Siebel Assignment Manager Administration Guide > Running Assignment Manager > Activating Contact Denormalization for Dynamic AssignmentFor dynamic assignment, if you want to run Assignment Manager in contact denormalization mode, you must activate the Contact Denormalization assignment policy. By default, this policy is inactive. NOTE: When Assignment Manager runs in contact denormalization mode, it does not evaluate assignment rules. Therefore, you do not need to select the Contact Denormalization object for the assignment rule to run Assignment Manager in contact denormalization mode. Use the following procedure to activate contact denormalization for dynamic assignment. To activate contact denormalization
NOTE: If running batch assignment, you do not need to activate this policy. |
| Siebel Assignment Manager Administration Guide |
