below before you can install Oracle Forms and Reports 11.1.2.2.0 on Oracle Linux 7 and Red Hat Linux 7:
While installing Oracle Forms and Reports 11g Release 2 (11.1.2.2.0), the prerequisite check may fail on Oracle Linux 7 or Red Hat Linux 7 with Oracle JDK 1.7.0_51+.
Apply Generic Patch 20836354 to handle this problem.
Use the following procedure to use the patch:
Download and unpack the Oracle Forms and Reports 11g Release 2 (11.1.2.2) software on your local disk.
After you unzip the archive, you should be able to locate a folder called Disk1 in the unpacked directory.
Download patch 20836354 from My Oracle Support.
Unzip the patch archive, using the following command:
unzip -d PATCH_DIR p20836354_11.1.2.2.0_generic.zip
In this example, replace PATCH_DIR with the name of a local directory. This is typically a top-level directory used for storing patches you have downloaded from My Oracle Support.
Change directory to the following directory where you unpacked the Oracle Forms and Reports software archive:
cd unpacked_forms_directory\Disk1
Locate and run the Oracle Forms and Reports installer (setup.exe), as follows:
./runInstaller PREREQ_CONFIG_LOCATION=PATCH_DIR/prereq
In this example, replace PATCH_DIR with the path to the local directory where you unzipped patch 20836354 in Step 3.
Install the patch mentioned below before you install the fusion middleware products.
Apply patch 22651881 to handle this problem.
Download patch 22651881 from My Oracle Support.
unzip -d PATCH_DIR p22651881_111220_generic.zip
Change directory to the following directory where you unpacked the software archive:
Locate and run the installer (runInstaller), as follows:
In this example, replace PATCH_DIR with the path to the local directory where you unzipped patch 22651881 in Step 3.
During the software installation of Oracle Forms and Reports 11.1.2.2.0 on Oracle Linux 7, Red Hat Linux 7 and SUSE 12 SP1+ OUI reports the following error at 92% (during EM Agent binaries link stage):
Error in invoking target 'agent' of makefile
Use the following procedure to download the patch:
From My Oracle Support, go to patch 19692824.
From the Select a Release drop-down list, select FMW Control 11.1.1.7.0.
From the Platform or Language drop-down list, select Linux x86-64.
Click Download.
Follow the instructions in the patch readme file and apply the patch.
The Oracle Fusion Middleware installer (which is based on the Oracle Universal Installer) does not support silent (command-line) mode on Oracle Linux 7, Red Hat Linux 7 and SUSE 12 (SP1+). You must use the graphical user interface when installing the binaries on an Oracle Linux 7, Red Hat Linux 7 and SUSE 12 (SP1+) machine.
Follow the instructions in this section if you need to run the Oracle Forms and Reports builder functionality on Oracle Linux 6:
Log in to your system as root.
Go to the /etc/yum.repos.d directory.
Run the following command:
wget http://public-yum.oracle.com/public-yum-ol6.repo
Edit the public-yum-ol6.repo file and modify section [ol6_*] to change enabled=0 to enabled=1.
Install the fonts with the following command:
yum install *font*
If you are not able to use yum to perform this, install the following packages using the rpm -i package_name command:
baekmuk-ttf-batang-fonts noarch 2.2-28.el6 ol6_ga_base 4.0 baekmuk-ttf-dotum-fonts noarch 2.2-28.el6 ol6_ga_base 1.7 baekmuk-ttf-fonts-common noarch 2.2-28.el6 ol6_ga_base 8.8 baekmuk-ttf-fonts-ghostscript noarch 2.2-28.el6 ol6_ga_base 7.5 baekmuk-ttf-gulim-fonts noarch 2.2-28.el6 ol6_ga_base 3.7 baekmuk-ttf-hline-fonts noarch 2.2-28.el6 ol6_ga_base 372 bitmap-console-fonts noarch 0.3-15.el6 ol6_ga_base 20 bitmap-fangsongti-fonts noarch 0.3-15.el6 ol6_ga_base 623 bitmap-fonts-compat noarch 0.3-15.el6 ol6_ga_base 5.3 bitmap-miscfixed-fonts noarch 0.3-15.el6 ol6_ga_base 531 bpg-algeti-fonts noarch 2.005-6.1.el6 ol6_ga_base 32 bpg-courier-s-fonts noarch 4.000-6.1.el6 ol6_ga_base 25 bpg-elite-fonts noarch 3.000-6.1.el6 ol6_ga_base 31 bpg-ingiri-fonts noarch 4.000-6.1.el6 ol6_ga_base 28 bpg-nino-medium-cond-fonts noarch 4.005-6.1.el6 ol6_ga_base 26 bpg-nino-medium-fonts noarch 4.005-6.1.el6 ol6_ga_base 26 bpg-sans-fonts noarch 1.005-6.1.el6 ol6_ga_base 37 bpg-sans-medium-fonts noarch 1.005-6.1.el6 ol6_ga_base 37 bpg-sans-modern-fonts noarch 2.025-6.1.el6 ol6_ga_base 29 bpg-sans-regular-fonts noarch 1.005-6.1.el6 ol6_ga_base 37 bpg-serif-fonts noarch 1.005-6.1.el6 ol6_ga_base 44 bpg-serif-modern-fonts noarch 2.028-6.1.el6 ol6_ga_base 40 ctan-kerkis-calligraphic-fonts