RemoveElimina un par de clave y elemento de un objeto Dictionary.
Sintaxis
object.Remove(key)
Argumentos:
Object: necesario. Siempre es el nombre de un objeto Dictionary.
Key: necesario. Clave asociada al par de clave y elemento que desea eliminar del objeto Dictionary.
Observaciones
Se produce un error si el par de clave y elemento no existe.
El siguiente código muestra el uso del método Remove:
Ejemplo 1:
Dim d ' Create a variable.
Set d = CreateObject("Scripting.Dictionary")
' Add some keys and items.
d.Add "a", "Athens"
d.Add "b", "Belgrade"
d.Add "c", "Cairo"
' Remove the key "b" and its associated item
d.Remove("b")
' Output: Dictionary Object Contains Keys: a,c Items : Athens,Cairo
Ejemplo 2:
Function RemoveKey(keyToRemove)
Dim d, msg ' Create some variables.
d.Add "x", "Xenon"
d.Add "y", "Yttrium"
d.Add "z", "Zirconium"
' Check and remove key
If d.Exists(keyToRemove) Then
d.Remove(keyToRemove)
msg = "Key '" & keyToRemove & "' removed."
Else
msg = "Key '" & keyToRemove & "' not found."
End If
' Display remaining items
For Each Key In d.Keys
msg = msg & "Key: " & Key & ", Item: " & d.Item(Key)
Next
RemoveKey = msg
End Function
' Usage
Dim result
result = RemoveKey("y")
' Output: Key 'y' removed. Key: x, Item: Xenon Key: z, Item: Zirconium
Ejemplo 3:
Function RemoveMultipleKeys(keysToRemove)
d.Add "m", "Moscow"
d.Add "n", "New York"
d.Add "p", "Paris"
d.Add "t", "Tokyo"
' Check and remove each key
For Each key In keysToRemove
If d.Exists(key) Then
d.Remove(key)
msg = msg & "Key '" & key & "' removed."
Else
msg = msg & "Key '" & key & "' not found."
End If
Next
msg = msg & "Remaining items:"
Next
RemoveMultipleKeys = msg
End Function
' Usage
Dim keysToRemove
keysToRemove = Array("n", "t", "x")
Dim result
result = RemoveMultipleKeys(keysToRemove)
' Output: Key 'n' removed. Key 't' removed. Key 'x' not found. Remaining items: Key: m, Item: Moscow Key: p, Item: Paris
