Gli elenchi membri POV dinamici vengono creati dinamicamente in base al membro POV corrente di una o più dimensioni.
Le sezioni in grassetto dell'esempio di file elenco membri presentato mostrano le sezioni POV dinamiche.
Sub EnumMemberLists()
Dim EntityLists(5)
If HS.Dimension = "Entity"Then
EntityLists(1) = "AllEntities"
EntityLists(2) = "AppCur"
EntityLists(3) = "NoappCur"
EntityLists(4) = "Global(@POV)"
EntityLists(5) = "POWN(@POV)"
HS.SetMemberLists EntityLists
End If
End Sub
Sub EnumMembersInList()
If HS.Dimension = "Entity" Then
If HS.MemberListID = 1 Then
HS.AddEntityToList "","Corp_Ops"
HS.AddEntityToList "","China"
HS.AddEntityToList ,"","Germany"
HS.AddEntityToList "","UK"
End If
EntList=HS.Entity.List("","")
AppCur=HS.AppSettings.Currency
For each Ent in EntList
If HS.Entity.DefCurrency(Ent)=AppCur Then
If HS.MemberListID = 2 Then HS.AddEntityToList "",Ent
ElseIf Ent<>"[None]" Then
If HS.MemberListID = 3 Then HS.AddEntityToList "",Ent
End If
Next
ScenPOV=HS.MemberListScenario
YearPOV=HS.MemberListYear
PerPOV=HS.MemberListPeriod
EntPOV=HS.MemberListEntity
If HS.MemberListID = 4 Or HS.MemberListID = 5 Then
If ( EntPOV <> "") Then
EntList=HS.Node.List("E#" & EntPOV,"[Descendants]", "S#" & ScenPOV & "..Y#" & YearPOV & ".P#" & PerPOV)
If IsArray(EntList) Then
If Ent <> "[None]" Then
If HS.Node.Method("S#" & ScenPOV & ".Y#" & YearPOV & ".P#" & PerPOV & ".E#" & EntPOV & "." & Ent)="GLOBAL" Then
If HS.MemberListID = 4 Then HS.AddEntityToList "",Ent
End If
If HS.Node.POwn("S#" & ScenPOV & ".Y#" & YearPOV & ".P#" & PerPOV & ".E#" & EntPOV & "." & Ent) > 0.5 Then
If HS.MemberListID = 5 Then HS.AddEntityToList "",Ent
End If
End If
Next
End If
End If
End If
End Sub