noarch 2.0-23.el6 ol6_ga_base 93 culmus-fonts-compat noarch 0.103-7.el6 ol6_ga_base 5.3 dejavu-lgc-sans-fonts noarch 2.30-2.el6 ol6_ga_base 1.1 dejavu-lgc-serif-fonts noarch 2.30-2.el6 ol6_ga_base 701 fontforge x86_64 20090622-3.1.el6 ol6_latest 6.6 fontforge-devel x86_64 20090622-3.1.el6 ol6_latest 123 fontpackages-devel noarch 1.41-1.1.el6 ol6_ga_base 22 fontpackages-tools noarch 1.41-1.1.el6 ol6_ga_base 33 libXfont-devel x86_64 1.4.5-2.el6 ol6_latest 22 libfontenc-devel x86_64 1.0.5-2.el6 ol6_ga_base 10 libfonts x86_64 1.0.0-3.OOo31.el6 ol6_ga_base 326 libfonts-javadoc noarch 1.0.0-3.OOo31.el6 ol6_ga_base 118 libreoffice-opensymbol-fonts noarch 1:3.4.5.2-16.1.0.1.el6_3 ol6_latest 170 stix-integrals-fonts noarch 0.9-13.1.el6 ol6_ga_base 35 stix-pua-fonts noarch 0.9-13.1.el6 ol6_ga_base 104 stix-sizes-fonts noarch 0.9-13.1.el6 ol6_ga_base 25 stix-variants-fonts noarch 0.9-13.1.el6 ol6_ga_base 13 terminus-fonts-console noarch 4.30-1.el6 ol6_ga_base 578 thai-scalable-fonts-compat noarch 0.4.12-2.1.el6 ol6_ga_base 5.8 wqy-zenhei-fonts-common noarch 0.9.45-3.el6 ol6_ga_base 28 xorg-x11-fonts-ISO8859-15-100dpi noarch 7.2-9.1.el6 ol6_ga_base 1.1 Installing for dependencies: autotrace x86_64 0.31.1-26.el6 ol6_latest 128 libbase x86_64 1.0.0-3.OOo31.1.el6 ol6_ga_base 216 libloader x86_64 1.0.0-2.OOo31.1.el6 ol6_ga_base 143 libuninameslist x86_64 20080409-3.1.el6 ol6_ga_base 457 perl-Font-TTF noarch 0.45-6.el6 ol6_ga_base 314
Set the NLS_LANG variable appropriately for your system. For example:
set NLS_LANG=AMERICAN_AMERICA.WE8ISO8859P15
Follow the instructions in this section if you need to run the Oracle Forms and Reports builder functionality on Oracle Linux 7:
Go to the /etc/yum.conf file to add the required proxy information:
proxy=http://www-proxy.us.<address>:<port number>
Where, <address> is oracle.com and <port number> is 80.
wget http://public-yum.oracle.com/public-yum-ol7.repo
Edit the public-yum-ol7.repo file and modify section [ol7_*] to change enabled=0 to enabled=1.
yum install *font*
abattis-cantarell-fonts.noarch 0.0.12-3.el7 @anaconda/7.0
baekmuk-ttf-batang-fonts.noarch 2.2-36.el7 @ol7_optional_latest
baekmuk-ttf-dotum-fonts.noarch 2.2-36.el7 @ol7_optional_latest
baekmuk-ttf-fonts-common.noarch 2.2-36.el7 @ol7_optional_latest
baekmuk-ttf-fonts-ghostscript.noarch 2.2-36.el7 @ol7_optional_latest
baekmuk-ttf-gulim-fonts.noarch 2.2-36.el7 @ol7_optional_latest
baekmuk-ttf-hline-fonts.noarch 2.2-36.el7 @ol7_optional_latest
bitmap-console-fonts.noarch 0.3-21.el7 @ol7_optional_latest
bitmap-fangsongti-fonts.noarch 0.3-21.el7 @ol7_optional_latest
bitmap-fixed-fonts.noarch 0.3-21.el7 @anaconda/7.0
bitmap-fonts-compat.noarch 0.3-21.el7 @ol7_optional_latest
bitmap-lucida-typewriter-fonts.noarch 0.3-21.el7 @anaconda/7.0
bpg-algeti-fonts.noarch 2.005-3.el7 @ol7_optional_latest
bpg-chveulebrivi-fonts.noarch 3.002-3.el7 @anaconda/7.0
bpg-classic-fonts.noarch 8.500-3.el7 @ol7_optional_latest
bpg-courier-fonts.noarch 4.002-3.el7 @anaconda/7.0
bpg-courier-s-fonts.noarch 4.000-3.el7 @ol7_optional_latest
bpg-dedaena-block-fonts.noarch 3.005-3.el7 @ol7_optional_latest
bpg-dejavu-sans-fonts.noarch 2.28-3.el7 @ol7_optional_latest
bpg-elite-fonts.noarch 3.000-3.el7 @ol7_optional_latest
bpg-excelsior-caps-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-excelsior-condenced-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-excelsior-fonts.noarch 2.03-3.el7 @ol7_optional_latest
bpg-fonts-common.noarch 20120413-3.el7 @anaconda/7.0
bpg-glaho-fonts.noarch 9.000-3.el7 @anaconda/7.0
bpg-gorda-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-ingiri-fonts.noarch 4.000-3.el7 @ol7_optional_latest
bpg-irubaqidze-fonts.noarch 1.000-3.el7 @ol7_optional_latest
bpg-mikhail-stephan-fonts.noarch 2.500-3.el7 @ol7_optional_latest
bpg-mrgvlovani-caps-fonts.noarch 1.002-3.el7 @ol7_optional_latest
bpg-mrgvlovani-fonts.noarch 1.002-3.el7 @ol7_optional_latest
bpg-nateli-caps-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-nateli-condenced-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-nateli-fonts.noarch 2.003-3.el7 @ol7_optional_latest
bpg-nino-medium-cond-fonts.noarch 4.005-3.el7 @ol7_optional_latest
bpg-nino-medium-fonts.noarch 4.005-3.el7 @ol7_optional_latest
bpg-sans-fonts.noarch 1.005-3.el7 @ol7_optional_latest
bpg-sans-medium-fonts.noarch 1.005-3.el7 @ol7_optional_latest
bpg-sans-modern-fonts.noarch 2.025-3.el7 @ol7_optional_latest
bpg-sans-regular-fonts.noarch 1.005-3.el7 @ol7_optional_latest
bpg-serif-fonts.noarch 1.005-3.el7 @ol7_optional_latest
