Questo esempio di script di importazione restituisce la posizione sotto forma di un valore per la colonna.
# Sample shows how to use the value from the fdmContext map, In
# this sample return the Location as value for the column
def getOrgfromLoc(strfield, strrec):
org = fdmContext['LOCNAME']
return org
# Sample to show the Jython string function. The script below is
# used to parse an account column 01-205-4110-0000-000 and return the
# third string
def getSegfromAcct(strfield, strrec):
if strfield.count("-") > 0:
seglist = strfield.split('-')
result = seglist[2]
return result
# Sample to process header record in Trial Balance report and
# store value in global variable to be used during detail row
# This should be called from the Amount column in import format
globalorg = ""
globalcur = ""
def copyglobal(strfield, strrec):
if strrec[18:27] == "Currency:" :
global globalcur
globalcur = strrec[29:32]
if strrec[14:27] == "Organization:" :
global globalorg
globalorg = strrec[29:32]
if strrec[42:47].strip() == 'Total' or strrec[29:34].strip() == 'Total' :
return fdmSkip
return strfield
# Sample to return the global variable set during amount process
def getCurrfromGlobal(strfield, strrec) :
return globalcur
