Supported Versions and Platforms
For information on supported versions and platforms, see the release certification matrix at http://www.oracle.com/technetwork/middleware/ias/downloads/ fusion-certification-100350.html.
WSDLs Supported by Oracle RightNow Adapter
The Oracle RightNow adapter supports the Standard WSDL only. There is no support for the Partner WSDL. The API version which the RightNow adapter supports is 1.3. See also Obtaining the Standard WSDL.
For more information on the Standard WSDL, see "WSDL Retrieval" in the Oracle RightNow Connect Web Services for SOAP Developer Guide, Getting Started: Introduction to Connect to Web Services.