bpg-serif-modern-fonts.noarch 2.028-3.el7 @ol7_optional_latest
bpg-ucnobi-fonts.noarch 3.300-3.el7 @ol7_optional_latest
cjkuni-ukai-fonts.noarch 0.2.20080216.1-51.el7
@anaconda/7.0
cjkuni-uming-fonts.noarch 0.2.20080216.1-53.el7
@anaconda/7.0
culmus-aharoni-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-caladings-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-david-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-drugulin-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-ellinia-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-fonts-common.noarch 0.130-3.el7 @anaconda/7.0
culmus-frank-ruehl-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-hadasim-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-keteryg-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-miriam-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-miriam-mono-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-nachlieli-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-shofar-fonts.noarch 0.130-3.el7 @ol7_optional_latest
culmus-simple-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-stamashkenaz-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-stamsefarad-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
culmus-yehuda-clm-fonts.noarch 0.130-3.el7 @anaconda/7.0
dejavu-fonts-common.noarch 2.33-6.el7 @anaconda/7.0
dejavu-lgc-sans-fonts.noarch 2.33-6.el7 @ol7_optional_latest
dejavu-lgc-sans-mono-fonts.noarch 2.33-6.el7 @ol7_optional_latest
dejavu-lgc-serif-fonts.noarch 2.33-6.el7 @ol7_optional_latest
dejavu-sans-fonts.noarch 2.33-6.el7 @anaconda/7.0
dejavu-sans-mono-fonts.noarch 2.33-6.el7 @anaconda/7.0
dejavu-serif-fonts.noarch 2.33-6.el7 @anaconda/7.0
fontawesome-fonts.noarch 4.1.0-1.el7 @ol7_latest
fontawesome-fonts-web.noarch 4.1.0-1.el7 @ol7_optional_latest
fontconfig.i686 2.10.95-7.el7 @anaconda/7.0
fontconfig.x86_64 2.10.95-7.el7 @anaconda/7.0
fontconfig-devel.i686 2.10.95-7.el7 @anaconda/7.0
fontconfig-devel.x86_64 2.10.95-7.el7 @anaconda/7.0
fontconfig-devel-doc.noarch 2.10.95-7.el7 @ol7_optional_latest
fontforge.i686 20120731b-12.el7 @ol7_optional_latest
fontforge.x86_64 20120731b-12.el7 @ol7_optional_latest
fontforge-devel.i686 20120731b-12.el7 @ol7_optional_latest
fontforge-devel.x86_64 20120731b-12.el7 @ol7_optional_latest
fontpackages-devel.noarch 1.44-8.el7 @ol7_optional_latest
fontpackages-filesystem.noarch 1.44-8.el7 @anaconda/7.0
fontpackages-tools.noarch 1.44-8.el7 @ol7_optional_latest
fonts-tweak-tool.i686 0.3.2-5.el7 @anaconda/7.0
fonts-tweak-tool.x86_64 0.3.2-5.el7 @anaconda/7.0
fonttools.x86_64 2.4-3.el7 @ol7_optional_latest
ghostscript-fonts.noarch 5.50-32.el7 @anaconda/7.0
gnome-font-viewer.x86_64 3.8.0-3.el7 @anaconda/7.0
gnu-free-fonts-common.noarch 20120503-8.el7 @anaconda/7.0
gnu-free-mono-fonts.noarch 20120503-8.el7 @anaconda/7.0
gnu-free-sans-fonts.noarch 20120503-8.el7 @anaconda/7.0
gnu-free-serif-fonts.noarch 20120503-8.el7 @anaconda/7.0
google-crosextra-caladea-fonts.noarch 1.002-0.4.20130214.el7
@anaconda/7.0
google-crosextra-carlito-fonts.noarch 1.103-0.2.20130920.el7
@anaconda/7.0
google-noto-sans-armenian-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-avestan-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-bengali-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-bengali-ui-fonts.noarch
google-noto-sans-brahmi-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-carian-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-cherokee-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-coptic-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-deseret-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-devanagari-fonts.noarch
google-noto-sans-devanagari-ui-fonts.noarch
google-noto-sans-egyptian-hieroglyphs-fonts.noarch
google-noto-sans-ethiopic-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-georgian-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-glagolitic-fonts.noarch
google-noto-sans-gujarati-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-gujarati-ui-fonts.noarch
google-noto-sans-hanunno-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-hebrew-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-imperial-aramaic-fonts.noarch
google-noto-sans-kaithi-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-kannada-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-kannada-ui-fonts.noarch
google-noto-sans-kayah-li-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-kharoshthi-fonts.noarch
