Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard > Mapping Business Component Fields to the Dashboard Business ServiceYou must map the available fields on the business component to fields on the Customer Dashboard applet. You do this by defining user properties for the Persistent Customer Dashboard business service. The user property name identifies the Customer Dashboard fields, such as Field 1, Field 2, and so on. The value of the user property defines the business component list and one of the available fields. The syntax for the value is the name of the list user property, for example List1, followed by the position of the field in the list for that user property. For example, List 1.1 is the first field available from List1, List1.2 is the second field available from List1, and so on. For more information about business component lists, see Adding Business Component Lists User Properties to the Dashboard Business Service. For example, to display the Last Name field from the Contact business component (see List1 in Table 69) in Field 1 of the Customer Dashboard, you would define a user property as shown in Table 70 below: You can display fields from more than one business component in a single Customer Dashboard field. To do this, you define multiple values for the Customer Dashboard field's user property. For example, suppose that when the Customer Dashboard is in the context of Contacts, you want Field 1 of the Customer Dashboard to display Last Name. However, when the Customer Dashboard is in the context of Opportunities, you want Field 1 to display Opportunity Name. To map multiple business component fields to a single Customer Dashboard field, you define the user property as shown in Table 71. List 1.1. represents the first field of List one. List2.1 represents the first field of List2. The Customer Dashboard business service searches through the list of user properties, starting with Field, and looks for fields that are mapped to the Customer Dashboard from the current business component. For example, when the Contact business component is instantiated, the business service looks for Fields mapped from the Contact business component. Fields in the Customer Dashboard not mapped to fields in the current business component remain empty. NOTE: The following fields are preconfigured for the Customer Dashboard, Field 1, Field 2, Field 3, Field 4, Field 5, Field 10, Field 12. Field 4 is formatted to display phone numbers. This task is a step in the Process for Configuring the Customer Dashboard. |
Configuring Siebel eBusiness Applications |
