| Application Services Interface Reference > Application Services Interfaces (ASIs)  > ASIs and Web Services > Protocols Used with ASIs
 ASIs support the standard XML envelope for Web Services and SOAP. Siebel applications support two types of SOAP protocols—SOAP-Remote Call Procedure (RPC) and SOAP-DOC. If an inbound ASI supports an industry standard other than the protocols that Siebel Systems supports, the ASI cannot be defined as an inbound Web Service. The ASI must be defined and supported through the existing EAI framework.  Table 5 lists the various types of transport and protocols available. The Null Protocol implements a loopback—a call back into the Siebel servers. Any method arguments passed using the Null Protocol or that are not directly specified are forwarded to the local business service or local workflow. When testing an ASI, you can use the File protocol.
Table 5.  Protocols
    | HTTP | Inbound/Outbound | Inbound/Outbound | N/A |
    | MQ | Inbound/Outbound | Outbound | N/A |
    | MSMQ | Inbound/Outbound | Outbound | N/A |
    | Local Business Service | Inbound/Outbound | N/A | N/A |
    | Local Web Service | Outbound | Outbound | Outbound |
    | Local Workflow | Outbound | Outbound | Outbound |
    | File | Outbound | Outbound | Outbound |