google-noto-sans-khmer-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-khmer-ui-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-lao-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-lao-ui-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-lisu-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-lycian-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-lydian-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-malayalam-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-malayalam-ui-fonts.noarch
google-noto-sans-mandaic-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-meeteimayek-fonts.noarch
google-noto-sans-nko-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-old-south-arabian-fonts.noarch
google-noto-sans-old-turkic-fonts.noarch
google-noto-sans-osmanya-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-phoenician-fonts.noarch
google-noto-sans-shavian-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-symbols-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-tagalog-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-tai-tham-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-tai-viet-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-tamil-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-tamil-ui-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-telugu-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-telugu-ui-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-thai-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-thai-ui-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-ugaritic-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-sans-ui-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-sans-vai-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-serif-armenian-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-serif-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-serif-georgian-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-serif-khmer-fonts.noarch 20130807-2.el7 @ol7_optional_latest
google-noto-serif-lao-fonts.noarch 20130807-2.el7 @anaconda/7.0
google-noto-serif-thai-fonts.noarch 20130807-2.el7 @anaconda/7.0
gubbi-fonts.noarch 1.1-3.el7 @anaconda/7.0
ipa-gothic-fonts.noarch 003.03-5.el7 @anaconda/7.0
ipa-mincho-fonts.noarch 003.03-5.el7 @anaconda/7.0
ipa-pgothic-fonts.noarch 003.03-5.el7 @anaconda/7.0
ipa-pmincho-fonts.noarch 003.03-5.el7 @anaconda/7.0
jomolhari-fonts.noarch 0.003-17.el7 @anaconda/7.0
kacst-art-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-book-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-decorative-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-digital-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-farsi-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-fonts-common.noarch 2.0-12.el7 @anaconda/7.0
kacst-letter-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-naskh-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-office-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-one-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-pen-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-poster-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-qurn-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-screen-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-title-fonts.noarch 2.0-12.el7 @anaconda/7.0
kacst-titlel-fonts.noarch 2.0-12.el7 @anaconda/7.0
khmeros-base-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-battambang-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-bokor-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-fonts-common.noarch 5.0-17.el7 @anaconda/7.0
khmeros-handwritten-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-metal-chrieng-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-muol-fonts.noarch 5.0-17.el7 @anaconda/7.0
khmeros-siemreap-fonts.noarch 5.0-17.el7 @anaconda/7.0
kurdit-unikurd-web-fonts.noarch 20020502-11.el7 @anaconda/7.0
libXfont.i686 1.4.7-3.el7_1 @ol7_latest
libXfont.x86_64 1.4.7-3.el7_1 @ol7_latest
libXfont-devel.i686 1.4.7-3.el7_1 @ol7_optional_latest
libXfont-devel.x86_64 1.4.7-3.el7_1 @ol7_optional_latest
liberation-fonts-common.noarch 1:1.07.2-14.el7 @anaconda/7.0
liberation-mono-fonts.noarch 1:1.07.2-14.el7 @anaconda/7.0
liberation-narrow-fonts.noarch 1:1.07.2-14.el7 @anaconda/7.0
liberation-sans-fonts.noarch 1:1.07.2-14.el7 @anaconda/7.0
liberation-serif-fonts.noarch 1:1.07.2-14.el7 @anaconda/7.0
libfontenc.i686 1.1.1-5.el7 @anaconda/7.0
libfontenc.x86_64 1.1.1-5.el7 @anaconda/7.0
libfontenc-devel.i686 1.1.1-5.el7 @ol7_optional_latest
