The DROP TYPE BODY statement drops the body of an object type, varray, or nested table type. When you drop a type body, the object type specification still exists, and you can re-create the type body. Prior to re-creating the body, you can still use the object type, although you cannot call the member functions.
The object type body must be in your own schema or you must have the DROP ANY TYPE system privilege.
Keyword and Parameter Descriptions
Specify the schema containing the object type. If you omit schema, then the database assumes the object type is in your own schema.
Specify the name of the object type body to be dropped.
Restriction on Dropping Type Bodies You can drop a type body only if it has no type or table dependencies.
Dropping an Object Type Body: Example The following statement removes object type body data_typ1. See Object Type Examples for the example that creates this object type.
DROP TYPE BODY data_typ1;
