ItemsDevuelve una matriz que contiene todos los elementos de un objeto Dictionary.
Sintaxis
object.Items( )
Argumentos
Object: necesario. Siempre es el nombre de un objeto Dictionary.
Observaciones
En el siguiente ejemplo se muestra el uso del método Items:
Ejemplo 1:
Function DicDemo
Dim a, d, i, s ' Create some variables.
Set d = CreateObject("Scripting.Dictionary")
' Add some keys and items.
d.Add "a", "Athens"
d.Add "b", "Belgrade"
d.Add "c", "Cairo"
' Get the items.
a = d.Items
' Iterate the array
For i = 0 To d.Count - 1
s = s & a(i) ' Create return string
Next
DicDemo = s
End Function
' Usage
Dim result
result = DicDemo
' Output: Athens Belgrade Cairo
Ejemplo 2:
Function DicItemsWithKeys
d.Add "x", "Xenon"
d.Add "y", "Yttrium"
d.Add "z", "Zirconium"
' Get the items.
a = d.Items
keysArray = d.Keys
' Iterate the array
s = s & "Key: " & keysArray(i) & ", Item: " & a(i)
Next
DicItemsWithKeys = s
End Function
' Usage
Dim result
result = DicItemsWithKeys
' Output: Key: x, Item: Xenon Key: y, Item: Yttrium Key: z, Item: Zirconium
Ejemplo 3:
Function CountSpecificItems(targetItem)
Dim a, d, i, count
d.Add "m", "Moscow"
d.Add "t", "Tokyo"
d.Add "n", "New York"
d.Add "l", "London"
d.Add "p", "Paris"
' Add duplicate items for counting
d.Add "s", "Paris"
d.Add "y", "Tokyo"
' Get the items.
a = d.Items
' Count the target item
count = 0
If a(i) = targetItem Then
count = count + 1
End If
Next
CountSpecificItems = targetItem & " occurs " & count & " times."
End Function
' Usage
Dim result
result = CountSpecificItems("Paris")
' Output: Paris occurs 2 times.