libfontenc-devel.x86_64 1.1.1-5.el7 @ol7_optional_latest
libfonts.noarch 1.1.3-13.el7 @ol7_optional_latest
libfonts-javadoc.noarch 1.1.3-13.el7 @ol7_optional_latest
libreoffice-opensymbol-fonts.noarch 1:4.2.6.3-5.0.1.el7 @ol7_optional_latest
lklug-fonts.noarch 0.6-10.20090803cvs.el7
@anaconda/7.0
lohit-assamese-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-bengali-fonts.noarch 2.5.3-4.el7 @anaconda/7.0
lohit-devanagari-fonts.noarch 2.5.3-4.el7 @anaconda/7.0
lohit-gujarati-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-kannada-fonts.noarch 2.5.3-3.el7 @anaconda/7.0
lohit-malayalam-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-marathi-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-nepali-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-oriya-fonts.noarch 2.5.4.1-3.el7 @anaconda/7.0
lohit-punjabi-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-tamil-fonts.noarch 2.5.3-2.el7 @anaconda/7.0
lohit-telugu-fonts.noarch 2.5.3-3.el7 @anaconda/7.0
madan-fonts.noarch 2.000-11.el7 @anaconda/7.0
nafees-web-naskh-fonts.noarch 1.2-11.el7 @anaconda/7.0
navilu-fonts.noarch 1.2-3.el7 @anaconda/7.0
nhn-nanum-brush-fonts.noarch 1.100-9.el7 @anaconda/7.0
nhn-nanum-fonts-common.noarch 3.020-9.el7 @anaconda/7.0
nhn-nanum-gothic-fonts.noarch 3.020-9.el7 @anaconda/7.0
nhn-nanum-myeongjo-fonts.noarch 3.020-9.el7 @anaconda/7.0
nhn-nanum-pen-fonts.noarch 1.100-9.el7 @anaconda/7.0
open-sans-fonts.noarch 1.10-1.el7 @ol7_latest
overpass-fonts.noarch 1.01-5.el7 @anaconda/7.0
paktype-naqsh-fonts.noarch 4.1-2.el7 @anaconda/7.0
paktype-naskh-basic-fonts.noarch 4.1-3.el7 @anaconda/7.0
paktype-tehreer-fonts.noarch 4.1-2.el7 @anaconda/7.0
paratype-pt-sans-caption-fonts.noarch 20101909-3.el7 @ol7_optional_latest
paratype-pt-sans-fonts.noarch 20101909-3.el7 @anaconda/7.0
perl-Font-AFM.noarch 1.20-13.el7 @anaconda/7.0
perl-Font-TTF.noarch 1.02-3.el7 @ol7_optional_latest
pothana2000-fonts.noarch 1.3.3-6.el7 @anaconda/7.0
saab-fonts.noarch 0.91-10.el7 @anaconda/7.0
samyak-devanagari-fonts.noarch 1.2.2-12.el7 @anaconda/7.0
samyak-fonts-common.noarch 1.2.2-12.el7 @anaconda/7.0
samyak-gujarati-fonts.noarch 1.2.2-12.el7 @anaconda/7.0
samyak-malayalam-fonts.noarch 1.2.2-12.el7 @anaconda/7.0
samyak-oriya-fonts.noarch 1.2.2-12.el7 @anaconda/7.0
samyak-tamil-fonts.noarch 1.2.2-12.el7 @anaconda/7.0
sil-abyssinica-fonts.noarch 1.200-6.el7 @anaconda/7.0
sil-nuosu-fonts.noarch 2.1.1-5.el7 @anaconda/7.0
sil-padauk-book-fonts.noarch 2.8-5.el7 @ol7_optional_latest
sil-padauk-fonts.noarch 2.8-5.el7 @anaconda/7.0
smc-anjalioldlipi-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-dyuthi-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-fonts-common.noarch 6.0-7.el7 @anaconda/7.0
smc-kalyani-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-meera-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-rachana-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-raghumalayalam-fonts.noarch 6.0-7.el7 @anaconda/7.0
smc-suruma-fonts.noarch 6.0-7.el7 @anaconda/7.0
stix-fonts.noarch 1.1.0-5.el7 @anaconda/7.0
stix-math-fonts.noarch 1.1.0-5.el7 @ol7_optional_latest
tex-fonts-hebrew.noarch 0.1-21.el7 @anaconda/7.0
texlive-amsfonts.noarch 2:svn29208.3.04-32.el7
@anaconda/7.0
texlive-amsfonts-doc.noarch 2:svn29208.3.04-32.el7
texlive-collection-fontsrecommended.noarch
2:svn28082.0-32.20130427_r30134.el7
@anaconda/7.0
texlive-fontbook.noarch 2:svn23608.0.2-32.el7
texlive-fontbook-doc.noarch 2:svn23608.0.2-32.el7
texlive-fontspec.noarch 2:svn29412.v2.3a-32.el7
@anaconda/7.0
texlive-fontspec-doc.noarch 2:svn29412.v2.3a-32.el7
texlive-fontware.noarch 2:svn26689.0-32.el7 @ol7_optional_latest
texlive-fontware-bin.x86_64 2:svn26509.0-32.20130427_r30134.el7
texlive-fontwrap.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
texlive-fontwrap-doc.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
texlive-latex-fonts.noarch 2:svn28888.0-32.el7 @anaconda/7.0
texlive-latex-fonts-doc.noarch 2:svn28888.0-32.el7 @ol7_optional_latest
texlive-metafont.noarch 2:svn26689.2.718281-32.el7
@anaconda/7.0
texlive-metafont-bin.x86_64 2:svn26912.0-32.20130427_r30134.el7
@anaconda/7.0
texlive-pxfonts.noarch 2:svn15878.0-32.el7 @anaconda/7.0
texlive-pxfonts-doc.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
texlive-txfonts.noarch 2:svn15878.0-32.el7 @anaconda/7.0
texlive-txfonts-doc.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
texlive-xetexfontinfo.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
texlive-xetexfontinfo-doc.noarch 2:svn15878.0-32.el7 @ol7_optional_latest
