Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Applications Administration Guide > State Models > Configuring Child Modification for State ModelsBy default, child records cannot be created, modified, or deleted when the state of the parent record is No Delete. You can change this behavior in two ways:
To enable child modification for all business components
To disable child modification for an individual business component if child modification is globally enabled |
Applications Administration Guide |
