Configuring Siebel eBusiness Applications > Configuring Applets > Exposing System FieldsTo expose system fields in the user interface, you create either a list column (within a list applet) or a control (within an entry applet). NOTE: You do not need to define system fields as child Field objects of the underlying business component. To define a list column object
| Configuring Siebel eBusiness Applications |