thai-scalable-fonts-common.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-garuda-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-kinnari-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-loma-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-norasi-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-purisa-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-sawasdee-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-tlwgmono-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-tlwgtypewriter-fonts.noarch
thai-scalable-tlwgtypist-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-tlwgtypo-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-umpush-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
thai-scalable-waree-fonts.noarch 0.5.0-7.el7 @anaconda/7.0
tibetan-machine-uni-fonts.noarch 1.901-12.el7 @anaconda/7.0
ucs-miscfixed-fonts.noarch 0.3-11.el7 @anaconda/7.0
urw-fonts.noarch 2.4-16.el7 @anaconda/7.0
vemana2000-fonts.noarch 1.1.3-6.el7 @anaconda/7.0
vlgothic-fonts.noarch 20130607-2.el7 @anaconda/7.0
vlgothic-p-fonts.noarch 20130607-2.el7 @anaconda/7.0
wqy-microhei-fonts.noarch 0.2.0-0.12.beta.el7 @anaconda/7.0
wqy-unibit-fonts.noarch 1.1.0-13.el7 @ol7_optional_latest
wqy-zenhei-fonts.noarch 0.9.46-11.el7 @anaconda/7.0
xorg-x11-font-utils.x86_64 1:7.5-18.1.el7 @anaconda/7.0
xorg-x11-fonts-100dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-1-100dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-1-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-14-100dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-14-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-15-100dpi.noarch 7.5-9.el7 @ol7_optional_latest
xorg-x11-fonts-ISO8859-15-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-2-100dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-2-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-9-100dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ISO8859-9-75dpi.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-Type1.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-cyrillic.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-ethiopic.noarch 7.5-9.el7 @anaconda/7.0
xorg-x11-fonts-misc.noarch 7.5-9.el7 @anaconda/7.0
The openmotif22 package is not included by default on SUSE 10 and SUSE 11 operating systems. If you need to obtain this package, you must go to the Novell website to obtain the package and then perform the installation using the instructions provided by Novell.
If you are installing Oracle HTTP Server on a Linux operating system, the operating system needs to set Native POSIX Threads Library (NPTL) as the default threads-implementation. To check for this, run the following command:
getconf GNU_LIBPTHREAD_VERSION
The expected results should be "NPTL 2.3.4". Failing to have NPTL can result in unexpected behavior for the Oracle HTTP Server, especially if the Multi-Processing Module (MPM) is the Worker MPM.
During the OFR installation, it is preferred to select Install Software - Do not Configure Install type.
This helps to apply the workaround mentioned in section Section 6.2.11, "Configuring Oracle Forms and Reports 11.1.2.2.0 on Oracle Linux 7, Red Hat Linux 7 and SUSE 12 (SP1+) Requires a Symlink" before configuring the product.
Configuring Oracle Forms and Reports 11g Release 2 (11.1.2.2.0) may fail at a given "start report server component" step (i.e. start of "RptSvr_<hostname>_<instancename>").
Checking the log may show that libXm.so.3 cannot be opened because the file does not exist. This error is thrown because the motif library for Oracle Linux 7 and SUSE 12 (SP1+) contains the upgraded version, libXM.so.4*.
To fix this problem, create a symlink named libXm.so.3 that points to the location of libXm.so.4* under /usr/lib64/ before running configuration.
For example, if libXm.so.4.0.* is located in /usr/lib64, do the following:
ln -s /usr/lib64/libXm.so.4.0.4 libXm.so.3
Where, <*> is the specific sub-version of the file.
For Oracle Linux 7, the file name is libXm.so.4.0.4.
Append /usr/lib64 to all LD_LIBRARY_PATH referenced in $ORACLE_HOME/bin/config.sh, like so:
if [ x${LD_LIBRARY_PATH} != x ]; then
LD_LIBRARY_PATH=$ORACLE_HOME/lib:$LD_LIBRARY_PATH:/usr/lib64
export LD_LIBRARY_PATH
else
LD_LIBRARY_PATH=$ORACLE_HOME/lib:/usr/lib64
Run the config.sh from $ORACLE_HOME/bin.
Table 7 lists the platform, operating system, package, and patch information for Solaris operating systems that are either currently supported or were supported in a previous release.
