Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Aligning Shapes
The Align option allows you to align shapes relative to each other on the ERD canvas. To align shapes in the ERD canvas
- Navigate to an entity relationship diagram.
For instructions, see Navigating to Entity Relationship Diagrams.
- In the ERD canvas, select two or more entities by holding down the shift key while clicking the shapes.
- Right-click and then choose Layout > Align > and one of the following options:
