| Bookshelf Home | Contents | Index | PDF |    |
| Application Services Interface Reference > Application Services Interfaces (ASIs) > ASIs and Web Services > Handling Errors for ASIsThe SOAP fault message returns any errors for inbound and outbound ASIs. Errors for Inbound ASIsThe SOAP fault block returns any inbound error messages, as defined by the SOAP 1.1 specification. The  The following XML shows an example of a fault message. <?xml version="1.0" encoding="UTF-8" ?>  <SOAP-ENV:Fault xmlns:siebelf="http://www.siebel.com/ws/fault">       <faultstring>    <detail>          <siebelf:errormsg>Supplied input is not well formed          <siebelf:error>         <siebelf:errormsg>XML Hierarchy Converter error - empty       </siebelf:errorstack>  Errors for Outbound ASIsIf an error occurs during an outbound ASI that has been exposed as a Web Service, the business service raises the error and returns the SOAP fault message as the output method argument, soap:fault, for the application to process. The error is represented as an XML hierarchy property set. These outbound ASIs can potentially time out. You can specify the time out interval as a siebel:timeout argument. If a time-out interval is not specified, the transport's default time-out applies. An  |
| Application Services Interface Reference |
