事件指令碼範例
此範例「事件」指令碼會在資料載入執行期間更新 table_xyz 表格:
# Sample to update table_xyz table during data load rule execution
query = "UPDATE table_xyz SET accountx = 'SCRIPT_' || account WHERE loadid = ? and accountx is NULL"
params = [ fdmContext["LOADID"] ]
print fdmAPI.executeDML(query, params, False)
fdmAPI.commitTransaction()
# Sample to import data from a custom SQL source and upload into FDMEE
# open interface table. This script should be called in BefImport Event.
# This is alternate to the FDMEE integration import script.
import java.sql as sql
batchName = "Batch_" + str(fdmContext["LOCNAME"])
insertStmt = """
INSERT INTO AIF_OPEN_INTERFACE (
   BATCH_NAME
  ,COL01
  ,COL02
  ,AMOUNT
  ,DESC1
) VALUES (
sourceConn = sql.DriverManager.getConnection("jdbcUrl", "user", "password");
# Limiting number of rows to 5 during the test runs.
selectStmt = "SELECT * FROM orders WHERE rownum < 6"
stmt = sourceConn.prepareStatement(selectStmt)
stmtRS = stmt.executeQuery()
while(stmtRS.next()):
  params = [ batchName, stmtRS.getBigDecimal("Customer_Id"),
             stmtRS.getString("Ship_Country"),
             stmtRS.getBigDecimal("Freight"), stmtRS.getString("Ship_Name") ]
  fdmAPI.executeDML(insertStmt, params, False)
stmtRS.close()
stmt.close()
sourceConn.close()
# Sample to send email messages using Jython SMTP library
import smtplib
sender = "from@gmail.com"
receivers = "to@gmail.com"
message = """ This is a test e-mail message.
              This is a test e-mail message.  """
try:
  smtpServer = smtplib.SMTP('smtp.gmail.com:587')
  smtpServer.starttls()
  smtpServer.login("user", "password")
  smtpServer.sendmail(sender, receivers, message)
  print "Successfully sent email"
  smtpServer.quit()
except Exception, e:
  print "Error: unable to send email: " + str(e)
註:
請參閱位於下列連結的線上 Jython 文件,該文件說明 Jython 例外清單以及設陷擷取指令碼的例外時使用的語法:如需在 Jython 中使用例外處理機制的資訊,請參閱例外處理與除錯。
此注意事項適用於所有指令碼類型。