Note: The SRU 11.3.3.6.0 or later (mandatory patch) is required for the Solaris 11 Update 3 on SPARC or x86-64. |
In addition, you should also review the following Solaris-specific issues to see if they are applicable to your environment:
Section 6.3.1, "Installing Font Packages on Solaris 11 for Forms and Reports"
Section 6.3.2, "Installing Oracle Identity Management on Solaris x86-64 Platforms"
Section 6.3.3, "Applying Solaris Patches in Non-Global Zones"
Table 7 Supported Solaris Operating Systems
| Platform | Operating System Version | Required Packages | Required Operating System Patches |
SPARC64 |
Solaris 10 (Update 4+) |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt SUNWmfrun Motif: 2.1.0 |
127111-02 137111-04 |
Solaris 11 Solaris 11 Update 2+ Solaris 11.3 (SRU 11.3.3.6.0 or higher) |
SUNWlibC developer/assembler Motif: 2.1.0 /x11/library/libxp See Section 6.3.1, "Installing Font Packages on Solaris 11 for Forms and Reports" for additional Solaris 11 package requirements. |
x86-64 |
Solaris 10 (Update 6+) |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt Motif: 2.1.0 |
For Oracle Forms and Reports, the following packages must also be installed on Solaris 11 systems:
system/font/daewoo-misc system/font/gnome-fonts system/font/isas-misc system/font/jis-misc system/font/misc-ethiopic system/font/misc-meltho system/font/sun-ja-bitmap system/font/sun-ja-bitmap-unicode system/font/truetype/arphic-ukai system/font/truetype/bh-luxi system/font/truetype/bitstream-vera system/font/truetype/fonts-core system/font/truetype/gentium system/font/truetype/google-droid system/font/truetype/hanyang-ko system/font/truetype/ipafont-mincho system/font/truetype/sil system/font/truetype/unfonts-ko-core system/font/truetype/unfonts-ko-extra system/font/truetype/unifont system/font/truetype/wqy-zenhei system/font/xorg/cyrillic system/font/xorg/iso8859-10 system/font/xorg/iso8859-11 system/font/xorg/iso8859-13 system/font/xorg/iso8859-14 system/font/xorg/iso8859-15 system/font/xorg/iso8859-16 system/font/xorg/iso8859-2 system/font/xorg/iso8859-3 system/font/xorg/iso8859-4 system/font/xorg/iso8859-5 system/font/xorg/iso8859-7 system/font/xorg/iso8859-8 system/font/xorg/iso8859-9
After these packages are installed, you must also set the following environment variables:
On Solaris x86-64 operating systems, set the NLS_LANG environment variable to AMERICAN_AMERICA.WE8ISO8859P15, or set the DISPLAY variable to any 64-Bit Linux machine.
On Solaris SPARC64 operating systems:
Set LC_ALL=C.
Set the NLS_LANG environment variable to AMERICAN_AMERICA.WE8ISO8859P15, or set the DISPLAY variable to any 64-Bit Linux machine.
If you are installing Oracle Identity Management on a Solaris x86-64 platform, you must patch all software versions to the most recent version before you configure a domain. Below is a recommended installation procedure; refer to the product documentation (Oracle Fusion Middleware Installation Guide for Oracle Identity Management) for more details.
Install the most recent version of Oracle WebLogic Server.
If necessary, run Repository Creation Utility (RCU) to create the database schemas.
Perform a software-only installation (do not configure a domain) of the Release 11.1.1.2.0 software.
Patch the software to the latest version with the Patch Set Installer.
Run the configuration tool to configure a domain.
On Solaris operating systems, the prerequisite patches that are applied in the global zone can be considered applied in the non-global zones. There is only one kernel running on the system, and all zones must be at the same patch level with respect to the kernel and other Solaris system components. Kernel patches can only be applied from the global zone, and they affect the global and all non-global zones equally.
To check if a kernel patch is applied in the global zone, use the following command:
showrev -p | grep patch_number
For example, to check if patch 137111-04 is applied:
showrev -p | grep 137111
Table 8 lists the platform, operating system, package, and patch information for HP-UX operating systems that are either currently supported or were supported in a previous release.
Table 8 Supported HP-UX Operating Systems
Itanium |
11i (11.31) B.11.31.0803.318a Base Quality Pack Bundle for HP-UX 11i v3, March 2008+ |
HPDesktopDev (version B.11.31.01) B3394BA (version 2.1.0) |
PHKL_36248 PHKL_36249 PHSS_37202 PHSS_37501 PHCO_38050 PHSS_38139 |
Note: The B3394BA package is obsoleted in HP-UX Itanium 11i v3 machines. This is causing an error message to be seen during prerequisite checking.This error message can be safely ignored provided that the open Motif package can be confirmed as installed on the machine using the following command: /usr/sbin/swlist -l fileset | grep -i motif |
Table 9 lists the platform, operating system, package, and patch information for IBM AIX operating systems that are either currently supported or were supported in a previous release.
Table 9 Supported IBM AIX Operating Systems
AIX |
6.1 (TL2+) |
X11.motif.lib (version 2.1.30) |
7.1 (TL0+) |
bos.adt.base bos.adt.lib bos.adt.libm bos.perf.libperfstat bos.perf.perfstat bos.perf.proctools rsct.basic.rte rsct.compat.clients.rte xlC.aix61.rte (version 10.1.0.0) xlC.rte (version 10.1.0.0) |
7200-00 |
bos.adt.base 7.2.0.0 bos.adt.lib 7.2.0.0 bos.adt.libm 7.2.0.0 bos.perf.libperfstat bos.perf.perfstat 7.2.0.0 bos.perf.proctools 7.2.0.0 rsct.basic.rte 3.2.1.0 rsct.compat.clients.rte 3.2.1.0 xlC.aix61.rte 13.1.2.0 xlC.rte 13.1.2.0 |
This section contains the following:
Refer to the certification documents for the latest information on certified Windows operating systems. See Section 1, "Using This Document with the Certification Matrix and Product Installation Guide" for a link to these documents.
In addition, note the following requirements for specific Windows Operating releases:
If you plan to install and configure Oracle Forms and Reports on Windows 8.1, Windows 2012 Release 1, or Windows 2012 Release 2, then download patch 20836354 before you start the Oracle Forms and Reports installation.
Without this patch, the installer will fail during the preinstallation checks for supported operating systems.
setup.exe PREREQ_CONFIG_LOCATION=PATCH_DIR\prereq
Install the patch mentioned below before you install the Oracle Forms and Reports 11g Release 2 (11.1.2.2.0) on Windows 10 (64-bit).
While installing Oracle Forms and Reports 11g Release 2 (11.1.2.2.0), the operating system prerequisite check may fail on Windows 10 (64-bit).
Apply Generic Patch 22651881 to handle this problem.
unzip -d PATCH_DIR p22651881_111220_Generic.zip
If you encounter issues related to anti-virus software during your Fusion Middleware product installation, disable your anti-virus software for the entire duration of the installation. If the system is restarted before the installation is complete, ensure the anti-virus software was not restarted before continuing with the installation.
Anti-virus software can be re-enabled when the installation is complete.
On Microsoft Windows operating systems, you must enable User Account Control (UAC) so that the correct permissions are applied to the cwallet.sso file.
To enable UAC:
Run secpol.msc from the command prompt.
Select Security Settings > Local Policies > Security Options.
Set the User Account Control:Run all Administrator in Admin Approval Mode option to enabled.
Restart the host.
Restart the servers.
In order to install Oracle Forms and Reports or use the Oracle Forms and Reports Builders after installation, the operating system user must have Windows "Administrator" privileges.
Although the current user may have Windows "Administrator" privileges, if they are not the installation owner, the Windows UAC settings may need to be relaxed.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Oracle Fusion Middleware Forms and Reports System Requirements and Specifications 11g Release 2 (11.1.2)
E25460-03
Copyright © 2012, 2018 Oracle and/or its affiliates. All rights reserved.
This software and related documentation are provided under a license agreement containing restrictions on use and disclosure and are protected by intellectual property laws. Except as expressly permitted in your license agreement or allowed by law, you may not use, copy, reproduce, translate, broadcast, modify, license, transmit, distribute, exhibit, perform, publish, or display any part, in any form, or by any means. Reverse engineering, disassembly, or decompilation of this software, unless required by law for interoperability, is prohibited.
The information contained herein is subject to change without notice and is not warranted to be error-free. If you find any errors, please report them to us in writing.
If this is software or related documentation that is delivered to the U.S. Government or anyone licensing it on behalf of the U.S. Government, then the following notice is applicable:
U.S. GOVERNMENT END USERS: Oracle programs, including any operating system, integrated software, any programs installed on the hardware, and/or documentation, delivered to U.S. Government end users are "commercial computer software" pursuant to the applicable Federal Acquisition Regulation and agency-specific supplemental regulations. As such, use, duplication, disclosure, modification, and adaptation of the programs, including any operating system, integrated software, any programs installed on the hardware, and/or documentation, shall be subject to license terms and license restrictions applicable to the programs. No other rights are granted to the U.S. Government.
This software or hardware is developed for general use in a variety of information management applications. It is not developed or intended for use in any inherently dangerous applications, including applications that may create a risk of personal injury. If you use this software or hardware in dangerous applications, then you shall be responsible to take all appropriate fail-safe, backup, redundancy, and other measures to ensure its safe use. Oracle Corporation and its affiliates disclaim any liability for any damages caused by use of this software or hardware in dangerous applications.
Oracle and Java are registered trademarks of Oracle and/or its affiliates. Other names may be trademarks of their respective owners.
Intel and Intel Xeon are trademarks or registered trademarks of Intel Corporation. All SPARC trademarks are used under license and are trademarks or registered trademarks of SPARC International, Inc. AMD, Opteron, the AMD logo, and the AMD Opteron logo are trademarks or registered trademarks of Advanced Micro Devices. UNIX is a registered trademark of The Open Group.
This software or hardware and documentation may provide access to or information about content, products, and services from third parties. Oracle Corporation and its affiliates are not responsible for and expressly disclaim all warranties of any kind with respect to third-party content, products, and services unless otherwise set forth in an applicable agreement between you and Oracle. Oracle Corporation and its affiliates will not be responsible for any loss, costs, or damages incurred due to your access to or use of third-party content, products, or services, except as set forth in an applicable agreement between you and Oracle.
